Author Topic: Bit of a ballsup  (Read 15232 times)
Offline ega
Bit of a ballsup
« on: December 29, 2015, 06:14:46 PM »
I'd like to show a casualty from my long-running Quorn T&C grinder campaign. With luck it will appear as an attachment but I don't immediately see how the insert image feature works. I'll press Post and see what happens.
Re: Bit of a ballsup
« Reply #1 on: December 29, 2015, 06:26:08 PM »
What happened? did it turn in the vice whist you were trying to bore a hole through it?
Huge pictue resized - 800x600 is much better
Offline efrench
« Reply #2 on: December 30, 2015, 12:45:22 AM »
Nice looking knurl :clap:
Offline tomrux
« Reply #3 on: December 30, 2015, 04:02:42 AM »
my first thought
Tom R
Offline RotarySMP
  • Country: at
« Reply #4 on: December 30, 2015, 04:20:43 AM »
Now you just have to figure out how you did it and make the othe 15 the same.
Mark
Mark
Offline ega
« Reply #5 on: December 30, 2015, 07:57:54 AM »
Pete:
You are pretty well spot on. I was following the G H Thomas words and music for ball handles and the workpiece moved whilst being faced off preparatory to drilling and tapping; if I had not hit the clutch so promptly I think I would have decorated the ball all round.
I should add a correction: the handle was actually intended for GHT's pillar tool. When I built the Quorn I used the form tool method recommended by the designer but then moved on to using a generating tool.
Thanks for the picture tip which I will try next time. Do you happen to know how to turn off the animated smileys?
« Reply #6 on: December 30, 2015, 10:34:13 AM »
When you make a reply, click on attachments and other options and put a tick in the 'don't use smilies' checkbox.
Offline mcostello
  • Lancaster, Ohio
« Reply #7 on: December 30, 2015, 10:54:51 AM »
That is kinda neat, now if You had just wanted it................
Offline ega
« Reply #8 on: January 05, 2016, 05:26:14 AM »
Pete:
Thanks for the tip. Checking the "Don't use smileys" box doesn't remove them from the screen for me but I have just done the obvious thing and scrolled down so I no longer have to look at them.
« Reply #9 on: January 05, 2016, 01:14:32 PM »
They are like newspaper adverts. Pretty soon you won't notice they are there.
Offline efrench
« Reply #10 on: January 05, 2016, 09:52:40 PM »
Pete:
That was a good idea  :) :)
Offline Pete49
« Reply #11 on: January 05, 2016, 10:20:23 PM »
I agree  :mmr: :headbang: :nrocks:
(I know ....off to the naughty corner)
