Author Topic: Melting crankshafts  (Read 7412 times)
Offline ironman
Melting crankshafts
« on: January 24, 2016, 06:41:07 PM »
Hi everyone
I was running low on scrap cast iron so I dismantled some lawnmower engines. The crankshafts were melted for the castings I needed, have a look at the video to see how it turned out.
« Last Edit: May 24, 2022, 09:08:17 PM by vtsteam »
Online awemawson
Re: Melting crankshafts
« Reply #1 on: January 25, 2016, 03:19:23 AM »
Ironman, your videos are always informative and interesting, and this one is no exception. Thank you for sharing. :thumbup:
Offline RotarySMP
  • Country: at
« Reply #2 on: January 25, 2016, 06:39:23 AM »
Nice. It really helps to have someone post videos of how to do thing properly.You really have perfect process control. Really impressed that there is no porosity at all.
This was green sand wasn't it? Do you measure sand moisture level, or have the experience to just do it be feel? Roughly what oil flow rate were you running?
Regards,
Mark
Mark
Offline NormanV
  • United Kingdom
« Reply #3 on: January 25, 2016, 12:07:14 PM »
I've done a lot of aluminium casting but from watching this video I can see that I have a lot to learn. Very informative, thanks.
« Reply #4 on: January 25, 2016, 12:41:53 PM »
That slo-mo of the liquid metal splattering on the floor should be a clear warning to those who you see pouring while wearing shorts and sandals. Don't do it.
« Reply #5 on: January 25, 2016, 04:56:54 PM »
Cracking video! Thanks for sharing,
Offline ironman
« Reply #6 on: January 26, 2016, 06:21:07 PM »
Mark This is green sand and I use a liter container to measure how much water to put in the sand.
Offline ironman
« Reply #7 on: January 27, 2016, 09:53:02 PM »
Mark I forgot to answer your other question, the oil flow rate is 13.73 litres per hour.
Offline RotarySMP
  • Country: at
« Reply #8 on: January 28, 2016, 05:45:00 AM »
Thanks.
Mark
Offline Toolshed
« Reply #9 on: May 04, 2016, 10:02:50 PM »
ONE OF THESE DAYS. IRON!!!!  :-)  I'm just doing aluminum at this point....
Metalworker
Woodworker
Metal Caster
