Author Topic: Giffard boiler water injectors  (Read 9940 times)
Offline picclock
« on: June 25, 2016, 11:05:01 AM »
For anyone who doesn't know what I'm talking about :
http://www.bluebell-railway.co.uk/~uhaa009/bb/locos/3217/injector.html
Apart from the fact that these seem like a bit of sleight of hand magic has anyone successfully used these in a model engine ?  It does seem odd that you can take a high pressure gas, shoot it down a cone, picking up water on the way, then re-pressurise it to higher than its original level and feed it back into the boiler. How much high pressure gas is wasted in the process? Do design formulae exist for this configuration?
Failing that what sort of water injectors do you use on your model engines ?
Any help or info much appreciated.
Best Regards
picclock
inthesticks
Re: Giffard boiler water injectors
« Reply #1 on: June 25, 2016, 12:57:42 PM »
Hello PICCLOCK as a stationary engineer I recieved instruction on thier operation. They are finicky to operate and if found in a modern power plant are used only for emergency back-up. For model engineering they would be a great project. I believe Model Engineering Magazine did an article on this years ago, if you have access to an index you may be able to find it.
Below are 8 page scans from one of my stationary engineering books covering thier design, construction and operation with questions. Hope this helps. :thumbup:
CB
Offline picclock
« Reply #2 on: June 26, 2016, 03:31:30 AM »
Hi inthesticks
That is the best info I have ever seen. Many, many thanks for taking the time to post it. I have printed out the pages and hopefully the dark clouds of ignorance are moving away.
The info you provided clearly shows and the sequence of events initiating the process (p381), something which I have not seen explained elsewhere.
I am not surprised. One of the issues with this solution is that to work well the flow must contain a lot of energy. If you have a large volume of steam this is not a problem, but on a modelling scale much of the steam energy will be absorbed by the boundary layer effect, and increasing the volume of flow would quickly deplete a model boiler pressure reserves.
If they are only used as a backup in 'modern' boilers, do you know what mechanisms are used in their place?
I will try to hunt down the model engineer article you mentioned to see if they succeeded in making one work at such a small scale.
Best regards and a (sadly) virtual  :beer:
picclock
« Reply #3 on: June 26, 2016, 03:32:57 AM »
D E Lawrence artical in ME 1986
inthesticks
« Reply #4 on: June 26, 2016, 09:52:26 AM »
Glad you found the info. usefull PICCLOCK.You will not find injectors in lage industrial plants thier feedwater volume requiremants are to high for injectors.In smaller heating and cooling plants they can still be found. I worked one hospital heating and cooling plant with 3, 25,0000 lbs/hr. Cleaver Brooks firetube boilers.
Thier 2 main feedwater pumps were electrically driven. In the event of a power failure each boiler had its own injector mounted in its feedwater supply to provide water during the shut down proccess. Clean feedwater is important, as noted in the earlier text they will gum-up quikly. The majority of plants use electrical and steam turbine prime movers for their feedwater pumps. Steam turbines probably logging more hrs. than any other method.
Below is a section diagram of a tipical steam turbine used in feedwater service.
CB
Offline ozzie46
« Reply #5 on: June 26, 2016, 10:00:00 AM »
   L.B.S.C. of Model Engineering fame used injectors in many of his model Locomotive designs and claimed they were fairly easy to make and use if you followed his "words and music" as he refered to his instructions. I can't claim to have any first hand knowledge of such as I have never attempted to make any yet.
    Ron
« Reply #6 on: June 26, 2016, 12:23:41 PM »
    Ron
It's the reamers that are tricky to make , to soft and the ends twist off to hard and the ends snap off .
Offline Noitoen
  • Country: pt
« Reply #7 on: July 06, 2016, 01:38:19 PM »
There is a guy here in Portugal that has built some. I can't remember his web site but I will search a little. Here is a video in Portuguese. https://youtu.be/m2u3kivLDL0
Web page no longer exists I found a Facebook link https://pt-pt.facebook.com/vaporvivo/
Offline picclock
« Reply #8 on: July 21, 2016, 04:33:28 AM »
Hi all
I have just found this thread on Madmodder
http://madmodder.net/index.php/topic,10761.0/all.html
which gives all the information I was after.  :Doh:
Just didn't search with the correct terms ....
Best regards
picclock
« Reply #9 on: July 21, 2016, 03:35:14 PM »
They can be a bit tempremental but get it correct they work like a dream I have one I made fitted to my loco that I run most week ends and it works very well
Offline Sackett
« Reply #10 on: July 28, 2016, 03:41:56 PM »
They are indeed finicky. One of the veneer mills I worked had one, n a donkey pump when I satarted there in the early 70's. Used to have to run cold water on both to get themstarted. Injectors will pump a lot of water tho.Handy trick to keep saftey from popping was use injector
