Author Topic: Cutting Spur Gears -- A neat technique  (Read 149670 times)
Offline xo18thfa
« on: February 22, 2017, 01:24:34 AM »
Several years ago, I did a series on cutting spur gears using the methods in the “Workshop Practice Series” book #17, “Gears and Gear Cutting” by Ivan Law:
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Law%20Book_zpsevy3b904.jpgCutting Spur Gears -- A neat technique
Mr Law's method works great.  You can follow his techniques without deviation.  However, recently I found another method to cut gears that approximates involute tooth using only one cutter to form gears of any size within the diametral pitch.  The method is described by "Helicron" at his website.
http://www.helicron.net/workshop/gearcutting/
I followed Helicron's technique with good results.
First step is to make the cutter tool.  My lathe is not rigid enough to make the cutter as Helicron shows.  Instead mine is a single point cutter with most of the blank removed before forming the cutting teeth.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Cutter%20Bit_zps19quvcjo.jpgCutting Spur Gears -- A neat technique
The steel for the cutter is alloy “O1”. O1 is the most widely used tool steel and is available from McMaster Carr and other suppliers. O1 is very easy to work with and harden. Shape and form the tool to the desired size. Heat with a torch to 1400 degrees F, which is cherry red heat in room light. Plunge in oil to quench. I used some leftover salad oil from the kitchen. Leave in the oil quench about 30 seconds, it cools down slowly. Quenched tool steel is too brittle at this point and needs tempering. To temper, suspend the tool in a small pot of salad oil on the kitchen stove. Heat to 350 degrees F using a candy thermometer to check the temperature. Leave it in about 10 minutes, pull out and let air dry. The O1 steel comes out very hard and will cut just about anything.
For an upcoming project I want to cut some 48 diametral pitch gears with 52, and 16 teeth.  First, the 52-tooth gear.  These are from 1/8” thick flat brass bar.  First, make a shank from length of 1/2" diameter steel in the lathe cut and turn a 5/16” diameter boss. Thread the end to accept a nut. Gang up four pieces of brass stock on the shank.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/52%20Blank%201_zpsld6etjqo.jpgCutting Spur Gears -- A neat technique
Turn the ganged stock to the final diameter for the gear.  In this case 1.125"
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/52%20Blank%202_zpscetazxno.jpgCutting Spur Gears -- A neat technique
To cut the gears I used my little, homemade Harold Hall dividing head.  It is a “direct indexing” head that uses the change gears from the Atlas 6” lathe for indexing.  The spindle hole is tapered with #2 Morse Taper (2MT). A 2MT collet holds cinches stock tightly in the dividing head be means of a draw bar.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Dividing%20Head_zpsu2f65hhy.jpgCutting Spur Gears -- A neat technique
Secure the 52-tooth lathe change gear to the spindle of the dividing head. Mount the dividing head to the mill table. Use a 1/2" 2MT collet to chuck the gear blanks.  Chuck the gear cutter in the mill spindle and use a height measure device to set the gear cutter height.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Cutting%2052%201_zpst2qhts9a.jpgCutting Spur Gears -- A neat technique
Adjust the depth of cut and start cutting. depth of cut on 48DP gears is 0.045".  Advance the dividing head spindle one notch on the indexing gear.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Cutting%2052%202_zps9ecakztf.jpgCutting Spur Gears -- A neat technique
Finish the 52 tooth gears by soft soldering an appropriate hub.  Drill and tap for a set screw.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Cutting%2052%203_zpstslsvuln.jpgCutting Spur Gears -- A neat technique
Next time we will cut the 16 tooth gear and do something with the results.
Bob Sorenson
Harrisburg, South Dakota, USA
Offline bertie_bassett
Re: Cutting Spur Gears -- A neat technique
« Reply #1 on: February 22, 2017, 01:23:41 PM »
nice work
that method is one im planning on using again in the near future to make change gears for my lathe.
last time i tried it didnt quite work, think my cutter wasnt very accurate. and had issues with working out the depth of cut
couple of questions:
a multi tooth cutter would have been easier on your lathe surely? its just a series of v's at the correct spacing. cuting just one tooth as you have must have been quite clunky as it went round and id have thought harder on your lathe?
also from memory you only need about 5 teeth, anymore dosnt help as they dont do any cutting ( unless your cutting a gear with hundreds of teeth.
« Reply #2 on: February 22, 2017, 02:57:05 PM »
There used to be a series of videos on YouTube by a guy called Hobbynut, showing how he used a very similar technique to make gears on his Sherline lathe & mill. I think I downloaded them somewhere, no idea where they'd be now, I'm pretty sure they've gone now. I can't remember if his cutter required indexing, or if it was a free-running hob, though.
Even so, liked the write up on Helicron's site, that definitely gives me the confidence to have another go at gear cutting!
« Reply #3 on: February 22, 2017, 03:20:59 PM »
Yes those Hobbynut videos were very informative but as you say they have gone now.
There is a DVD by Jose Rodriguez on gear cutting doing the rounds, about £30 a pop.
Don't bother it's absolute $hite
He's using some home made mill made from licorice root and drinking straws, the video is out of focus and any close up could be a shop of anything [ probably blancmange ]
But the biggest fook up is he gets Pi wrong all the way thru all his calculations so all his calculations are off.
Since when is Pi 3 416 ??
« Reply #4 on: February 22, 2017, 04:13:15 PM »
Imperial PI? Metric is standard :lol:
« Reply #5 on: February 22, 2017, 07:33:20 PM »
In practice I've found that no tempering is needed when working with brass or other soft metals like aluminum.
In fact, for a one-off tool that's going to see little use you can often get away without tempering the tool for most materials found in the home shop.
Offline xo18thfa
« Reply #6 on: February 22, 2017, 10:15:19 PM »
nice work
I tried the multi tooth cutter using helicron's method.  My little lathe started to chatter a lot and the attempt failed.  The single point tool bumped too, but less.  I'll re-visit the tool making method again.  Yes, 5 or 6 teeth are enough.  I did not know what to expect.
According to Mr Law (in his book), depth of cut = 2.157/DP (DP is diametral pitch)
Thanks, Bob
Bob Sorenson
Offline xo18thfa
« Reply #7 on: February 22, 2017, 10:19:31 PM »
Good to know.  That saves a step.  Wife gets upset when I use her cooking oil anyway
Bob Sorenson
Offline Lew_Merrick_PE
« Reply #8 on: February 23, 2017, 11:57:05 AM »
There are two steps to heat treating steel.  1) Hardening and 2) tempering.  The first (hardening) takes the surface of the steel to a Body-Centered-Cubic crystalline form (which is why "hard steel" grows in size).  And tempering "relieves the stresses" generated by such a transformation which makes it more resistant to breakage.
« Reply #9 on: February 23, 2017, 07:31:37 PM »
No arguments here.  What you've said is correct.  Though I doubt most home shop machinists care what form of crystal the steel is, as long as it does the job.
What I was pointing out was merely a shortcut that you can often get away with - kinda like sex without birth control.
I didn't think it necessary to add the obvious: "Don't come crying to me if your tool shatters" (or if the baby is crying).
« Reply #10 on: February 24, 2017, 08:07:07 AM »
Often tool steels temper ok, without complete cycling...Ie. Hardening, but you don't let it cool completely, just when water does not boil anymore, lift it out and let residual heat to do tempering. Some guy's at the knife making class were pretty good at this.
I did the two step process and first blade went fine, second had wery thin blade and I got bit bluish near tang and straw on the tip. I was aiming in-between, but it became ok knife. Not perfect, but not dog either.
Offline xo18thfa
« Reply #11 on: February 24, 2017, 09:27:00 PM »
The 16-tooth pinion cuts in the same general manner as the 52’s. The notable difference is that the hub is integral, rather then hub less.
Change out the 52 tooth indexing gear on the dividing head and replace it with a 32 tooth.  During machining, skip every other tooth to get 16 divisions.
A 16 tooth, 48DP gear has a rough stock diameter of exactly 3/8” which is convenient. Use a 3/8” collet to chuck some 3/8” stock.  Cut as before.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Cutting%2016_zpsymn5x0tp.jpgCutting Spur Gears -- A neat technique
With the dividing head set up I did some 32 tooth gears too.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Cutting%2032_zpssevscvni.jpgCutting Spur Gears -- A neat technique
Chuck the 16 tooth gear in the lathe and turn a hub. Tap for some set screws and it’s done.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Finished%2016%2032_zpsprdn5q5b.jpgCutting Spur Gears -- A neat technique
These gears are going into a scaled up Ernest Glaser “Cracker”
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Regal%201_zpsbmrxp3pq.jpgCutting Spur Gears -- A neat technique
They mesh perfectly. The chassis rolls smooth as silk.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Regal%202_zpsvhfwlpzw.jpgCutting Spur Gears -- A neat technique
Observations:
- Helicron's method is a great way for cutting gears. Simple to follow, simple to do.  A single cutter rather then a set of 7 or 8 is so much better.
- My lathe is not rigid enough to make the cutter blank as he shows.  So I went with the single tooth cutter.  Perhaps feeding the lathe bit in at an angle would be better then plunging straight in as I did.
- Overall grade: A-
Bob Sorenson
« Reply #12 on: February 24, 2017, 10:21:07 PM »
Nice work.  I definitely like the idea of using a rack-shaped cutter over the use of a specially shaped single point tool.  Are you able to get an extreme close-up picture of the resulting tooth profile?
As for the lathe not being rigid enough to cut the cull diameter, this is possible - even likely.  But, I wonder if you couldn't get the result you were looking for either by turning the speed (RPM) way down.  Feed as quickly as your lathe will allow with a sharp tool.  Another possibility is to rough out the grooves a bit first with another tool then come and finish using the above parameters.
... Or go CNC and peck at it using a few plunges.  Too finicky for manual, though some might attempt it.
« Reply #13 on: February 25, 2017, 03:57:40 AM »
Those gears look very nice. Very good work and very nice info.
That method looks worth trying...hmm..where do I need some gears?
« Reply #14 on: February 25, 2017, 02:29:16 PM »
I see a project for me one of them dividing heads
Offline xo18thfa
« Reply #15 on: February 26, 2017, 08:54:39 PM »
Thanks for the kind words.
Here are the best pics I could get with this camera.  Holding these gears up to the light with a commercial gear shows they are pretty close.  You can see the flat cuts of the "approximate involute" but it does not seem to affect the performance.  I have a set of these in a "Cracker" loco that's been run hard and no appearance of wear.
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Close%20up%201_zpsjzbcwxuc.jpgCutting Spur Gears -- A neat technique
http://i280.photobucket.com/albums/kk189/xo18thfa/Gear%20Cutting/Close%20up%202_zpsla6kw6dc.jpgCutting Spur Gears -- A neat technique
I like this method.  Going to try 32 DP gear next.
The dividing head is Harold Hall's design.  It has a #2 Morse Taper spindle which is not a good idea. Morse Tapers do not quick release.  They go in tight and need a hammer blow on the draw bar to loosen.  I have a set of castings for George Thomas' "Versatile Dividing Head".  Going to set that one up with a straight shank ER-25 collet.  I think that will work better.  It will also be direct dividing with change gears or plates.
Bob Sorenson
« Reply #16 on: February 27, 2017, 03:01:16 AM »
Very nicely done  :thumbup:
I'm tempted to have a try just for the fun of it despite not at the moment needing any gears.
Offline Biggles
« Reply #17 on: February 27, 2017, 01:10:52 PM »
Propar Job!  :)
« Reply #18 on: February 27, 2017, 09:25:57 PM »
Again, very nice. I'm in the same boat as others though... don't need any gears at the moment.
Offline seacat
« Reply #19 on: April 22, 2017, 06:26:59 PM »
Bob, very nice gears and a very nice application you have made for them.  A very useful method of gear making which I have noted down - I have some gears to make sometime soon including an internal gear and this looks like solving the problem of the making of the spur gears at least.
Yes, I can see that the gears have a series of straight lines on the teeth - had the been steel gears I would have suggested you make a "running in board", where the gears are mounted on spindles on a temporary board and one gear driven to drive the rest and run for ten minutes or so with grinding paste to grind the gears into one another, which would take off the rough edges, such as they are, not very rough really.  But being brass this would not work as the grinding paste would only inbed itself into the brass for every more.  Perhaps if they are run with plenty of lub they will bed themselves in, if you are worried about it.  Not sure I would be much!
Offline fatal-exception
« Reply #20 on: May 05, 2017, 06:27:29 PM »
I spent hours last weekend making a cutter as pictured by the OP for 20DP gears. It did not work at all for cutting the actual gears. The cutter cut just fine, but the geometry of the finished teeth was, well, non existent. The teeth are pretty much triangular with no involute to them at all. I think I will try to replicate what this cutter does in a solidworks model. I should be able to see if this was doomed from the start, or it's a scale issue.
Has anyone else tried this method with a larger pitch tooth? The gears made at 48dp look good. Wish I could say the same.  :coffee:
Now I've cheated and bought an 8 piece cutter set off e-bay for $100. Completely against the spirit of Mad Modder...oh well, I gave it a shot.
« Reply #21 on: May 06, 2017, 12:08:11 AM »
Well done, you gave it a go.  :clap:   And have new found respect for a fellow modder.
« Reply #22 on: May 06, 2017, 02:34:25 AM »
What do you think went wrong? I never tried this method, but (to electrical engineer) it looks like if you get the cutter profile correct, lace it to centreline of the "disc" and have depth set right it should produce nearly correct tooth form.
Is it possible dwell on this one more? I see this a learning experience.
« Reply #23 on: May 06, 2017, 04:32:16 AM »
Very true.
True story based on real world experience.
Few years ago I used to make proper form cutters using a full sized Eureka attachment, 1" bore model.
These were made out of gauge plate which is the flat version of silver steel or drill rod as known in America.
These were machined and then sent away for professional hardening and tempering. Cost wasn't a problem, what was a problem was the profile had to be exact.
When they came back the faces of the cutter were ground, one face one way, the other face the opposite way so all the burrs were thrown ff the cutter as believe it or not these also provide clearance.
Then fitted to the machine, basically a wood router they worked very well but the life before regrinds wasn't as good as using HSS and was a bit of a disappointment.
On one set because we were pushed for time we self hardened the cutters but didn't temper them, just ground them and put them to work.
This set cut far better and lasted longer. We determined that the heat generated from grinding was enough to take the brittle edge off the file actual tips that did the cutting.
After that it was make, harden, grind and use.
« Reply #24 on: May 17, 2017, 06:43:04 PM »
So I had a chance this afternoon to simulate this cutter, cutting a gear in Solidworks. I setup up the DP, PA, OD, and tooth count as variables and used them to do an extruded cut on the outside of a simple cylinder, which is driven by the OD variable. Then a circular array of this cut is done 'Tooth count' times to form the gear.
Here's the larger gear with more teeth.
Maybe I wrote off this method a bit hastily. Oddly enough, in theory, this should work, even with 20DP and larger gears. The only place it gets a bit whacky is with low tooth counts, the crest of the tooth takes on a more triangular shape.
Honestly, the gears don't look all that great, but when put together in an assembly and constrained at the correct distance apart, they mesh and have no unwanted interference during the contact time, so again, they should work.
Now I have to go home and figure out why my real world example didn't work. Maybe I was a bit too sloppy setting up the DOC....
Paul
