Author Topic: Knocking one off the list ,,, Tapping attachment  (Read 30591 times)
« on: December 05, 2010, 02:56:11 PM »
Hi Lads
Being at a bit of a loose end this afternoon i thought i would make a start on a tapping tool ,,,, giving it a bit thought i decided instead of making the complete tool i would make an attachment to fit my new ped/drill as it has a good stiff column and large table ,,, this way i would save on shop space , material and time  :med:
The design so far ,  going to be a welded up job  :dremel:
It will fit here, between the collar and head casting  and can be swung out of the way when not required
Selection of mystery metal for the job  :)
A bit of ruff machining to size and welding  :dremel:
I still have to make and weld in the webs
When i have it all welded up i will stick it in the furnace for a bit of stress relieving  ,, then machine it up proper  :dremel:
Re: Knocking one off the list ,,, Tapping attachment
« Reply #1 on: December 05, 2010, 03:07:50 PM »
Very nice Rob.
I was going to ask about it being square and perpendicular, but I think you answered it for me.
What did you weld it with?
Offline trevoratxtal
« Reply #2 on: December 05, 2010, 03:12:43 PM »
Nice one!
 but does it not interfere with the table rack on the support column ?
I did wonder how you would keep the two bored bushes parallel, but see at the end you had allowed for it, with stress relief then finish boring.
I am a great believer where possible to prefab with the welder, I like welding as well as turning.
As I said nice one, many thanks for the pics. :nrocks:
Trev
« Reply #3 on: December 05, 2010, 03:33:27 PM »
Hi Eric  :thumbup:
Just zapped it with my MIG welder  :zap: :dremel: .
Trev ,,,,,,,,, it goes  here  :D
« Reply #4 on: December 05, 2010, 03:52:29 PM »
Hi Rob
Nice idea.. would it not be easier to make a two-piece clamp? No need to dismantle the drill M/C. Or have you discounted that idea ?
I notice some clumsy oaf has poked holes in the cross-vice....  :lol:
Dave BC
« Reply #5 on: December 05, 2010, 03:52:53 PM »
Very nice  :bow: :bow: :bow: :bow:
That weld looks a bit pourous  :D :D :D :D :D :lol: :lol: :lol: :lol: :lol:
« Reply #6 on: December 05, 2010, 04:01:14 PM »
Not porous John, bit of fag-ash in it for reinforcing ...  :lol:
Dave BC
« Reply #7 on: December 05, 2010, 04:04:44 PM »
Hi Rob
Dave BC
Dave ,,,,,,,,,,  i will sharp remove the head ,,, well this lanky bloke i no will  :poke: John  :lol: :lol:  him taller than me  ::)
Hole'ssssssss,,,,,, wonder  who did that  :coffee:   :lol: :lol: :lol:
« Reply #8 on: December 05, 2010, 04:04:52 PM »
I do like a nice weld  :bow: :bow: :bow: :bow:
« Reply #9 on: December 05, 2010, 04:14:13 PM »
[/quote]
[/quote]
Yeah .... I did wonder .... but not for long .... :lol:
Dave BC
Offline Jonny
« Reply #10 on: December 05, 2010, 05:31:34 PM »
Take no notice of them, i would have tacked it to the table :headbang:
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #11 on: December 05, 2010, 06:27:01 PM »
Crikey.. do you think it will be sturdy enough, Rob?  Looks like a con-rod for the QE-2!
Guess it will be okay if you are only tapping small holes, like 1"-8 tpi.  If it's not stout enough
you could always put a platter on it for a swing-out hors d oeuvres server.
 :lol:
You go, Mister!  (and I didn't see no stinkin' holes..)
« Last Edit: December 05, 2010, 06:29:45 PM by Dean W »
Dean W.
Shop Projects:
« Reply #12 on: December 05, 2010, 06:58:40 PM »
Chewing gum by the looks of it.......................
Offline scrapman
« Reply #13 on: December 05, 2010, 07:22:41 PM »
Looking good so far Rob :thumbup:
Ray.
« Reply #14 on: December 06, 2010, 11:50:49 AM »
cheers lads  :lol: :lol:
Rob  :dremel:
« Reply #15 on: December 06, 2010, 03:33:30 PM »
Thought it was still under engineered for 14 BA   so i welded some extra bits on  :lol: :lol:
Into the furnace for a bit of a warm up ,,,
it can stay there for now,,,,, until tomorrow to cool down slowly and normalize  stress relief :coffee:
« Last Edit: December 07, 2010, 10:13:44 AM by Rob.Wilson »
Offline Blade
« Reply #16 on: December 06, 2010, 03:51:56 PM »
That is coming out very nice!
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #17 on: December 06, 2010, 04:08:59 PM »
 :D :D  Great going Rob  :bow: :bow:
 :beer: Good to see you got the shop defrosted enough to get back in there  :thumbup:
 :ddb: :ddb:  With the furnace started, things should heat up a whole lot more  :lol: :lol: :lol:
 :poke: :poke: Are you going to beef up the ped/drill's column and base to cope with the forces of those 14BAs ?  :doh: :lol: :lol: :lol: :lol:
Cracking job as usual mate  :thumbup: :bow: :bow: :bow:
Kind regards, Arnold
« Reply #18 on: December 06, 2010, 04:18:53 PM »
It would be a good idea to make 2
One for each side to stop it from tipping over :D :D :D :D :D :D
Offline Artie
« Reply #19 on: December 07, 2010, 05:28:45 AM »
oh...all de funny mens....... mate, looks great.... if a tad over engineered.... jesus bloke! How large are ya gonna tap?  :doh:
As always the stuff coming R W Engine Works is first rate.... you do keep the bar right up there fella.... great work.... :thumbup:
« Reply #20 on: December 07, 2010, 06:23:27 AM »
Looks like it's going to be a really useful piece of kit. The arm is pretty long, and the beefiness will certainly give it rigidity. So, unlike many puny tapping stands, you will be able to tap holes a long way in from the edge of the material. Great job.
« Reply #21 on: December 07, 2010, 07:01:51 AM »
Looks spot on Rob. Could you explain why it goes in to the furnace?
« Reply #22 on: December 07, 2010, 08:36:31 AM »
Top notch engineering Rob!  :thumbup:
Can you bring a little of that heat down here, for my shop? Getting just a little bored with looking at wallpaper/ tele etc.....  :bang:
« Reply #23 on: December 07, 2010, 10:37:12 AM »
Hi Chris
The part was stuck in the furnace so that i could get rid of any internal stresses in the welded part that may have built up due to welding.
Over time the internal stresses can cause the part to move ,, they can also come out when machining operations are carried out .Just like when you machine more off one side of length of bright mild steel flat bar
So it was placed in the furnace brought up to heat and left to soak a heat for 1/2 an hour (rule of thumb for soak time is 1 hour per inch of thickness ) then left to cool down very slowly . :med: :med:
« Reply #24 on: December 07, 2010, 12:56:34 PM »
Hi Lads ,,,,,,,,,,,, :lol: :lol: :lol: :lol: :lol: your comments are killing me  :lol: :lol: :lol: :lol: :lol: :beer:
Well its cooled down now and i have given it a quick blast to remove the black scale ,, some shots of it clean with a couple of every day shop tools in for scale  ::)
I will start machining it the morn (tomorrow)
David :    furnace is to well insulated ,,, you have to get in it to feel the heat  :D
Rob  :dremel:
« Last Edit: December 07, 2010, 01:05:20 PM by Rob.Wilson »
