Author Topic: Bowling ball engraving vise  (Read 39781 times)
Offline Powder Keg
  • Machinist Extraordinaire
« on: October 10, 2011, 08:30:30 PM »
I decided it's time to build me an engraving vise. This had to be done on the cheep! I looked around my shop and came up with a blue bowling ball and a Harbor freight vise. I spent a good part of my free time today trying to come up with a easy way to cut off a slice of this ball on my bandsaw.
I ended up just strapping it to a board with a ratchet strap.
It worked perfect!!! I cut off what looked like the right amount.
Bolted on a cheep drill press vise I had lying around and presto-chango!!!
I have a fancy engraving vise. I still need to find a bigger doughnut for it to sit on. But I think it will work out great!!!
Thanks for watching,
~Wes~
Wesley P
Offline fixerup
Re: Bowling ball engraving vise
« Reply #1 on: October 10, 2011, 09:16:51 PM »
Great re-use project!
That ball will provide a nice pivot point and will be heavy  enough for stability. I started looking for a bowling ball  :beer:
Offline PTsideshow
« Reply #2 on: October 10, 2011, 09:26:54 PM »
Here is a simpler version lighter duty if you will
It is one of the Harbor freight swivel vise with the suction or clamp base. I also have an aluminum natural finish one from our US aldi's version.
I just enlarged the one hole to slip press fit the vise shaft.
You can put the inner tube in the tire and adjust the air pressure to make it easier to move the tire.
That is also one of the HF wheel/tire 10" size with the wheel removed.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline Pete49
« Reply #3 on: October 10, 2011, 09:44:31 PM »
Mr Powder you never cease to surprise with your cheap and 'out of left field' ideas.  :smart: Don't stop as many of us like that method and helps us to think 'outside of the square' as it were. :doh:
« Reply #4 on: October 11, 2011, 02:25:13 AM »
Great thinking Wes!  :clap: :clap: :thumbup:
I've never seen such a simple/ sensible/ logical, handworking set up before.......  :bow:
Offline Powder Keg
« Reply #5 on: October 11, 2011, 07:01:26 PM »
Thanks for the compliments. It's nothing that hasn't been done before. I just showed how I made mine. I found pictures on the internet and went for it. I'm making some pin jaws so I can hold irregular stuff as well. Pictures when they are done.
~Wes~
Wesley P
Offline Powder Keg
« Reply #6 on: October 30, 2011, 05:40:53 PM »
I finally got back out into my shop! We had our sewer line quit working on us and I couldn't afford to have it fixed. So I ended up doing it myself, with the help of some good friends. What a job!!!
I made some pin jaws and pins for my crappy vise. I also turned up a base out of a scrap piece of tube.
Here it is all done. I'm happy with my results:o)
Later,
~Wes~
Wesley P
Offline Henning
  • Country: no
  • All the kit and no clue!
« Reply #7 on: November 01, 2011, 05:07:03 PM »
That is a fantastic recycling project!
Well done!  :headbang:
Henning
