Author Topic: My little Demon so far.  (Read 54924 times)
Offline Doc
    • My Youtube Channel
Re: My little Demon so far.
« Reply #50 on: February 06, 2016, 08:29:03 PM »
Thanks Andrew I pretty much napped on and off all day!  :Doh:
I don't know much about Fusion 360 but I do know Catia and NX pretty good I use them at work.
George
Offline Doc
« Reply #51 on: February 14, 2016, 10:52:23 AM »
Well I finally made it out to the shop yesterday and did a little work on the carbs. I didn't feel up to it but I forced myself to get out there.
  Today I hope to get some time in this afternoon I do have to go move some snow but not a whole lot didn't get nearly what they were predicting. I really don't mind moving snow actually find it fun. I put in the vid my fav winter toy and you can see why I don't mind it.
  Anyway carbs are about done just the needles and the linkage left to do.
George
Offline Doc
« Reply #52 on: February 15, 2016, 06:20:04 PM »
Ok another vid drilling and mounting to manifold. Did this Sunday afternoon not going to make it out there today. I did get primer and paint for the one I'm going to paint.
George
Offline Doc
« Reply #53 on: February 18, 2016, 09:02:46 PM »
Haven't gotten out to the shop much did do a little lathe work but not a whole lot I'll get some time out there on Saturday. I did do a short little video power tapping on the lathe with a 4-40 tap at 1400 rpm.
George
Offline Doc
« Reply #54 on: February 20, 2016, 07:06:25 PM »
George
Offline Doc
« Reply #55 on: February 25, 2016, 09:36:47 PM »
And here is a video of the needles being made. Along with soldering the needle into the screw.
George
Offline Doc
« Reply #56 on: February 26, 2016, 09:54:50 PM »
Ok carb linkage arms done next will be the air cleaner pan and cover.
George
« Reply #57 on: February 27, 2016, 06:09:48 AM »
George - although its quiet in here, just to say thanks for keeping posting; this thread is heading for six thousand views!  I think most MadModders are, like me, impressed (and I for one can't offer any meaningful comment other than wow!); enjoying you taking us along for the ride (and looking forward to hearing the engine!) so thanks again for recording/editing/posting.
Offline Doc
« Reply #58 on: February 28, 2016, 10:03:46 AM »
Thanks Dave!
The start of the air cleaner. Work on the bottom pan milling out of a piece square plate stock.
George
Offline Doc
« Reply #59 on: February 28, 2016, 01:22:17 PM »
Oh crap that sucks!
I need to take a breather!
George
Offline Doc
« Reply #60 on: February 28, 2016, 01:39:13 PM »
 That happened yesterday if I get time today I will go into salvage mode and see if I can save it.
That's not how to do it!  :'(   :doh:
George
Offline Doc
« Reply #61 on: March 01, 2016, 04:27:36 PM »
Ok did get the part salvaged and did the second one also. Now I need to start on the air cleaner covers hopefully no more excitement for awhile!
George
Offline Doc
« Reply #62 on: March 01, 2016, 10:08:28 PM »
Well got the top covers done need to do some clean up on them yet.
George
Offline Doc
« Reply #63 on: March 19, 2016, 08:14:29 PM »
Haven't been out in the shop for awhile but made it out there today for a little bit. I primed and painted the block and oil pan in a little cardboard paint booth I threw together.
George
Offline Doc
« Reply #64 on: March 20, 2016, 09:07:26 PM »
Ok worked a little on the cam I cut off the indicator dia on the end and then I pressed on the bevel gear and got the bearing installed. So it's ready to be put in place and set when I get things put together that far.
  I have a few end mills to sharpen before the weather gets nice and I head outside. Plus I want to make a few carbide boring bars. I mat set the camera up and show the whole process and my set up for sharpening. I'm going to attempt some small end mills.
George
Offline Doc
« Reply #65 on: March 24, 2016, 08:11:02 PM »
Hmmmmm  :scratch: seems like the gremlin has visited again. I was going to set up the cam and the little mounting posts have come up missing for both engines.   :bang: So I need to make them again I have searched with no luck again!
George
Offline Doc
« Reply #66 on: March 26, 2016, 07:35:12 PM »
Well went out and did a little in the shop this morning and turned up the cam idle gear pegs. I was messing around with mounting camera in different places.
George
Offline Doc
« Reply #67 on: March 27, 2016, 05:47:37 PM »
  Well she was cool outside this morning again plus wind was blowing felt pretty cold out so I spent some time and put gears in place. I need to go and find Steve's video on setting the cam up and get a degree wheel made up and get it set.
  Plus I want get some dull end mills sharpened (I may video that from start to finish).
Anyway got the gears in place and they seem to work fairly smooth so once I get the cam set then I'll need to go back and cut out some gaskets.
It got pretty nice out side this afternoon but got windy and cool late in the afternoon and windy so I went back out in the shop and cleaned a few things up and printed out a degree wheel and now I'll glue it to a piece of plexi glass and band saw it out plus make a hub that I can mount it to the crank. (or I could run down town and but a round compass) na that wouldn't be as much fun as making your own. Hahaha
George
Offline Doc
« Reply #68 on: March 29, 2016, 09:51:57 PM »
Ok make up a degree wheel (compass) to set the cam.
I used an old computer cd.
George
Offline Doc
« Reply #69 on: April 03, 2016, 11:12:37 AM »
I did a little on the engine build today I had been putting off the dampener pulley because I didn't have any 1.0 dia aluminum stock I do have quite a bit of 1.625 so I finally decided to go ahead and turn a chunk of it down. So I got them done yesterday now I'll attempt setting the cam if I make it out there today.
George
Offline Doc
« Reply #70 on: April 03, 2016, 09:09:33 PM »
Well I have gotten the cam gear clocked and I may try my gasket cutting plan. I was going to set up and sharpen some end mills today but weather got nice and I worked outside this afternoon.
George
« Reply #71 on: April 04, 2016, 04:09:54 AM »
George it must be the same for a full size engine , lots of info on the net http://www.centuryperformance.com/valve-adjustment-procedure.html or ask a mecanic .
Offline Doc
« Reply #72 on: April 07, 2016, 08:12:44 PM »
Haven't done to much on the build the last few days. I did get some end mills sharpened. Messed around with the rockers getting ready to assemble them. I have the ones the plan called out but I changed them a bit  ;).
George
Offline Doc
« Reply #73 on: April 09, 2016, 02:20:02 PM »
Was going to mount rocker system (rails and rockers) and realized I didn't drill the mounting holes yet for them. SO dug out the fixture and created a program to drill them. I just need to find time to get out in the shop and do it. Anyway once I get that done I can get them mounted and size up the push rods. I keep meaning to get started on the gaskets but still haven't. Anyway very windy here today so I may make it out this evening for awhile.
George
Offline Doc
« Reply #74 on: April 10, 2016, 08:07:11 PM »
 Here is a video from yesterday. Today didn't make it to the shop. I will get the rockers mounted and get started on gaskets I hope next weekend. I did drill all 4 heads I figured why not do them all as it doesn't effect anything if I go with the original rockers. I did set down and do some deburing  and set up to cut down the area for the lock nut. Anyway I am getting closer every time I spend time in the shop so thas a good thing (I think) .
George
