Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Project Logs
Home
Help
Search
Login
Register
Gallery, Projects and General
Oooops!
Gear cutting
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Gear cutting (Read 12350 times)
chipenter
Hero Member
Country:
Gear cutting
on:
September 09, 2013, 10:43:28 AM »
Made a 20 DP 20 tooth gear today , there wasn't enough metal to cut the key way and it split , guess I should have cut the key way first , the cast iron came from a dumbbell so something had to go wrong .
Logged
awemawson
Global Moderator
Hero Member
Country:
East Sussex, UK
Re: Gear cutting
Reply #1 on:
September 09, 2013, 11:03:01 AM »
Bad luck - how frustrating.
There's not a lot of meat left between the dedendum and the keyway, can the keyway be reduced in depth?
Logged
chipenter
Hero Member
Country:
Re: Gear cutting
Reply #2 on:
September 09, 2013, 11:10:21 AM »
Thank Andrew I will try the fit before I cut the next one , I want a 20 tooth one as well my have to make that from steel .
Logged
Meldonmech
Hero Member
Re: Gear cutting
Reply #3 on:
September 09, 2013, 12:53:17 PM »
Hi Chip
Can the size of the shaft be reduced, it looks large in comparison to your gear?
Logged
Pete.
Hero Member
Country:
Re: Gear cutting
Reply #4 on:
September 09, 2013, 01:10:34 PM »
What kind of tool are you cutting the teeth with? Looks like you have a burr or it's dragging the back edge of the tool and carving a small step in one side of every tooth.
Crack looks like it's due to built-up stresses in the cast iron. I sometimes have to cut out cast iron tunnel sections and I've had quite a few split with a loud bang half way through cutting.
Logged
chipenter
Hero Member
Country:
Re: Gear cutting
Reply #5 on:
September 09, 2013, 02:45:04 PM »
It was a home made cutter using an and mill to get the profile , I split the gear using a standard broach knocking it though with a mallet , I have since successfully made another gear cutting the key way first .
Logged
ALB
Jr. Member
Country:
Aberdeen
Re: Gear cutting
Reply #6 on:
September 11, 2013, 02:38:58 PM »
Hello All,
I made this little gear cutter out of an old boss from a lawn mower shaft
Then made a 50 tooth gear out of nylon round this was my first ever gear cut Well pleased with the result
Next is to try and make one out of steel
Alb
Logged
Don't put all your eggs in one basket
awemawson
Global Moderator
Hero Member
Country:
East Sussex, UK
Re: Gear cutting
Reply #7 on:
September 11, 2013, 02:47:42 PM »
Difficult to tell from your pictures, but is that an involute form? It looks more triangular but maybe that's the lighting.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Oooops!
Gear cutting
