Author Topic: Tapping Stand  (Read 58243 times)
Re: Tapping Stand
« Reply #25 on: December 23, 2013, 07:18:27 AM »
Good going Dan you've nearly got all the parts done.  Nice looking base. .
Offline Dan The Man
  • How did they build the first Lathe????
Re: Tapping Stand
« Reply #26 on: December 23, 2013, 07:34:23 AM »
Tapping stand or Lathe Only ?
Offline Dan The Man
Re: Tapping Stand
« Reply #27 on: December 23, 2013, 02:39:44 PM »
Back to work on the tapping stand
Right, so instead of using the rack and pinion we used the measurer on the front to support the chuck.  We used the bracket from the shield but first taking the Perspex off .  After we reassembled the spring mechanism on the front we realised that the spring was too strong so we are getting a new one.  That is easier to push from above.
« Last Edit: December 24, 2013, 01:49:19 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #28 on: December 23, 2013, 02:41:32 PM »
Be careful when taking out the rack and pinion however.  :doh:  :doh:  :doh:
« Last Edit: December 24, 2013, 01:50:48 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #29 on: December 23, 2013, 02:52:24 PM »
Now instead of turning our own part that drives the tap, we used the old pulley, but first we needed to adapt it by sawing off one of the grooves. We then drilled a 6mm hole and inserted a bar in the top, so you can push down and turn the tap with more force. Here is the concept in an image.  :smart: . BTW to secure the pulley back on the shaft we reused the little bolt in the side of the pulley.
« Last Edit: December 24, 2013, 01:51:48 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #30 on: December 23, 2013, 02:58:35 PM »
The base was a little rusty so I got some wire wool out and started scrubbing away, you might be able to see on the photo where I have cleaned :Spotless ??:
« Last Edit: December 24, 2013, 01:54:27 AM by dsquire »
Offline Dan The Man
Re: Tapping Stand
« Reply #31 on: December 23, 2013, 03:13:47 PM »
End of day 2 :(
Offline Dan The Man
Re: Tapping Stand
« Reply #32 on: December 24, 2013, 04:20:09 AM »
Start of day 3 :)
Offline Dan The Man
Re: Tapping Stand
« Reply #33 on: December 24, 2013, 07:22:23 AM »
We then drilled a 6mm hole in the pulley
<a href="http://i1058.photobucket.com/albums/t405/Toptracks3719/004.jpg" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://i1058.photobucket.com/albums/t405/Toptracks3719/004.jpg</a>
After we found 6mm for it.  Sadly, it was slightly too short we then put on the handels off the old drill for looks
<a href="http://i1058.photobucket.com/albums/t405/Toptracks3719/007.jpg" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://i1058.photobucket.com/albums/t405/Toptracks3719/007.jpg</a>
Offline Dan The Man
Re: Tapping Stand
« Reply #34 on: December 24, 2013, 07:32:43 AM »
Production stopped because of this thing called Christmas  :D good progress so far
Offline Dan The Man
Re: Tapping Stand
« Reply #35 on: December 27, 2013, 08:07:24 AM »
Back to Work!!
We turned down the diameter on the bar to allow us to thread it <a href="http://i1058.photobucket.com/albums/t405/Toptracks3719/002.jpg" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://i1058.photobucket.com/albums/t405/Toptracks3719/002.jpg</a>.  Then we Araldited the small bar into 2 bigger bars then screwed on the handles.
<a href="http://i1058.photobucket.com/albums/t405/Toptracks3719/004-1.jpg" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://i1058.photobucket.com/albums/t405/Toptracks3719/004-1.jpg</a>
Right remember how we needed a spring we got one out of a cracker and it is the right size and tension.  but first I learnt the party trick.
<a href="http://i1058.photobucket.com/albums/t405/Toptracks3719/007-1.jpg" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://i1058.photobucket.com/albums/t405/Toptracks3719/007-1.jpg</a>
2 minor jobs to complete the project.
Re: Tapping Stand
« Reply #36 on: December 27, 2013, 08:31:44 AM »
Back to Work!!
We turned down the diameter on the bar to allow us to thread it http://i1058.photobucket.com/albums/t405/Toptracks3719/002.jpgTapping Stand.  Then we Araldited the small bar into 2 bigger bars then screwed on the handles.
http://i1058.photobucket.com/albums/t405/Toptracks3719/004-1.jpgTapping Stand
http://i1058.photobucket.com/albums/t405/Toptracks3719/007-1.jpgTapping Stand
Hi Dan The Man,
I don't know if anyone else can see the images but I can't and I think you've clicked on the wrong button to insert an image. You need to click on the 4th button from the left on the bottom row (looks like a tiny Mona Lisa) which will put "img" and "/img" (both in square brackets) in the text and then you paste the image url in between.
Hope this helps.
Offline Dan The Man
Re: Tapping Stand
« Reply #37 on: December 28, 2013, 03:18:32 PM »
did it happen for post 33 and Dose it happen on anyone else's? its normal on mine
Re: Tapping Stand
« Reply #38 on: December 28, 2013, 03:33:57 PM »
Reply 33 is the same for me - no images - just rectangles with nothing in them but a red cross in the corner. I can't speak for anyone else but I just tried looking at your posts on my wife's iPad and can't see the images on that either.
Cheers.
Re: Tapping Stand
« Reply #39 on: December 28, 2013, 04:33:22 PM »
Cheers.
Post 33 looks OK to me, two piccys ..
Re: Tapping Stand
« Reply #40 on: December 28, 2013, 04:48:18 PM »
Hi again,
As others seem to be able to see them I looked using Google Chrome (I usually use Internet Explorer) and I could see the images! They were very small however - is that how you intended them to be?
Cheers.
Offline Dan The Man
Re: Tapping Stand
« Reply #41 on: December 29, 2013, 03:57:18 AM »
I was using the 2nd tab across (flash)  it may not work for you if you have a outdated version of flash player. I will try to put one of the pics in this post
This time have put it in insert pic. Thank you for your help   :D
Offline Dan The Man
Re: Tapping Stand
« Reply #42 on: December 31, 2013, 11:20:29 AM »
Now to finish we put a plastic handle on the top that can be used to apply pressure when tapping.
http://i1058.photobucket.com/albums/t405/Toptracks3719/002-1.jpgTapping Stand
Then it was done, we may later paint it but not for now.  Thanks for the good support and  :mmr: :headbang:
Offline Dan The Man
Re: Tapping Stand
« Reply #43 on: December 31, 2013, 11:21:39 AM »
Project Finished
Offline ivansgarage
    • Ivan's Garage
Re: Tapping Stand
« Reply #44 on: January 01, 2014, 12:12:28 PM »
Good Job::
Am I missing something?  What are you using to hold the taps?
I all ways dreamed about finding a four jaw 1/2 inch drill chuck.
Ivan
Ivan's Garage
Web Site  http://ivanbennett.com
Forum  http://ivanbennett.com/forum
Offline drmico60
    • mikesworkshop
Re: Tapping Stand
« Reply #45 on: January 01, 2014, 12:17:48 PM »
Good Job::
Ivan
I had the same dream. I had to make my own 4 jaw tap chuck, see:
http://mikesworkshop.weebly.com/improved-chuck-for-taps.html
Mike
Offline ivansgarage
    • Ivan's Garage
Re: Tapping Stand
« Reply #46 on: January 01, 2014, 04:39:38 PM »
Good Job::
Ivan
Mike
Hey Mike Thanks for that link, looks real nice, gona have to make me one.
Just what I need another fricken project.  :loco:
Ivan's Garage
