Gallery, Projects and General => Neat Stuff => Topic started by: smiffy on September 19, 2016, 04:26:52 AM
https://techcrunch.com/2016/09/12/wazer-good-idea/ At the price mentioned this could revolutionise the home workshop
Apt name for something that can piss all over the place.
On another forum it was reckoned it used masses of abrasive so would be cheaper to farm jobs out :(
I calculated about $20 an hour in abrasive alone for a 1.5mm kerf. No service life figures for nozzle and pump etc so hard to get a real cost of ownership.
Shame, as I like the concept.
I am sure it will improve with further development and I can see its uses . Just look at how 3D printing has improved and become available at a reasonable cost
To me water jet cutter would be far more interesting than any 3D printer. Real water jet cutters are expensive to buy and own. Cheaper alternative would be very nice.
3D printer I might get if there is one on that produces lost wax type patterns for investment casting. Total cost should be reasonably low.
And here you can buy it. =)
https://www.kickstarter.com/projects/1294137530/the-first-desktop-waterjet-cutter
All the SLA printers will do that.
interesting. the waterjet at the works has a 10kW motor and a 3800bar pump it'll cut 4" steel but is not the quickest thing you'll ever see. I wonder just how useful this little thing really is????
Aren't the abrasives re-usable? [to some extent?]
"Aren't the abrasives re-usable? [to some extent?]"
Not on the commercial systems. The garnet is blo wn onto the nozzles dry or it would just clog.
Believe it or not, the water does most of the cutting , the garnet helps the keep the cutting face rough so the water can do its job.
Thanks for that Bill
I always wondered which had more effect.
Regards Ian
"...it'll cut 4" steel but is not the quickest thing you'll ever see..."
You haven't seen me cut 4" steel with my hacksaw. I'd be skiving off for a break every 3 minutes. Your water jet must be fantastic.
Mark
