Gallery, Projects and General => How do I?? => Topic started by: Chuck in E. TN on July 31, 2016, 03:37:50 PM
While researching for my Webster build, I came across dbvandy's build thread herehttp://madmodder.net/index.php?topic=4413.0 (http://madmodder.net/index.php?topic=4413.0). He used a weedeater coil and flywheel for his Webster ignition. I happen to have a couple flywheels and ignition coils from a troy-bilt I had problems with.
Does anyone know what the taper is in the flywheel or on the crank for a weedeater? I can't get the crank out of the junked troy-bilt and don't have anything to measure the taperin the flywheel.
I have posted a question in dbvandy's thread, and sent him a pm but nothing back yet.
Chuck
Drop a ball bearing into the taper and measure the depth from the ball to the face of the 'hole'. Then drop a larger one in and measure that. Draw it up in CAD, draw lines tangent to both circles and use the measure tool to get the included angle.
I don't have CAD, nor the skills to use it. Heck, don't even have any ball bearings. I do have a couple more dead weed eaters out in the shed. Guess I'll strip one or both to see if the flywheel is the same, and the crank can be 're-used'.
Thanks anyway, Pete.
Chuck
I guess the answer is to chuck up a piece of scrap aluminium and cut a taper with the compound. Blue up the inside taper and keep adjusting the compound until you get a good print, then figure a way to measure the shaft you made.
I have one of these and it's very handy, should do the trick:
http://r.ebay.com/cwm3sx
Pete,
That would be the cat's meow for measuring the taper on the exposed part of the crank! now to find out what it will cost to ship to the US!
Thanks.
Chuck
