The Shop => Composites & Plastics => Topic started by: John Rudd on June 18, 2016, 05:51:52 AM
Title: Fan
Post by: John Rudd on June 18, 2016, 05:51:52 AM
So,
I've attempted several times now to make a replacement cooling fan for my drill that I'm refurbishing....(in fact I have somewhat of a collection now amounting to around 18 of them...different models of course...)
The last effort resulted in me missing an index point on the rt and resulting yet another failure...
So I'm thinking, a metal mold machined frim aluminium, with slots cut and a recess bored for a boss to cast a fan using some form of plastic or fibreglass/resin compound...
I need the process to be repeatable as I need six of these fans..... :scratch:
Any thoughts on a suitable casting material?
Title: Re: Fan
Post by: RobWilson on June 18, 2016, 08:19:16 AM
Hi John
What about sticking the broken motor fan back together and taking a silicon mould from that , then make resin castings from that .
Just a thought mate .
PS I went for option two ,,,,,,,,,,,,,,,, curry and bear   :beer:
Title: Re: Fan
Post by: Bluechip on June 18, 2016, 08:54:08 AM
Err ... you can buy the damn things. Had them from here, generic, fairly easy to modify.
Shipping took about a week or so IIRC.
http://www.ebay.co.uk/itm/Plastic-Impeller-Motor-Fan-Blade-10mm-x-84mm-x-23mm-Gray/291633922728?_trksid=p2047675.c100008.m2219&_trkparms=aid%3D444000%26algo%3DSOI.DEFAULT%26ao%3D1%26asc%3D37255%26meid%3D44d1157dfd9e4d5bae4166ad9cd1f191%26pid%3D100008%26rk%3D2%26rkt%3D6%26sd%3D291601424207
Have a shufti, see if you can find one near enough to modify.
PS What flavour was the bear ???  Starter or Pudding course ???  We need to know !!!
Title: Re: Fan
Post by: John Rudd on June 18, 2016, 09:57:54 AM
Thanks Dave, had a look but the larger diameter ones are difficult to mod becausecthe blade tips are unsupported...I think they will just rip if I try to machine it...
Title: Re: Fan
Post by: Bluechip on June 18, 2016, 10:32:38 AM
Machine ???  Mine were polypropylene I think.
Machined the blades with  'state of the art' multi-axis Gilbow tinsnips ..  :thumbup:
A bit primitive down here you know. Almost qualify to be Geordies ..  :lol:
Title: Re: Fan
Post by: John Rudd on June 18, 2016, 11:48:44 AM
'K  had another go on the mill with one more of me blank disc....
Got all the blades cut nicely, just had to clear out 'bits' in between.....swapped to a smaller cutter (3mm) going nicely when'crack' another one broken....So more scrap perspex...,
I've realised what I'm doing wrong here I think.....
As I approach the edge of the disk, the cutter seems to be forcing the disc down...Now its only supported in the centre on the mandrel I made for it...so I think it needs a disc of the same diameter at least to offer support to the edges.... :scratch:
Is my theory flawed in some way or should I just go back to the nursing home?  :lol:
Anyway here's a foto of what I need to make.....
Title: Re: Fan
Post by: appletree on June 18, 2016, 01:35:40 PM
Try putting vacuum cleaner fan in google, in the good old days they were aluminium. Not sure what you are after or how efficient it needs to be but a simple disc with blades rivetted on would make quite a draft. It never ceases to amaze me what industry can produce when needed often very simple (cheap and nasty  on the face of it) but reliable and cost effective.
Title: Re: Fan
Post by: efrench on June 18, 2016, 02:34:38 PM
Make a cut, put in a backer piece.  Continue until all blades are cut.
or
Get a 3d printer  :wave:
Title: Re: Fan
Post by: John Rudd on June 18, 2016, 03:04:00 PM
Care to elabborate please? Pictures are good :lol:
Title: Re: Fan
Post by: efrench on June 18, 2016, 05:15:06 PM
(http://img.photobucket.com/albums/v649/etfrench/Misc/fanMill_zpsghodsu3o.jpg)
Title: Re: Fan
Post by: John Rudd on June 20, 2016, 11:02:58 AM
Got a bit more done today....one new fan machined from solid....a lot of hard work.... :doh:
Sadly I'm inclined to discard this one, making them out of metal is just too heavy....
Anyone seen any fibreglass filled resin that I can mix with hardner and mold into a fan?
Title: Re: Fan
Post by: seadog on June 20, 2016, 12:27:24 PM
This is quite informative John - https://davidneat.wordpress.com/materials/casting/fillers-for-resin/common-fillers-for-resin-casting/ (https://davidneat.wordpress.com/materials/casting/fillers-for-resin/common-fillers-for-resin-casting/)
Title: Re: Fan
Post by: RobWilson on June 20, 2016, 12:31:52 PM
Good going John  :thumbup:
Machine up a mould and purchase Joules fine plastic injection moulding machine ,sorted  :)
Title: Re: Fan
Post by: awemawson on June 20, 2016, 12:34:36 PM
In the absence of a 3D printer my approach would be to glue up the original, or your best copy, fettle it to a good finish with car bodywork filler, and take an impression in Vynamold :
http://www.mbfg.co.uk/vinamold.html
Release from Vynamold and pour in resin of your choice, no doubt with a filler added.
If you form a decently thick edge to your Vynamold it will hold it's form yet be flexible enough to release the pattern. I still have a few vynamold forms I made over ten years ago and they would be fine for resin casting even now.
(I was lost wax casting iron in sodium silicate bonded sand)
Title: Re: Fan
Post by: Joules on June 20, 2016, 02:34:26 PM
LOL, 3D printed fan's.......
Another Vynamold user here, usually taking impressions off plaster of paris than machining up a part to take an impression....    I have a wee bit of experience with fans, but mine usually ran very hot except this one where I slipped with a Dremel cutoff wheel.  Twice !!!  at 90 degrees...
Title: Re: Fan
Post by: DMIOM on June 22, 2016, 03:56:34 AM
 :bow:  :bow:  :bow:
Title: Re: Fan
Post by: RotarySMP on June 22, 2016, 09:17:03 AM
Wow Joules. Do you have a thread somewhere with more info and photos of making that turboprop?
Mark
Title: Re: Fan
Post by: Joules on June 22, 2016, 10:05:26 AM
Sorry Mark, it was a commercial unit.  I was fortunate enough to have the opportunity to work for the UK outfit that builds miniature gas turbines.  My favourite engines where the gas generators used in the turboprop and helicopter variants.
Title: Re: Fan
Post by: John Rudd on June 22, 2016, 11:46:50 AM
Joules,
Would that have been Wren Turbines ?
