Recent Posts
Pages: [1] 2 3 ... 10
1
The Water Cooler / Re: How do you go about starting a small manufacturing business?
« Last post by Rester on November 24, 2026, 09:28:53 AM »
I?d start with one complete instrument and treat it as a proper cost and safety test, not just a prototype. Check zoning, dust and noise rules, product liability insurance, electrical safety, and whether your insurer requires documented training. Even working alone, safe procedures matter because accidents and defective products can still cost you badly.
2
New from Old / Re: The Sequel - Oh Blimey I bought a CNC Lathe (Beaver TC 20)
« Last post by awemawson on November 24, 2026, 05:50:36 AM »
OK let's try a different approach - remove the bearing directly. it's a:
                  INA-X-life NK 80/35  Slovakia 095 N0803
According to it's markings which resolutely refused to be photographed ! Now somewhere deep in the depths I have a 'Blind Bearing Removal Kit' - a/ can I find it and b/ will it work.
Yes found it:
Arh - but will it work? No not a chance, it's the best part of an order of magnitude too small  :bang:
So more thinking needed.
3
« Last post by awemawson on November 23, 2026, 08:55:12 AM »
Good theory but even stripped down to this extent I have great difficulty moving it about on the bench. The 'rotation' to get the front bearing sort of upright involved long levers. It's quite amazingly heavy  :bugeye:
I did calculate the (removed) tool disk at between 80 and 90 kg - considering that it mounted up to 45 kg of tooling no wonder it needs a powerful servo drive. It's all rather massively constructed.
4
« Last post by John Rudd on November 22, 2026, 11:04:45 AM »
kitchen oven when the missus aint home... :clap: :clap:
5
« Last post by awemawson on November 22, 2026, 08:43:36 AM »
I did try John but it's a big lump of metal. I can get the Curvic coupling up to about 110 Deg C in local places but that's about it due to it's heat sink properties.
I don't suppose that the coupling was bonded as well as bolted - may have been maybe to avoid fretting but I have little hope of getting it up to Loctite releasing temperatures that need to be north of 200 degC.
6
« Last post by John Rudd on November 22, 2026, 07:49:40 AM »
A bit of heat mebbe? :dremel:
7
« Last post by awemawson on November 22, 2026, 07:11:06 AM »
Now this front curvic coupling piece is stretching me to the limit. I want to get it off to see if anything behind it is retaining that roller bearing that can be seen in the picture.
There is a ring of six M8 Allen Cap Screws that obviously are the main holding for it, but it won't come off. There are two M8 tapped holes that I had assumed were to push the curvic part off the main casting. It was all rather mucky so this morning I've cleaned it up a bit and cleared the threads in the two supposed pusher hole with a bottoming tap.
Inserting a grade 12.8 bolt in both threaded holes and exerting as much torque as I felt was their limit - still no movement.
This is getting silly! There are three other 6mm  holes which again I cleaned out with an M6 tap and tried maximum torque but no movement what so ever.
Off to lick my wounds!
8
Member Videos / Re: USS Monitor Building Project Video
« Last post by Rich Carlstedt on November 21, 2026, 08:53:55 PM »
Well The 4 Videos were released and her is the one that details USS Monitors Steam Engine operation
I think the Mariners Museum staff did a good job with the visual display for a very unusual engine
https://duckduckgo.com/?q=Youtube+Mariners+Museum+title+%22Introduction+to+steam+engines%22&t=h_&atb=v556-1&ia=videos&iax=videos&iai=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DfWDg2P0VEnQ
This is episode 3 of the 4
If you search YouTube, I believe you have to start with "The Mariners Museum" and then USS Monitor
Rich
9
« Last post by kayzed1 on November 20, 2026, 02:57:30 PM »
When i had my TIG kit i used Hobby weld mid size bottles, can not remember the prices now but they were ok-ish for the amount i used up front cost for the bottle and set price for an exchange..
Lyn.
10
Member Videos / Re: My week this week, my workshop videos!
« Last post by hermetic on November 20, 2026, 01:13:23 PM »
Hi folks,
A short week consisting of a start on stripping the Westwood grass deck, and a selection of Antique repairs with the ever camera shy Andy! Got the deck stripped and the bearings out, and then onto antiques, mainly pistol parts and a couple of mounted bronzes. two days of productive work, they cleaning the car out on Wednesday and off to bitterly cold York on Thursday form my daughter Emilie?s Graduation ceremony in equally cold York Minster! All went well, Stayed in York and came back Friday, and Tomorrow is Izzis birthday! Busy busy!
Video goes live at 4-00pm GMT on Saturday
Phil, in Pretty cold East Yorkshire!
