Author Topic: Toolpost holder holder  (Read 58978 times)
« on: April 13, 2009, 04:45:03 PM »
As most of you know, I have been rebuilding my workshop for about the last year, and now the time has come to start getting things organised.
On my lathe, I use a size T2 piston quick change toolpost (I think known as an 'Aloris' type in the US).
During the rebuild, I have been setting up all my toolholders to perfect centre height as they have been required, but they have been left strewn about the workshop on the nearest flat and level surface. So armed with a couple of lengths of 6mm bar given to me by the neighbour who stripped the cot down, I am finally going to get the problem sorted.
The die filer was set up with a hacksaw blade and 60 pieces of bar were cut to length in no time. 30 @ 50mm and 30 @ 40mm.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder01.jpgToolpost holder holder
Half way thru the turning of the bars. All the short ones have been done.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder02.jpgToolpost holder holder
I put a full point on one end and a feed in taper on the other. The pointy bit won't stay that way for long, I will be banging that end with a hammer, and a small flat should be formed on the end. The long ones were soon brought to the same state of machining.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder03.jpgToolpost holder holder
This bit is the experimental bit, getting all the bells and whistles sorted.
After rooting about in the back room, I found a bit of that light brown stuff, I think it is called wood. It hate the stuff with a passion, but needs must.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder04.jpgToolpost holder holder
Two of the bars were pushed tight up into the dovetails, and after a slick bit of measuring and calculation, I found the centre between the two bars.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder05.jpgToolpost holder holder
A line was drawn, and two 5.9 holes were drilled 33.5mm apart, this is to ensure that the holders slip nicely onto the bars without forcing them.
The long bar was tapped down into the hole until 40mm remained protruding, the same was done in the bottom hole with the short rod, but leaving 30mm sticking out. By having different lengths of bar, it allows the holder to be located on the top one, and that then helps guide it onto the bottom one.
This is how the holder fits on.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder06.jpgToolpost holder holder
A view from the front.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder07.jpgToolpost holder holder
So now I knew the system would work. Now to the problems that occur in use.
Depending on which side the holder is mounted onto the toolpost, sets up how the tools fit into the holder.
So what I did, was got the two stickyoutest holders with mounted tools I have, and set them side by side, give them a little clearance between each other, and found the position the next set of bars should go in.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder08.jpgToolpost holder holder
Two more pins located, nice gap, that will do me.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder09.jpgToolpost holder holder
On the last set of racks I made for my old machine holders, I did it the normal way. That is, have a single bar and hang the holders on the bar, like using a coathook.
I have set up a pic to show the problem with that system. Under certain conditions, the holders end up in the position shown, screw to screw.
As you can easily see, this new setup will allow double the number of toolholders to be hung in the same space.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder10.jpgToolpost holder holder
These are the dimensions I used with 6mm bar and T2 sized holders. If you want to try this system, you will need to work out the dimensions for your particular holders and bar.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder11.jpgToolpost holder holder
So now the system has been proven, I will be up at dawn tomorrow, funny hat on, check shirt, axe over shoulder and Monty Python's 'Lumberjack Song' pumping out of the MP3 player.
Goin' to get me some more of that 'orrid brown stuff to finish the job off.
Re: Toolpost holder holder
« Reply #1 on: April 13, 2009, 04:48:34 PM »
Great idea John. I am going to be going through my work shop in the next 6 months. This looks like a great deal!
« Reply #2 on: April 13, 2009, 04:59:35 PM »
Bogs, if you dont like that brown stuff you could instead use resin bonded cellulose.  ::)
« Reply #3 on: April 13, 2009, 05:10:54 PM »
I know all about resin bonded cellulose.
I spent hours playing about with natural and man made fabrics containing cellulose.
Eventually I could bond two pieces of paper together using nothing but pressure and heat. It ended up as biodegradeable decorative ribbon that is used for tying up your gifts and as bows on Christmas trees and wreaths.
« Last Edit: April 13, 2009, 05:13:33 PM by bogstandard »
« Reply #4 on: April 13, 2009, 06:10:23 PM »
John, if you dont like the look of wood for your tool holder holder how about offcuts of kitchen and bathroom materials?  I have quite a bit of 6mm white and it is very useful at covering up the brown stuff you are not so keen on.
« Reply #5 on: April 13, 2009, 06:16:46 PM »
That's a neat idea you have there, I guess most of us have tool holders strewn all over the place.
I can see that being copied many times over  :thumbup:
« Reply #6 on: April 13, 2009, 07:51:20 PM »
Wait until you see the finished article, later today
« Reply #7 on: April 13, 2009, 08:01:56 PM »
Hi John  :wave:
'Bout time you got to this ehh?!  :D
Works just like you described it :thumbup:
« Reply #8 on: April 13, 2009, 08:02:38 PM »
Wont it take a while for the mulitple coats of polyurethane to set? :med:
« Reply #9 on: April 13, 2009, 08:50:10 PM »
Don't be silly, this is a workshop, not a museum.
« Reply #10 on: April 13, 2009, 09:22:45 PM »
Bogs,
You've come up with another novel idea. I've seen all sorts of fancy holders for hanging those types of tool holders on, but a piece of wood and some round stock takes the cake.
Great idea. I love it. :thumbup:
Can't wait to see the finished project.  :clap:
Offline HS93
« Reply #11 on: April 14, 2009, 01:33:39 AM »
Didnt they write a song for you John
"Bogs the builder  can he do it.... YES HE CAN "
Peter
Sorry John I was bord
:ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb: :ddb:
« Last Edit: April 14, 2009, 01:48:03 AM by HS93 »
« Reply #12 on: April 14, 2009, 04:45:30 PM »
On my foraging trip this morning, turned the corner and found a load of pre cut trees cowering in one of my storage areas, so I gave the biggest one a wack with an hammer, and dragged it back to the shop.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder12.jpgToolpost holder holder
Once inside, it was dispatched humanely and was butchered to get the three limbs I required.
They were held together with a couple of coachbolts while I drilled holes all over the place.
Twenty in the top one, but I actually ended up with sixty very accurately drilled holes.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder13.jpgToolpost holder holder
Just to make sure they were dead, I wacked in 60 metal pins to the correct depth.
A couple of holes in each one will allow my trophies to hang on the wall.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder14.jpgToolpost holder holder
Up on the wall, and I found they were a perfect place to hang my toolholders on. All sorted into type and how often they are used.
So a little plastic rack underneath finished the job off, I can put all my tips and ground up tooling in that.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/holder15.jpgToolpost holder holder
I now do have to get on with a commission job, so that will be about a week before I can go searching for any more little jobs to do.
« Reply #13 on: April 14, 2009, 04:52:13 PM »
Nice work Bogster,  do you have any plans for lower levels in that corner of the 'shop?
I always seem to end up putting stuff in a corner which is never used the end result being wasted space. :scratch:
« Reply #14 on: April 14, 2009, 04:53:56 PM »
Nice neat job John that will make your time more productive
 :whip:
« Reply #15 on: April 14, 2009, 05:22:21 PM »
Thanks lads, been meaning to do this for ages. Now it is done, I feel a lot happier.
Actually nothing else can go into that corner. Just out of shot, lower down, is a set of rolling drawers reaching from the lathe front to the wall behind the lathe. Between that and the new racks is my area for changing the gears on the lathe. Under the metal collet rack is the oil filled radiator and swarf bin, so not much space left IN THAT CORNER, but I do have a couple more to work with.
There is an area above the new racks, and that is earmarked for a small rack to hold the lathe change gears and sundry items belonging to the lathe.
As you can see, I hate wasted space. In fact there are a couple of shelves going up behind the lathe for more lathe bits and my growing engine collection.
As long as I can reach it, it goes on the wall.
« Reply #16 on: April 14, 2009, 05:42:37 PM »
Ok John, understand, meanwhile I am facing some storage challenges myself especially as one workshop (the 'dirty' shop where welding and grinding happen) is severely hampered by out of control storage issues and my 'electronic' shop is almost a no go zone for the same reason. :(
« Reply #17 on: April 14, 2009, 06:13:04 PM »
That's a lot of trophies John, nice display....that'll impress the locals/visitors...... :ddb: :ddb: :ddb:
ja2on
« Reply #18 on: April 14, 2009, 06:17:48 PM »
slightly  :offtopic: John but can I ask why you have two dro's on the lathe ?
« Reply #19 on: April 14, 2009, 08:27:53 PM »
Jason,
In my quest for greater accuracy in machining parts, I fitted an extra couple of read heads. One on the compound (topslide) and another on the tailstock.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/compoundscale.jpgToolpost holder holder
http://i202.photobucket.com/albums/aa102/bogstandard_photos/tailstock6-1.jpgToolpost holder holder
http://i202.photobucket.com/albums/aa102/bogstandard_photos/readout.jpgToolpost holder holder
It takes a lot of guesswork out of machining. It works better than I ever imagined it would.
Offline usn ret
« Reply #20 on: April 15, 2009, 12:53:56 AM »
Bogs, what a novel approach, a verticle flat surface!!!! Does the same hold true that a clean desk is a sure sign of a cluttered mind = a clean and orderly shop is the sure sign of a totally messed up mind???  BTW sure looks great, but finding the tool that you are holding in your hand presents some great challenges and makes for great entertainment when friends are watching your quest to find  im your hand :doh:
Cliff :beer:
« Reply #21 on: April 15, 2009, 01:32:53 AM »
Cliff,
Anyone who has been into my shop will attest that it isn't as tidy as it looks.
My workbench usually looks like a bombsite. The vertical flat surface syndrome is a neccessity, an attempt to free up space on my benches.
Over the last year, I have given away many squids worth of tooling and equipment in the quest for an uncluttered shop, but I am losing the battle.
Offline usn ret
« Reply #22 on: April 15, 2009, 02:26:33 AM »
Bogs.  if you dont have enough room for all your tools, you need a bigger space.  On the other hand, if you have space, you dont have enough tools.  RATS :jaw: You can't get there from here :( .  A do loop.
Cliff :coffee:
« Reply #23 on: April 15, 2009, 08:52:35 AM »
Cliff :coffee:
Wrong in my case Cliff. I've got 2300sq ft. and can't find my tools.  :(
I seem to lay them down and can't find where I put them. Then the one in my hand gets laid down while I go look for the other one. Find the other one and can't remember were I laid down the first.
Ah yes I see a do loop also.  :scratch:
I'm getting  :offtopic: here. Time to take my meds. ::)
« Reply #24 on: April 15, 2009, 03:01:27 PM »
Obviously Bernd you do not have near enough tools and stuff.  A proper home workshop has barely enough room to walk around! ::)
