Author Topic: FACE PLATE WORK HOLDING AWKWARD OBJECTS  (Read 11899 times)
Offline ieezitin
« on: December 26, 2015, 07:29:02 PM »
Not my idea it came from Mr Harrold Hall. I have a project coming up that will extend the reach of my 6'' four jaw chuck  I need to hold a 6 sided object and i need it to be controlled pretty tight so i made these nice side forcing clamps.
Not hard to make and very useful..
as you can see they are pretty versatile....
The slots in the one clamp allow the pressure to be applied perpendicular to the job via the grub screws . The other block clamps are just  buttress blocks, Align your work piece with a prick mark, center it with a carbide center, squeeze it in and clamp the piece accordingly.
Anthony.
Offline jcs0001
Re: FACE PLATE WORK HOLDING AWKWARD OBJECTS
« Reply #1 on: December 27, 2015, 10:08:34 AM »
Anthony:
That's pretty slick.  Howard Hall does come up with some very good ideas.
John.
« Reply #2 on: December 27, 2015, 12:18:37 PM »
Anthony,
Yes, those are pretty neat.
Just one question, Don't you need two 'tighteners' ? One opposing each fixed buttress.
Offline seadog
  • NE London
« Reply #3 on: December 27, 2015, 12:35:42 PM »
There are two.
« Reply #4 on: December 27, 2015, 01:12:44 PM »
Seadog,
Where is the second one ?
And Anthony wrote...
...The slots in the one clamp allow the pressure to be applied perpendicular to the job via the grub screws . The other block clamps are just  buttress blocks,..
I did expect to see two, but can only find one; that's why I queried it.
Offline seadog
  • NE London
« Reply #5 on: December 27, 2015, 01:20:18 PM »
David, the images are a little too large. if you scroll to the right you'll see the second clamp block.
Graham
Offline mexican jon
« Reply #6 on: December 28, 2015, 04:18:14 AM »
Seadog,
I had to click on the picture then look at the others in his photo bucket account before I could see the other 1  :Doh: the picture doesn't seem to be here  :doh: just on photo bucket   :hammer:
« Reply #7 on: December 28, 2015, 05:57:50 AM »
Mexican Jon, Seadog,
That would account for it.  I assume it must be the mostly hidden clamp behind the thick vertical web.
But definitely a 'must make' item.
Offline mcostello
  • Lancaster, Ohio
« Reply #8 on: December 28, 2015, 11:17:22 AM »
The most awkward item I had to ever had to put in a lathe was a regulation Bowling Ball. It had to have a piece parted off for a lid for an art project.
Offline nrml
« Reply #9 on: December 28, 2015, 12:56:01 PM »
If there is still any confusion, Mr Hall's drawings for the clamps freely available on his website will clear it up. http://www.homews.co.uk/LPClSim01.pdf
His website is well worth bookmarking. It is full of very useful and interesting stuff.
Offline howsitwork?
« Reply #10 on: December 28, 2015, 03:43:24 PM »
These clamps are truly excellent however I made mine with the tightening screws more towards the top of the blocks than the ones shown so you get a downward thrust as you tighten them. This is in keeping with Mr Hall's original design- as in Model engineering workshop where I saw them.
take care when tightening onto the t slots as you really can exert some force with these.
Happy New year one and all! :beer:
Offline ieezitin
« Reply #11 on: December 28, 2015, 06:37:32 PM »
Dave...
I really should have paid attention while photographing the blocks, there are two force blocks and they are directly opposite one another thats the only way they work. I posted this same thread on another site and everyone commented on how this set up would not hold the angle block and HSS spacer, i only threw them on the face plate for a visual... alas they are correct, these little blocks would not hold this set up and i did not  intend them to hold items like these of such height.
I did not make them exactly to Harrold halls print... i just was in the shop and machined on the fly as that is a normal MO for me to do, i must say (howsitwork) comment on the screw height is correct, none the less these blocks will work fine for what i need now and i am going to size the blocks up and make another set for different size work, these are a must in your tool work holding crib.
God Bless..... Anthony.
« Last Edit: December 28, 2015, 07:09:02 PM by ieezitin »
