Author Topic: Easson DROs  (Read 3491 times)
  • Country: ie
Easson DROs
« on: July 27, 2016, 05:53:06 PM »
I have alreday posted about fitting the ES-12 DRO to my SX2P mill na dthe ES-8 to my ML-7
I now have a question about the "SPEED" basic function as described on page 5 of both manuals.
The lathe (ES-8) works as described; Press and hold the X or Y axis selector for > 0.6 seconds, and you get a XS or YS feed speed display which is naturally zero as you have not twidlled any feeds. Apply feed to the selected axis and the fedd rate increases/decreases as you feed in X and Y
The Mill (ES-12) does NOT behave the same way: Press and hold an axis and it may display a feed rate of 452 mm/min! or some other random number.
Applying feed (+axis or -axis) just increments/decrements the displayes mm/Min!
Anyone else have this behaviour?
