Author Topic: Brass/aluminium/ms supplies  (Read 13000 times)
« on: December 18, 2016, 01:30:37 PM »
Offline Biggles
Re: Brass/aluminium/ms supplies
« Reply #1 on: December 19, 2016, 12:39:24 PM »
looks good John.
  • Country: ie
« Reply #2 on: December 19, 2016, 05:52:38 PM »
Bought a load of material from this supplier....well worth it....mixed al/brass and ms..
http://www.ebay.co.uk/itm/Brass-Sheet-Plate-Off-Cuts-Mixed-sizes-thickness-Be-quick-BARGAIN-/291943006076?var=&hash=item43f928bf7c:m:m5fegisNi4q5x1iBo2VU5bw
"Won't post to Northern Ireland!"
Does the Royal mail no longer recognise NI??
Offline Biggles
« Reply #3 on: December 20, 2016, 06:20:57 AM »
probably due to the weight and mail!
Offline gerritv
  • St Catharines
    • My Hobbies
« Reply #4 on: December 20, 2016, 08:59:27 AM »
They don't post to the ex-colonies either :-(
« Reply #5 on: December 20, 2016, 09:28:40 AM »
It will be delivery by carrier pigeon only for you lot soon  :) ....OZ.
« Reply #6 on: December 21, 2016, 06:37:32 PM »
Hi Will,
When you mention a NI address I'm assuming you use "Parcel Motel" ??
There's a new service from An Post that will bring parcels from a mainland UK address to your  local post office
€3.50 for up to 20kg   :clap:
https://addresspal.anpost.ie/
HTH
« Reply #7 on: December 21, 2016, 07:18:40 PM »
These are amazing! They are a 10 minute drive from work in Littleborough. Huge shop floor with shed loads of materials and helpful even for small bits I sometimes go in for.
  • Country: ie
« Reply #8 on: December 23, 2016, 06:07:27 AM »
Hi Will,
HTH
Thanks John, I'm aware of the new An Post service. It looks good but don't exceed the weight/size limit as its then €25 (Max 20kg and size  less than 72cm X 31cm X 25cm)
My comment was more about the Royal Mail and or the suppliers involved.
Why do some suppliers not want the export business?
In Irelaand the Homebrew shops (Nort and South) will deliver any where up to 30Kgs, next day usually for just €6 using DPD or Nightline!
Offline charadam
« Reply #9 on: December 23, 2016, 06:29:58 PM »
Can't thank you enough!
5kg, all brass - and big.
Great link.
