Author Topic: Small M2 Running Centre.  (Read 14456 times)
« on: May 21, 2009, 01:08:58 PM »
After admiring Stew`s handiwork, today I made a small running centre for my 7x20 Mini Lathe.....  :wave:
Whatever I`ve missed here, please refer to Stew`s posting........  :thumbup:
The centre & MT2 blank to suit my smaller tailstock.
http://i110.photobucket.com/albums/n95/Dayjo/p5200005.jpgSmall M2 Running Centre.
Blank mounted in MT3 sleeve in headstock. Remembering to insert a piece of 10mm screw into the blank`s thread, for stripdown.
Roughing began....... At .010" per pass.....  ::)
http://i110.photobucket.com/albums/n95/Dayjo/p5210002.jpgSmall M2 Running Centre.
A little hard at the taper end.
http://i110.photobucket.com/albums/n95/Dayjo/p5210013.jpgSmall M2 Running Centre.
Found a nice new "10mm" reamer.
http://i110.photobucket.com/albums/n95/Dayjo/p5210016.jpgSmall M2 Running Centre.
A little swarfe clearing problem. (No problem).
http://i110.photobucket.com/albums/n95/Dayjo/p5210018.jpgSmall M2 Running Centre.
This is not a good time to realise you do not own a drift.......  :bang:
http://i110.photobucket.com/albums/n95/Dayjo/p5210020.jpgSmall M2 Running Centre.
I then realised the reamer is a few microns undersize, so I polished the centre shank to a lovely "pop" fit.
This caused an airlock with the loctite...... Had to file a flat to allow the air out!
Just needs the taper shortening for the little tailstock, after the loctite has cured.
http://i110.photobucket.com/albums/n95/Dayjo/p5210023.jpgSmall M2 Running Centre.
The centre is 23mm o/d, the tailstock ram is 22mm........ Now that`s close enough for me!  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/p5210024.jpgSmall M2 Running Centre.
Thanks Stew! Yer a gem......  :headbang:
Re: Small M2 Running Centre.
« Reply #1 on: May 21, 2009, 01:32:56 PM »
Nicely done David
It makes a lovely neat centre, I see you ran up against some tuff stuff as well when turning blank down, its not to bad but it does make the old machine groan.
Offline CrewCab
« Reply #2 on: May 21, 2009, 06:19:05 PM »
You guys are making everything look soooooooooooooo easy  :headbang:   ............. plus adding greatly to my "To Do" List
Ta chaps :beer:
CC
« Reply #3 on: May 22, 2009, 04:13:39 AM »
Don't forget to buy some of these.
Not worth messing about for a quid.
http://www.arceurotrade.co.uk/Catalogue/New-Products/Chucks-Backplates
JS.
« Reply #4 on: May 22, 2009, 04:54:16 AM »
Those screw in tangs are great John.
I bought a handful of them when I modded my tailstock. They are worth it at double the price.
« Reply #5 on: May 22, 2009, 07:41:50 AM »
Thanks John, one of those will tidy the job nicely.......  :thumbup:
