Author Topic: rotary table D1-4 reciever  (Read 57470 times)
Offline DeereGuy
    • D1 Adapter Solutions
« on: June 20, 2009, 02:45:41 PM »
My shop is a mess finally and I have swarf all over the mill and the lathe :D
My goal is to turn this chuck of 5.25 x 2 of aluminum:
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00074-20090618-1735.jpgrotary table D1-4 reciever
into something like this that  will be mounted to my rotary table:
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00071-20090618-1227.jpgrotary table D1-4 reciever
I have wanted to do this for a while now and all the postings that have been going on about rotary table adapters have spurred on my want to do one.
Currently I am at this point.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00090-20090619-1738.jpgrotary table D1-4 reciever
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00091-20090619-1900.jpgrotary table D1-4 reciever
Once I get everything sorted out and proper dimensions figured out I will post the complete build with the plans as best as I can come up with them.  So far I have had a few minor screw ups but nothing I wasn't able to over come.  I won't be back in the shop today anymore because SWMBO has other more pressing things for me to do :(
Tomorrow however is fathers day and I have been notified that it is mine to do as I see fit. :beer:
Cheers all and I will keep you posted as I make progress
Bob
Note edited to modify the title to reflect it is for the rotary table. ::)
« Last Edit: June 21, 2009, 02:33:54 PM by deere_x475guy »
Re: D1-4 reciever
« Reply #1 on: June 20, 2009, 03:10:05 PM »
Bob,
Interesting project. :dremel:
Aluminum? :bugeye:
Aren't you afraid of putting bumbs and dings in it when changing chucks or is it going to be protected from such abuse?
« Last Edit: January 09, 2011, 11:42:53 AM by Bernd »
Re: D1-4 reciever
« Reply #2 on: June 20, 2009, 04:58:23 PM »
Hi Bob
I've found my RT/chuck mounting invaluable, for quick sets, you'll find it well worth the effort, look forward to seeing your set up develop.
Offline DeereGuy
Re: D1-4 reciever
« Reply #3 on: June 21, 2009, 02:33:26 PM »
Bob,
Aluminum? :bugeye:
Bernb
Bernd, yes aluminum, I had this on hand from a real deal I got on 4 - 8" pieces I picked up a couple of years ago.  Money's tight as it is for most of us so this is what I chose, right now I am calling it a prototype but it may very well come out totally usable if I don't cock it up some how.  Plus it is light and makes moving the rotary table with it mounted and the 5C collet chuck possible for me w/o a crane of some type.  The Bison 3 jaw and 4 jaw chuck's that I have will be another story.  I have already dropped it and have taken care of the first ding anxiety :bang:
Offline DeereGuy
Re: D1-4 reciever
« Reply #4 on: June 21, 2009, 02:44:34 PM »
Hi Bob
Hi Stew, I have some minor tweaking going on today to make the pieces fit together nicely.  At this point I don't see it being done today because as soon as the sun passes far enough to move it off the south side of the house I will be doing some sanding on the south side of the cabin to prepare it for another coat of maintenance stain.
http://i2.photobucket.com/albums/y39/Deere_X475guy/SouthSide.jpgrotary table D1-4 reciever
It may not appear that bad in the picture but after 4 years of southern exposure I am getting some failure of the original stain.  It's not to bad of a job really this time around.  The original coat took me almost two summers to do the whole house.
Re: rotary table D1-4 reciever
« Reply #5 on: June 21, 2009, 02:46:41 PM »
Sounds like a plan then Bob. I can understand the finances being tight.
Ya, why didn't think of that, "prototype". Have to see if it'll work or not so why use expensive material the first time.  :)
« Reply #6 on: June 21, 2009, 03:15:30 PM »
Wow Bob
That looks like a lot wood to stain, don't let Bogs see it, as it'll give him nightmares you know what he thinks of wood
 :D :D :D
Nice looking house by the way.
Offline DeereGuy
« Reply #7 on: June 28, 2009, 10:20:45 PM »
Well I had a few hours in the shop today and got 1 pin fitted so I have a few more pics for everyone.  I decided I would make a hex head and use a socket to tighten the pins.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00114-20090628-2033.jpgrotary table D1-4 reciever
Here is a shot of the pin inserted into the reciever and turned so that the chuck can be mounted
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00115-20090628-2037.jpgrotary table D1-4 reciever
Here is a shot of the pin rotated 90 degrees.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00116-20090628-2038.jpgrotary table D1-4 reciever
Once I get all thee pins finished I will tighten my 5c chuck down and measure the run out.  I am a little worried that the 90 degrees will not be enough to lock it and may have to reduce the dia of the pin where the interferance fit is.
I will keep you all posted on my progress as I get time.  The logs are now ready to stain but we have 3 days of rain coming so I may get a few hours over the next 3 evenings to work on it a bit more.
« Reply #8 on: June 29, 2009, 01:04:20 AM »
Progressing well Bob
 :thumbup:
Offline DeereGuy
« Reply #9 on: July 03, 2009, 05:11:22 PM »
Tomorrow is a holiday here in the States and the company I work for gives this off to us.  Since it fell on a weekend day they gave us today off. :D
Since it is my birthday and we have a threat of rain I didn't do any staining on the cabin today....instead I made some great progress in the shop on the reciever.
I was having some trouble getting things concentric.  After bluing up the register I found that when I tightened up the receiver pins the chuck would be pulled slightly off center and would not let the chuck sit tightly on the face.   :bang:  Ok...so back to the mill, find center again on open up the holes about .010.  PERFECT!!!!.... Before doing this I noticed that my 5C collet chuck was the only chuck that would fit fairly well in the holes.  The rest would not drop down low enough because of binding.  What I found after checking the bores for the pins on the lathe reciever that they were made for a very sloppy fit.  Now I have just slightly over .001 TIR with it mounted in the 4 jaw and when I finally fitted it to the rotary table I have the same results with a .75 dia rod held in the 5C collet chuck.  I am more than pleased with this as I was shooting for no more than .003.
Here is the 5C collet chuck mounted to the reciever.  It measured .001 + TIR here.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00123-20090703-1413.jpgrotary table D1-4 reciever
Here it is mounted on the rotary table with the same TIR.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00125-20090703-1554-1.jpgrotary table D1-4 reciever
Here are the other D1-4 chucks and face plate mounted on the reciever:
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00126-20090703-1617.jpgrotary table D1-4 reciever
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00127-20090703-1618.jpgrotary table D1-4 reciever
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00128-20090703-1619.jpgrotary table D1-4 reciever
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/D1-4%20reciever/IMG00129-20090703-1624.jpgrotary table D1-4 reciever
Obviously the height will be a problem for some, luckily I still have plenty of room left and now I can mount any size d1-4 chuck to the rotary table.
I still need to make the detents for the pins so that it is easier to locate where the pins are set to remove the chuck,  I have been kicking around the design of the pins quit a bit with circlip via skype and I will be cutting a grove all the way around the pins.  Spot drill where I want the detent, then use a metal ball and spring with a grub screw to push the ball into the detent.
Crap-O-Cad drawings to follow. :beer:
« Reply #10 on: July 03, 2009, 05:22:37 PM »
I can see that little lot becoming very useful...nicely done..... :clap:
« Reply #11 on: July 04, 2009, 01:03:39 AM »
Nice Job Bob  :thumbup:
Thats given you plenty of options for mounting work on the RT
« Reply #12 on: July 04, 2009, 02:57:27 AM »
A very nice conclusion to your project Bob.
As you most probably know, I am a great believer in adaptable tooling, especially if it extends your repertoire by being able to mount it between machines.
A real nice job.
« Last Edit: July 04, 2009, 03:57:33 AM by bogstandard »
« Reply #13 on: July 04, 2009, 03:39:38 AM »
VERY nicely done Bob!  :clap: :clap:
« Reply #14 on: July 20, 2009, 11:51:48 AM »
Dunno how I missed this one. I have to do something similar... Lots of good ideas here.
Offline DeereGuy
« Reply #15 on: July 20, 2009, 12:04:36 PM »
Thanks Eric a lot of R&D went into this one figuring out all of the dimensions.
« Reply #16 on: July 21, 2009, 04:29:34 AM »
Bob,
That is really good, be it's dead useful.  :thumbup: If I get a rotary table I would need a threaded adaptor for my lathe chuck, not sure how i'd go about making that.
Stew, how does yours mount?
Cheers,
« Reply #17 on: July 21, 2009, 04:55:34 AM »
Its held on witha 74mm register and four bolts through the back same as my lathe, the adaptor plate is held to the RT with a M2 taper with a cap screw up the back.
http://madmodder.net/index.php?topic=1330.0
Hope this helps
Offline DeereGuy
Re: rotary table D1-4 reciever (Plans are free just PM me.)
« Reply #18 on: November 20, 2010, 09:48:42 AM »
All,
I have the plans I am giving out to the forum members.  Just PM me and I will send you the set.  All I ask is that you use them for personal use only.
Offline DeereGuy
Re: D1-4 reciever
« Reply #19 on: January 08, 2011, 10:20:10 AM »
Bob,
Aluminum? :bugeye:
Bernb
I know this is an old post but I thought I would show what this part would look like after being in continual use for the last year and a half.  Weston Bye anodized this for me in August of 2009 and this is what it looks like today.  Surprising what protection a good anodizing will give.
http://i2.photobucket.com/albums/y39/Deere_X475guy/IMG_20110108_092215.jpgrotary table D1-4 reciever
http://i2.photobucket.com/albums/y39/Deere_X475guy/IMG_20110108_092231.jpgrotary table D1-4 reciever
This was the first version and below is what I have just finished.  This one takes the OEM camlock pins that can be ordered from various suppliers when the campin wears.
http://i2.photobucket.com/albums/y39/Deere_X475guy/IMG_20110108_094223.jpgrotary table D1-4 reciever
« Reply #20 on: January 09, 2011, 11:44:26 AM »
Ok, I'm convinced. (I don't think you've done any work with them  :lol: ) They still look great.
Offline ieezitin
« Reply #21 on: January 09, 2011, 12:50:29 PM »
What a great mod.
Great looking piece of equipment and shows quite nicely the benefits of anodizing. And by what I have read here it’s not that unachievable for most of us in our hobby shops.
Bob thank you for showing us.    Anthony.
Offline DeereGuy
« Reply #22 on: January 09, 2011, 03:07:54 PM »
Bernd thanks!
Anthony,
I have changed a lot of things since I first tried this myself last June.  I am now using a CC powersupply, commercial black dye, and nickle acetate for sealing.  The black part was anodized at 12 ASF and the tank temp was 75 - 78 degrees.  My tank mix is 1:1 Napa Battery acid to distilled water (5 gallons total).
« Reply #23 on: January 09, 2011, 04:29:37 PM »
Bob, quite right anodising is a great surface protection. We use it at work for components that have to be stored / used in extreme conditions. We put stuff through salt spray tests and it holds up really well.
Nice work there, Nick
Offline DeereGuy
« Reply #24 on: January 09, 2011, 04:45:29 PM »
Thanks Nick,
It's been a real learning experience.  I am thinking about adding a small chiller for the 5 gallon tank.  Now that I am shooting for 12 to 15 ASF it will be harder to keep the tank cool this summer.
