Author Topic: Project Halo  (Read 74284 times)
Project Halo
« on: August 01, 2009, 05:10:05 PM »
I was due to start this project last year, but a combination of ill health and a complete workshop rebuild meant that it has been delayed until now.
Because this will be a talk thru, and because I am not making just one engine, I will in fact be treating if it was a production job. So I will be doing a few things different to normal, just to allow me to make a lot of items in the shortest possible time, but you should still be able to do it as I do, as some of the parts you will require five off of each one, whereas I will be making over twenty, so I will be making some easy jigs to help.
As far as I am concerned, this engine requires that you have a lathe, mill and an RT. I just cannot go into any depth about using other methods, which I am sure you can find workarounds for, because of the limited time I have to get the job done.
I know that the plans are perfect, as I know two people who have built straight from plans, and everything fitted together with no problems. I will be making the parts to the drawings (bling allowing), and will be concentrating on one part at a time, before continuing to the next. With a tiny bit of checking throughout the machining, a few fitting checks will be made. By doing this, I should be able to make all the parts, then it is just an assembly job at the end.
You should all know by now what engine I am on about, but if you don't, here is a nice link for you took have a look thru.
http://lineymachine.googlepages.com/l5
So without boring you to death any more, lets get on with it.
I am actually going to be building six engines. The first will be a set of 5. This engine can be made with 1 up to 5 cylinders, I will be making the whole set for a display. Then because I found I had spare components for assembly, I will be making a 5 cylinder for my collection, so in fact, I will be making 20 cylinders, but only showing on here the basic 5 cylinder engine. It would just take too long for me to show all the working out and machining for the others, as each engine has different angles and components to be worked out.
I contacted Lance at Liney Machine, and asked him just to send me the assembly pack and plans, as I had all my own raw materials. I went that way because I didn't want to start changing over from the US unified system to either BA or Metric. But John S has built a 3 cylinder version using 2mm fasteners.
Once I received the plans, and saw how good they were, and how the engine could be built with any number of cylinders, I contacted Lance again, and asked him to send me another few assembly packs of just the bearings, bolts, springs etc. Basically, anything that I would have a little bit of difficulty obtaining in the UK, because they were just as cheap for me to import them as buy from here. I even had him send me a few very good quality 2-56 taps. Just a little note here, every thread on the engine is 2-56, and only taps are required, standard fasteners take care of all external threads.
I will also add now that this engine was designed to be made by CNC, but having gone thru the whole list of components, there is nothing that cannot be fairly easily done by manual machining, and good tolerance control.
The pic below shows all the items I was sent. The ring bound plans are great and well detailed, there is even a set of acetate overlays that shows how each part builds up into the finished engine. IMHO, if all plans were like this, making engines would be a whole lot easier.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo01.jpgProject Halo
So now to get down to making the thing. I am starting by making the cylinders. The plans call for 3/4" square brass bar, but because I am making mine out of bar ends, I want to work with round bar, and I will machine the square bit on later.
So out with the desktop engineering calculator, and I soon had the diameter I required. Near as damn it 1 1/16".
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo02.jpgProject Halo
I have loads of hex bar ends, and a quick measurement showed they would turn down easily to the size I required. So I measured the length of a few, and got enough together to get the job done with very little wastage.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo03.jpgProject Halo
When I start a project, I get together a few boxes at the back of my assembly bench. In these I store everything parts wise that I already have and things that are to be made. There is nothing worse than searching around for bits you have already done but can't find.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo04.jpgProject Halo
The job now starts in earnest.
I turned the hex bars down to size in one hit, flip it around in the chuck and turn the other end down. I didn't go down to finished size just yet, that will come later. These were about 0.020" over size.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo05.jpgProject Halo
Ten minutes later, I had enough round bar to do the job.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo06.jpgProject Halo
I tried parting them all off to length under power, but it was just too slow. So I went in by hand as fast as I could, and they were all soon to rough length.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo07.jpgProject Halo
Millions upon millions of tiny hypodermic needles. Get one of these in your skin and you will soon know about it. They start to corrode and fester in less than a day.
Time for a very good clean up.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo08.jpgProject Halo
Enough to do the job, and a few spares, just in case.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo09.jpgProject Halo
The next job will be to get accurate holes thru all these, then the work to get them to shape can start.
Offline shred
Re: Project Halo
« Reply #1 on: August 01, 2009, 09:33:21 PM »
wow.. I'll definitely be keeping an eye on this build.
Offline NorthOf40
Re: Project Halo
« Reply #2 on: August 01, 2009, 09:37:12 PM »
Thank you, Bogs.
I always learn quite a lot from your write-ups. :thumbup:
Jim
Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it. – Mark Twain
Re: Project Halo
« Reply #3 on: August 02, 2009, 12:35:57 AM »
One of my planned builds... I will be watching this one with anticipation!
Offline kvom
Re: Project Halo
« Reply #4 on: August 02, 2009, 08:42:15 AM »
This is my planned winter project.   I have to obtain a rotary table first.  It will be nice having this thread as a reference.
The 2-56 fasteners are a bit daunting, but I guess I need to bite the bullet and learn to work smaller.
Re: Project Halo
« Reply #5 on: August 02, 2009, 12:51:04 PM »
Kirk,
When working with these small sizes, it is well worth building youself a tapping stand, as a few of the lads have done.
It does honestly cut down the breakage problems because you feel with your fingertips rather than your whole hand.
I bought 4 taps for making six engines, but that is looking on the very pessimistic side. If all goes to plan, I should end up with 4 unbroken ones left. The only reason I bought that many was in case I felt one going dull, then it would be thrown away. On the first squeak, it is out of there.
Offline zeusrekning
Re: Project Halo
« Reply #6 on: August 02, 2009, 04:58:03 PM »
Looking forward to following this build closely John. The tray for keeping up with all ready made parts is a must for sure. I seem to spend more time hunting than making when it comes to small parts. Good luck with the build man.
Zeusrekning
Re: Project Halo
« Reply #7 on: August 02, 2009, 07:04:55 PM »
This is going to be about one of the most boring posts you have ever seen, all because it is just shots of metal being either hacked down to size, or having a hole stuck in it.
But I suppose it needs to be shown because it is all part of the build.
Whenever I come to machine a fairly complicated piece, I study the drawing and work out a machining procedure.
This needs to be done, because you can easily get yourself into a position where you can't hold a part to finish it off.
This isn't written in stone, as I fairly regularly make a machining procedure, then when I get half way thru, I find I can change it to maybe cut out a couple of the steps by doing something slightly different.
If you can get into the habit of making notes and procedures like this, you will find that things go a lot smoother and less mistakes are made.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo10.jpgProject Halo
The part was mounted into the 3 jaw and about 1/2" was turned down to finished size for making the square flange. It just so happened that this was the largest size that I could hold in the 5C collet chuck, and as I have said, because I am treating it as a production run, I will use whatever I have to get the job done. So if you do it, you will most probably carry on using your normal chuck.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo11.jpgProject Halo
So now the finished size end could be held in a collet.
The first job was to face the end, this will be the datum end that all other measurements go from.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo12.jpgProject Halo
The next op was to centre drill to get ready for putting the bore in.
Because I am using a collet chuck, I can remove the part between operations, but if using a normal chuck, you would leave it in there and finish the whole operation until the bore was complete.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo13.jpgProject Halo
My next step was to drill 1/64" undersize of the finished size required.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo14.jpgProject Halo
A 3/8" parallel machine reamer was then used to finish off the bore. I find that a reamer is perfectly satisfactory for a job like this, but for other types of engines, I would bore the hole.
If you don't have a reamer you have two choices. The first is to carefully drill with the correct sized drill, and hope the bore cleans up nicely enough. Nine times out of ten, it will do. If it didn't, then a little lapping should sort it. The second option would be to bore the hole, a much longer process and your bore should finish up with a perfect finish.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo15.jpgProject Halo
It was at this point I decided to deviate from my proposed schedule. Instead of turning to an oversize, I decided to turn down to finished size, purely because this is where the finning on the cylinder is, and so I decided that it didn't need to be perfectly sized, so I turned down as long an area as I could in one hit down to the nominal size of 3/4". As it turned out, once I had set and locked the cross slide, they all turned to exactly the right size.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo16.jpgProject Halo
These are all the bits with the finning area to size. The top face, as I said before, is the datum face for the overall length.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo17.jpgProject Halo
The 3/4" collet was fitted with an internal backstop. The datum end was put against the backstop, and the machine set up so that after facing across, the cylinder would end up at the required length. Each cylinder in turn was faced off at the same setting.
Unfortunatley, the 5C backstop system is not as accurate as everyone thinks. Because it is mounted into the back of the collet and not into the lathe spindle, just by over or under tightening the collet can make the part slightly longer or shorter. Mine all came out within 0.002" of optimum length, so as far as I am concerned, they are within acceptable tolerances.
If you are using a normal chuck without a spindle backstop, then you will have to do it the hard way, measure, remove a bit, measure and so on until you reach the correct length.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo18.jpgProject Halo
I then decided just to rough size the flange area, rather than finishing it to correct dimensions.
I have got a design in my head for an all in one drilling and flange machining jig that will save me hours of RT work. By leaving the flange until later, the extra thickness will allow more accurate use of the jig.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo19.jpgProject Halo
The bits are now ready for drill and mill work, and me getting the jigs made.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo20.jpgProject Halo
If I get chance tomorrow, I will try to put my idea into metal, to see if this project can be taken a stage further.
« Last Edit: August 02, 2009, 07:10:47 PM by bogstandard »
Re: Project Halo
« Reply #8 on: August 02, 2009, 07:25:31 PM »
I could see my turret lathe coming into it's own here..... :ddb:
Looking nice John, watching closely as always. A bit more under me belt and maybe, just maybe........ :nrocks:
Re: Project Halo
« Reply #9 on: August 02, 2009, 11:53:51 PM »
That is very true Darren, a turret would have speeded things up no end.
I do in fact have one of those tailstock turrets, a good idea purchase at the time. But for me to set it up to do everything I would want of it, even for this little job would have cost me rather a few quid for good quality chucks. I suppose one day I will get it set up for how I would need to use it.
Mind you, twenty odd bits all the same cause me personally no problems. Once you get into a routine of swapping bits while the machine runs up and down, I suppose it could be nearly as fast as using the tailstock turret because you are having to move the tailstock anyway because of tooling lengths. It is totally different when you have a capstan saddle, you can get in and out much faster.
NB.
I have just read my last post, and it is lucky I didn't complete the maching routine that I had written down. Towards the end, it said 'form a 0.110" collar', it should in fact have read 'form a 0.100" collar".
So this is a massive reminder, not only check the drawings, double check your routines as well, to make sure they conform to the drawings.
I don't think it would have caused major problems, but a problem none the less.
A VERY lucky escape, and was caused by rushing things.
« Last Edit: August 15, 2009, 04:56:54 AM by bogstandard »
Offline kvom
Re: Project Halo
« Reply #10 on: August 03, 2009, 10:06:46 AM »
Question:
Do you see any issues in making the cylinders in Al and the crankcase in brass?
Re: Project Halo
« Reply #11 on: August 03, 2009, 10:35:58 AM »
Kirk,
Just having a lookthrough, I would say it would be OK, as long as you kept brass pistons to prevent galling.
But of course, that would be only if it was run on air, I would have grave doubts it would run on steam.
Re: Project Halo
« Reply #12 on: August 04, 2009, 06:54:45 PM »
I managed very little yesterday, not enough to post, and so finished it off today.
So here is my solution to the drilling problem I had. Notice the word HAD, you will see later. You should see it develope as I go along.
First off, I needed a bit of tough material, because I only have 180+ holes to drill, it isn't worth hardening anything for such a small quantity. I found a lump of stainless off some sort of machinery I must have stripped down at some time. A spigot to fit into the bore was turned on it, and polished so that the bore wouldn't be damaged.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo21.jpgProject Halo
A very nice sliding fit, but not loose.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo22.jpgProject Halo
This is a pic of the drawing showing how the holes have to be, but because I am working with round bar and not square, I couldn't use the marked positions for the holes. Instead, I worked out the PCD of the two sets of holes. These dimensions will be of help to you if you use round bar.
The cover up of the drawing is because when I talked with Lance about doing this post, I promised him that I would not show enough of the drawing to allow the engine to be made. The plans and fixings are very reasonable, and it would be expected you purchase them if you wanted to make one.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo23.jpgProject Halo
I needed two plates making, one for either end of the cylinder. One end was drilled 5mm, the other drilled and tapped 5mm. Sorry about the metric, this post was supposed to be all imperial, but at times it will need to be. Most of my workshop fastener stock is metric. The discs need to be larger than 1 3/8", and mine are about 1/4" thick. There is a reason for these dimensions, but they are not overly critical.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo24.jpgProject Halo
This is what they look like with the cylinder loaded.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo25.jpgProject Halo
So now I had to get things onto the RT, to get the holes drilled in the right places.
First thing is to centralise the RT to the quill and get everything zeroed up.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo26.jpgProject Halo
I fitted the disc that goes onto the head end of the cylinder first. This uses the smaller of the above PCD's. So the Y axis was offset by half the PCD figure, and the standard 0,90,180,270 degree RT settings were used for the four hole locations.
These positions were then centred with a #1 imperial centre drill (1/8" diameter, this is a diameter that is used later). As this is a bit of tough material, I used tapping oil as the lubricant.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo27.jpgProject Halo
The centre holes were then followed down with a good quality 1/8" drill. We need good sized holes here. Make sure you stand the piece off the chuck jaws slightly, otherwise you will drill the jaws as you break thru.
It was at this point, I stopped yesterday. Unfortunately, I forgot to take shots of the next two procedures, but the picture below shows what I did.
I locked up the RT really tight,  and traversed some more in the Y axis, then machined a flat on the back of the disc, just like below. Coming in by 1/8" should give you a fairly wide flat. Make a note of the amount you come in, to the nearest thou.
I did the second disc the same as the first, except it was at the larger PCD. But before cutting the flat, the disc was rotated by 45 degrees.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo28.jpgProject Halo
This is what the second disc looks like with the holes rotated by 45 degrees to the flat. The flat was machined to the same setting as the first. I actually went to great lengths with my offset for the flat, because my jig is going to be used for a critical second operation. More of that in the next post.
Both discs had the outside ends of the holes countersunk slightly with a #2 imperial centre drill. These should be a 60 degree countersink, the same as on a #1 centre drill.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo29.jpgProject Halo
This is now the drilling jig itself completed.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo30.jpgProject Halo
And this is how you set it up.
Make sure you have the correct end in the jig for the pcd on the discs. Assemble it lightly, gently tighten up the vice, and the two flats should automatically be lined up perfectly, tweak up the screw, and you have the assembly ready for drilling
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo31.jpgProject Halo
Or as I do, push the two flats down onto a perfectly flat plate, and tighten up.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo32.jpgProject Halo
Now set up a #1 centre drill (1/8" diameter) so that only the tip drills into the part, it should stop just before the countersink starts to cut. Then set the width of the vice jaws just a little wider than the washer under the assembly bolt head.
It is then a matter of just placing each hole under the drill and bring it down. The 60 deg countersink will guide the finger held jig and the centre drill into perfect position. Just carry on and drill the hole. Once you have done one end, flip over and do the same on the other end.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo33.jpgProject Halo
Eight perfectly placed pilot holes, exactly 45 degrees rotation between the two sets. It took less than half an hour to pilot drill 23 cylinders, over 180 holes. To do the same thing on an RT would have taken hours, mainly because of setting up for the 45 deg offset. Even if you used the square bar and tried to do it in the vice using a backstop, it would still have taken a lot longer. BTW, you cannot drill both sets of holes from the same end, the area for the cylinder fins get in the way of a centre drill for drilling the larger PCD flange holes. I suppose you could make up a special very thin pilot drill, but then you would have the trouble of drill tip wander.
I could have used the PCD function on my DRO, but you would have learned absolutely nothing.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo34.jpgProject Halo
Now comes the dead easy bit. Make up a close fitting stub mandrel that just clamps into the vice, you get it perfectly upright by putting one of the cylinders over it and making sure the cylinder end is resting flat on the vice jaws, then tighten up on the vice.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo35.jpgProject Halo
Put the small #1 centre drill in the chuck, and move the table until the drill tip goes nicely into the pilot hole. I would suggest the flange end first, as that is a straight thru hole. You can position the drill in any position you like, as long as the tip enters the hole precisely. This allows you to put it were you can see it the best.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo36.jpgProject Halo
Swap out for the correct sized drill, turn the cylinder until the pilot hole is under the drill and just go for it. Basically everything lines up perfectly and you can actually take your steadying hand away, only needing to steady the part when the drill breaks thru.
You do the head end the same way, but you also have to put in the smaller drill size and set your depth stop for the drill.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo37.jpgProject Halo
Again, about half an hour for all these holes. They almost drill themselves.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo38.jpgProject Halo
This is a close up shot showing the top and bottom offset holes. The smaller ones will go onto the tapping stand to have the threading done, and the flange end will use the drilling jig to set it up for squaring off.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo39.jpgProject Halo
Nearly at the end of making the cylinders, just square off the end and then onto the lathe for finning and trimming to size.
« Last Edit: August 05, 2009, 01:08:30 AM by bogstandard »
Offline zeusrekning
Re: Project Halo
« Reply #13 on: August 04, 2009, 09:16:29 PM »
Its really nice to see the fixturing done for small production runs. Its not to commonly done in the home shop but your set up is more similar to what i am used to doing at work.
Keep up the good work.
zeus
Re: Project Halo
« Reply #14 on: August 05, 2009, 12:33:10 AM »
Zeus,
This is the sort of thing that you don't see me doing, but it is a fairly normal occurance when small production jobs come in. A little jig or fixture can save tremendous amounts of time.
By making this drilling jig, even on such a short run, has saved me many hours of work setting up the RT. Plus it has the added advantage, if I want to make any more of these engines, the fixture will be ready and waiting. Or if anyone wants to go the round bar route, a bit of postage, and it can be sent out to help, to save them having to make a jig.
If using the square bar as recommended on the plans, then it might be a worthwhile thing to carry out the drilling on just the mill using a backstop and an edge finder, just using the square bar faced to length before any turning has been done on it.
Every method has it's own problems and solutions. If anyone needs help with setup procedures for their particular type of build, then they only have to ask, and I will help if at all possible.
I don't know if it is really a viable proposition if your are only making five cylinders. But a quickie throw away one out of say ali might be.
Re: Project Halo
« Reply #15 on: August 05, 2009, 02:20:14 AM »
That was so very well done, and very well shown.....  :clap:
The sort of thing many thousands of skilled machinists have done many times, over very many years.
But, very difficult to explain to others.......  ::)
You have the knack.  :headbang:
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
Re: Project Halo
« Reply #16 on: August 05, 2009, 03:01:33 AM »
I agree totally with David D. Thanks for taking the time to show those of us who are not trained machinests just how to save a lot of time and effort to achieve a consistent result using a jig.  :thumbup: :thumbup:
Tim
Offline kvom
Re: Project Halo
« Reply #17 on: August 05, 2009, 08:05:19 AM »
I am very impressed with the jig, esp. with the thinking that went into it.  Seems simple once you understand it, but I would not have come up with anything close. Using the oriented flats to ensure the 45 degree angle between top and bottom was the part I found ingenious.
I would be using round bar, but would have milled the flange square first, thus reducing the fabrication to the square bar case.
Re: Project Halo
« Reply #18 on: August 05, 2009, 01:13:14 PM »
Many thanks for the comments.
Unfortunately, having thought about it, I was a little selfish just showing how I had done it, and ignoring how most other people would do it with the square bar.
So I hope this post will correct that.
What I did this morning, was to do a setup as if I was doing it by the square bar method, but not actually drilling any holes. So you will have to use your imagination a little.
Just imagine this isn't another drilling jig, but the square bar with the bore thru it.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo40.jpgProject Halo
This is what I would do.
Put the backstop in position, with a pair of parallels in the vice. The low tension spring is to keep the paras in position as you are opening and closing the vice jaws all the time, and it is a PITA if you have to keep resetting them. Then I put my favourite edge finder in the chuck. You will have to allow for slightly different operations if you use another type.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo41.jpgProject Halo
You should, if possible when doing drilling like this, always work from known fixed points. The two fixed points here are the vice fixed jaw and the back stop.
So the part is dropped onto the paras and pushed against the stop and jaw with a downwards pressure as well, then the vice is tightened up.
I shouldn't need to remind you that the ends that go down onto the paras should be faced off and square to the sides.
This is a part I must explain to you. If you have machined the square bar yourself, it should be to size. If it came as a purchased length, sometimes the size can be up to about 0.005" smaller. This must be taken into account if you want good accuracy, and as such, you should measure the bar both ways, and make allowances.
We will take an example of the bar being 0.004" smaller. Halve the deficit, 0.002", and subtract that from the amount you have to move inwards from the edge. The further from the fixed faces the measurement is, the more critical you remove the error.
If you are working from the centre of the part to a PCD measurement, the centre of the bar must be found by subtracting the errors first.
I have done a rough sketch at the end to show what can happen if you don't do it.
A lot of times it doesn't make a difference, but if you are working to tight tolerances, it does.
So you find the edge, and move over the correct amount.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo42.jpgProject Halo
Then do the same thing on the backstop side.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo43.jpgProject Halo
So you now lock up X and Y axis, then using a centre drill, put in your pilot hole.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo44.jpgProject Halo
Move the part around to the next side and drill in again. The green spot represents where the first drilling was done, I told you it was imagination time.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo45.jpgProject Halo
So once all four holes have been pilot drilled, put your twist drill in the chuck, set up for correct depth, and drill away. You repeat for all four corners.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo46.jpgProject Halo
During the turning process, you have to make sure that all the areas are kept clean, because a bit of swarf can easily knock things out of line.
So for the other end, you repeat the first setup but using a different sized drill and locations.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo47.jpgProject Halo
As above.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo48.jpgProject Halo
As above, but if the size difference isn't allowed for, these holes, being out of line, will have more impact on the job.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo49.jpgProject Halo
This is a very rough sketch of what will happen to the holes if you don't compensate for the difference in size.
This pic is in fact wrong, I have shown the bar offset centre position in the wrong place.
Just use your imagination again, and think of it as being right.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Halo50.jpgProject Halo
I hope you had enough imagination to pick the technique up.
Offline CrewCab
Re: Project Halo
« Reply #19 on: August 05, 2009, 01:43:25 PM »
Good tips John, many thanks  :beer:
CC
Offline cedge
Re: Project Halo
« Reply #20 on: August 05, 2009, 02:44:39 PM »
John...
Are you building these to be steam capable or will they be basically air powered engines?  I've wondered more than once why Liney added cooling fins to what should be basically considered a steam engine.
Re: Project Halo
« Reply #21 on: August 05, 2009, 02:59:57 PM »
Steve,
I am building with what the plans says should be used.
It seems that everything Liney market are in fact steam capable, but unlike all their other ones, I have only seen this one on air.
Having looked at all the drawings, clearances and materials, I have no doubt it would steam.
If I can get these finished, I will be able to answer your question for definite.
I think the fins are purely for cosmetic effect on the engine. It would look rather bland without them, but as you suspect, it wouldn't help their steaming capability.
Offline kvom
Re: Project Halo
« Reply #22 on: August 05, 2009, 08:20:01 PM »
Your process for the square flange matches my thinking.  Having a DRO, I can find the center via the edge finder on either side and using the 1/2 key to split the difference.  So a bit faster than measuring and scrolling over from the edges.  I just bought a keyless chuck for the mill that will clamp my 1/2" edge finder, so now I won't have to use the same 1/2" collet for the edge finder and drills.  That should speed up my work quite a bit.
For the machining from round stock, I am thinking of the following process.  Critique is welcome:
1) Using the 6-jaw in the lathe drill and ream the center bore, and then face and turn the spigot to finish diameter.  I would need to make the spigot overlong as it will be held in my Jacobsen collet, which is inset from the collet chuck.  Part off.
2) Clamp in the Jacobsen collet chuck via the spigot.  Turn to 3/4" finish diameter leaving the flange material (no need to turn down the flange portion).  Face to finish length.
3) Remove the piece from the lathe, and clamp the head end in a 3/4" 5C collet in a square collet block.  Clamp the block in the mill vise and successively mill the flange square by rotating the block in the vise.
4) With the piece still in the block, clamp the block vertically in the vise using the vise stop.  Measure center and locate one corner.  Center drill, then rotate the collet block in the vise for the other holes.  Then repeat using the clearance drill.
5) Reverse the piece to hold the spigot in the square collet block.  Using the surface plate and height gauge, square the flange to the collet block.  Then use the same procedure to drill the holes for the head.
I would retain the overlength spigot for remounting in the the lathe for cutting fins/tapers, etc.  Eventually the flanges could be use to clamp in the mill vise to mill the spigot to length.
Re: Project Halo
« Reply #23 on: August 06, 2009, 02:42:56 AM »
Kirk,
It is good to see you are starting to do a lot of forwards planning. That is the secret to making complicated parts.
These cylinders are not complicated at all, but the reason I am being so long winded about it, there are a few traps that the unsuspecting could easily fall into. That is why I am trying to explain the reasons for me doing it the way I have.
If you remember, these plans are to make an engine using CNC. Which means, that once set up, will bang out perfectly spaced holes with great accuracy time after time. I am trying to show how to replicate that accuracy by doing it manually.
The engine would most probably go together and run by not being too accurate with the measurements, but making it exactly to plans for the critical bits will guarantee it will work.
Looking at it, your system might have a fault or two.
Your mounting of the collet block vertically is the major issue as far as I would be concerned. Bits sticking up that far from the vice jaws have a tendency to be rather unstable, and if only a second of a degree out, will start to move away from being square.
I have some more work to do on these cylinders, and I would suggest you see what sort of things I get up to first, then look at maybe modifying what I do before making your final machining procedure.
Re: Project Halo
« Reply #24 on: August 06, 2009, 04:49:49 AM »
Hi John
Great thread great post:- coming along great, I like your tip of using the spring to keep parallels in place that ones files away.
Have fun
