Author Topic: Small "Mill Engine Plant" (Display)  (Read 86746 times)
Offline klank
  • Sunny East Devon
« on: August 06, 2009, 09:30:11 AM »
The project I am working on, is to put together a finished Stuart engine, a nearly finished boiler made to a Tubal Cain design, and some sundry other kit, laid out as a working display (sort of basic "Diaorama").
Some of the photos of two of these items below have been published individually on another site about a year ago, but I hope I am forgiven for re-using them in this context.
Compared to many other beautiful projects on this site, this is admittedly a basic, beginners' project - albeit somewhat lengthy to describe. I do hope it may encourage a few to look at "steam" as a viable alternative to compressed air.
A bit of background :-
Soon after starting "the hobby", my wife gave me for my birthday 2 years ago, a Stuart kit of their simple horizontal engine (10H). She wanted to encourage me in my new workshop, bless her, and I slowly (very slowly) built it on my new lathe over the next 6 months. I made a bit of tooling first to get to "know" my first little lathe - with mixed success until I felt confident enough to start the engine proper.
I had no real problems with the kit contents, or castings and none in building it, apart from getting to know what some of the plan symbols and terms meant. I made a real bosh of the (built up) crankshaft at the first two goes - using Loctite, but eventually got it right the third time (my first essay at Silver soldering). Once I had got the valve timing properly set, it ran beautifully on compressed air at less than 10 p.s.i. I was really really happy that I could do it - my first ever build of any "proper" engineering item.
http://i336.photobucket.com/albums/n354/klank_photo/StuartH105.jpgSmall "Mill Engine Plant" (Display)
http://i336.photobucket.com/albums/n354/klank_photo/StuartH106.jpgSmall "Mill Engine Plant" (Display)
During the build, I had bought a number of books on building model engines, including Tubal Cain's pair on simple model engines and boilers. After much re-reading of these (his text gives a blow by blow recipe of how to make various boilers from scratch - excellent instruction), I decided it would be a good challenge to make a proper boiler and "steam" the engine.
The last project in his book 2 is to build a simple twin oscillator, mounted atop a sort of "cabinet" housed boiler - he called it "Wenceslas" - after a similar ready to run German model, by Bing, for sale in the 1930's I think? Marketed according to TC as "GROSSEDAMPFMASCHINE"!
The boiler itself is a sort of simple "Babcock" water tube design according to TC, but I was told recently it is properly known as a "Smithey's" (?spelling) boiler.
The main barrel is a small horizontal copper tube of 20swg - approx. 6" by 2" with 18swg end plates.
I flanged these from copper sheet on lathe turned steel flangeing blocks - great to learn a new skill - and quite satisfying to do. Needed to anneal the copper many times and go slowly and carefully with the hammering.
The boiler has a single gun-metal horizontal stay down the centre, screwed and silver soldered into bronze fittings at the centre of each end plate.
One end plate, to become the exposed boiler backhead, was marked out and drilled for a number of bronze bushes, turned up and tapped on the lathe, to accommodate the various fittings - pressure gauge, water gauge glass and clack valve for a boiler feed. With the boiler diameter being so small, the top fitting for the gauge glass had to be built as a small extension over the backhead - looks like the top of a periscope!
Steam take-off is from a copper dome atop the boiler barrel, with a suitably "Victorian" looking brass cap, into which goes the safety valve - made up surprisingly simply to TC's design.
I purchased the gauge glass fittings and clack valve from Reeves - a bit expensive, but the gauge glass lower fitting came with a blow-down valve as well - Reeves had run out of plain stock and gave me that "better" one as a freebie! (A very nice lady on the telephone at Reeves had a sympathetic ear when I said I could not afford the more expensive fitting - unusual and most welcome in today's financial climate!)
The final items necessary were a bronze bush for the filler cap, and two blind bushes for the support mounts of the barrel below the top plate of the "cabinet".
I also made a quick and dirty displacement lubricator, (shown in pic. of all the bits below), but I may well make a new one with a control needle to limit the oil flow - the exhaust steam could get a bit messy with too much oil I think - we shall see later.
Anyway - her is a pic. of all of the bits used to make the boiler.
http://i336.photobucket.com/albums/n354/klank_photo/WenceslasBoilerComponents001.jpgSmall "Mill Engine Plant" (Display)
At the time this photo was taken, I had only made three of the four water tubes, and they were not bent properly. I made a simple tube bending tool from a plan in a back copy of ME and made a fresh set of tubes which looked and fitted a lot better.
I also made a simple jig and bushes to align the gauge glass in the backhead.
http://i336.photobucket.com/albums/n354/klank_photo/WenceslasBoilerComponents010.jpgSmall "Mill Engine Plant" (Display)
Just as an aside here, you will note the glass "build plate" the boiler components are resting on :- this has proved invaluable in setting up all kinds of things. Its just a sheet of scrap plate glass (from a fish tank originally I think) placed on a similar sized sheet of blockboard, with a sheet of graph-paper as the sandwich filling. (I use metric sized graph paper, but imperial would be just as good). I ran a 3B draughting pencil over the thicker graph paper lines to make them stand out more. The whole sandwich is held together by linen gaffa tape around the edge. The surface is to all intents, truly flat, it is easy to clean - glue, paint, epoxy, Cyano etc. all "slice" off with a razor blade. The graph paper helps in alignment/parallelism and setting up items during fabrication. I used to use a rubbery/plastic/so called self-healing cutting mat, but the surface became unuseable very quickly.
Not a new idea but passed on here in case it might be of use to someone else!
It took a while to silver solder it all together. I found the use of rivets, loosely inserted around the end plates to be essential to prevent the ends from moving when soldering them into the barrel.
Here some pics of the finished boiler.
http://i336.photobucket.com/albums/n354/klank_photo/WenceslasBoilerComponents017.jpgSmall "Mill Engine Plant" (Display)
http://i336.photobucket.com/albums/n354/klank_photo/WenceslasBoilerComponents018.jpgSmall "Mill Engine Plant" (Display)
I made some blanking plugs to screw into all of the various bushes, and hydraulic tested the finished boiler. I had set the safety valve for 40 p.s.i. as per TC's design. Using a small hand-pump (an old Stuart one I think from the 1950's - acquired together with a small copper water tank from a friend), T piece and domestic water pressure gauge, filled the boiler to the brim and slowly pumped up the pressure, bit by bit, watching for weeps/leaks. One of the blanking plugs was not good, but some ptfe plumbers' tape did the job. I got it up to 90p.s.i. and it held rock steady for 10 minutes! It was strange to "feel" the boiler material actually moving and changing as pressure went up - I guess it was hardening up the previously annealed state of the copper.
I should have added - at present I do not intend to steam the affair publicly - I am building it for my pleasure. I may eventually take it to an exhibition, but only once it is working properly and safely. Being built to a "proven/tested design" and of small size/working pressure, I don't think there will be any problems, but I shall eventually have the hydraulic test re-done by one of the boiler testers at my local club - but that is a long way away.
On to the boiler cabinet.
The frame was made from brass angle strip to TC's design - I changed a few of the dimensions a bit, but it is basically the same. The boiler is suspended from the top plate, which has to accommodate all of the various top fittings of the boiler (dome/safety valve, filler cap, gauge glass top fitting).
By this time, I was getting fairly adept at scrounging "metal stuff/off-cuts" from local sources, and was very fortunate in getting some highly polished stainless steel sheet off cuts (marked as "heat resistant") from a local steel fabrications' business - they had just finished a huge commercial heating project of some sort, and let me have a free rimmage in their scrap bin. I also blagged some weird brass plated iron pipe which would make a good funnel (gas stack).
Stainless steel sheet is a bu**er to to drill and bore out, I discovered. Fortunately by that time I had got my little mill, which made the job somewhat easier. Even so, it was a difficult job to get the cut-out for the dome and associated steam take-off bored and finished. I destroyed one boring tool in the process by running it too fast and with insufficient suds.
Here is the basic frame and top plate, with cut-outs for the boiler top. The lower plate (drilled for secondary air - to aid the burner) inserted for temporary fitment/sizing.
http://i336.photobucket.com/albums/n354/klank_photo/WenceslasBoilerComponents024.jpgSmall "Mill Engine Plant" (Display)
TC's design originally included a steam control valve taken off the side of the steam dome. I have dispensed with this, and blanked it off on one side. I shall make a separate steam globe valve to be fitted further down the line.
Here is a trial fit of the boiler with safety valve and filler cap to the frame.
http://i336.photobucket.com/albums/n354/klank_photo/WenceslasBoilerComponents026.jpgSmall "Mill Engine Plant" (Display)
That is really as far as I had got up until earlier this year.
I got sidetracked a bit with building a Chinese Stirling engine, (posted separately), but thanks to all those kind souls who encouraged me to get it going it does finally work. I need to take a video of it running, but am not having much success with the digi camera here.
Back to this project:-
My next problem was to decide what form of firing the boiler would be best.
TC's original design was to use solid fuel tablets (Meta) in a tray.
He suggested in his book the option of using Meths/wick burners.
After a few experiments I discarded both ideas - messy, smelly, possibly dangerous, and largely uncontrolable.
My wife, bless her again, agreed I could have a propane gas/ceramic burner system as my last Christmas present - so I had talks with Maccsteam (usual disclaimer) about what size of burner etc. and he fabricated a small square burner with a propane tank, pipework and fittings - all safety certificated. The good bloke at Maccsteam felt the rate of water evaporation with even this small burner would be more than sufficient, given the design and size of the boiler, and to keep the gas turned down very low. He felt a hand pump to replenish the water via the clack valve will be essential during steaming. We shall see!
So this is the point I am at now.
I finished the cabinet plate-work, and after thoroughly de-greasing it all, spray painted it all black - using car engine enamel. I used about 4 coats, rubbing down gently in between. The side plates are "gilded" with three brass portholes, which also allow secondary air into the cabinet.
I am presently lagging the barrel with mineral board lagging - some off cuts from British Rail Engineering - used in lagging diesel engine (railcar) silencers. (Thanks Ian).
Here some pics (sorry about the crude editing - in haste) of the almost finished and lagged cabinet, with funnel/stack. There is an internal baffle plate behind the boiler barrel to help duct the burner gases along the underside of the boiler and up the stack.
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild023.jpgSmall "Mill Engine Plant" (Display)
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild019.jpgSmall "Mill Engine Plant" (Display)
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild020.jpgSmall "Mill Engine Plant" (Display)
I have also made the basic display board/base. Just mdf boarding, edged and covered with Slater's Plasticard, with a timber planked walkway down the centre - to add a bit of texture. The boiler cabinet, water tank frame etc. will be affixed to this by locating pegs let into pre-drilled holes - as per next pics. The plastic mock stonework etc. will be painted/textured later.
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild010.jpgSmall "Mill Engine Plant" (Display)
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild022.jpgSmall "Mill Engine Plant" (Display)
Interconnecting pipe runs could be a nightmare, but I have built the baseboard so that it is raised on dwarf walling, hiding a sort of "well" area - pipework can thus go down through suitable holes and run underneath the board and back up to where it is supposed to go. Waste pipes (steam, blow down and engine cylinder drain cocks) will be fed down to a sort of "sump" outlow pipe.
I am not sure yet, but am thinking that the main steam line from the boiler might be routed through the boiler cabinet, using the burner heat as a sort of "steam dryer" and then to the lubricator/engine. Not sure yet.
Similarly, the water feed from the pump could be routed the same way to "pre-heat" it?
I am also toying with fitting an oil separator to the exhaust line to keep things a bit cleaner.
Next to do is make another set of rollers for the pipe bender to accommodate the various sizes of pipe to be used.
I bought, off flea bay, a roll of 5/32 auto brake pipe - copper,nickle iron type - its already pre-annealed and silver solders well - a hell of a lot cheaper than buying small bore copper tubing from the usual sources.
Finally I have been making pipe fittings, olives and so on - pics to follow.
I made a form tool from a piece of old car rear leaf spring (gauge plate) I had blagged from our local garage scrap pile. Following a drawing/article in the Gauge O Guild handbook, found on line it gives a good plan of how to fabricate "globe" valves for steam/water control. The form tool cuts the globe shape in brass hex. Will post that next.
So - up to date now and will carry on a bit with more pics. as things develop.
As I said at the beginning - I am building this for my pleasure - its not all blinged up and not built as an "exhibition work", so please forgive any errors, but I have had fun and satisfaction getting this far - and I hope to finish the challenge of making the whole thing work.
Offline DeereGuy
    • D1 Adapter Solutions
Re: Small "Mill Engine Plant" (Display)
« Reply #1 on: August 06, 2009, 12:10:14 PM »
Bravo Peter, very nicely laid out post.  I used the plate glass while building my RC airplanes many years ago....thanks for bringing back those memories.:)
You now have me on the lookout for some boiler material so I can start on one this fall.  I will be looking for your suggested reference material and hopefully learn from you and the reference material what I need to know.
PS: I wish I had your style of writing.
« Reply #2 on: August 06, 2009, 12:58:19 PM »
Hi Peter
Your making a lovely job of that engine, those Tubal Kain books got me going with the hobby, I think he may be the main point of infection for  :proj:.
The main joy of this hobby as you said is that you do it for your own pleasure.
Thanks for the great write up and sharing your project with use look forward to next installment.
Have fun
Offline klank
  • Sunny East Devon
« Reply #3 on: August 06, 2009, 05:42:27 PM »
Bob, Stew - thanks to you both for such kind comments and encouragement.
I will do  some more over the next few days and post the results.
I can actually see bits of my work table now that have not seen day's morning light for many a long month - so I'm moving forward!
« Reply #4 on: August 06, 2009, 06:03:05 PM »
Have you seen his vids on UTube?
Offline CrewCab
« Reply #5 on: August 06, 2009, 06:04:40 PM »
Klank,
Thanks for a great write up of a cracking build  :thumbup:
CC
Offline Andy
« Reply #6 on: August 06, 2009, 06:25:43 PM »
Thanks for that Klank.  :clap: I like the life that steam and boilers bring to an engine.  Have made a couple similar to yours in the past (sadly now sold and no photos), guided by the same Tubal Cain (Tom Walshaw) books. However, a vertical one is planned, but don't hold your breath. I've had the copper tube sat here for about three years already.
I know where you are coming from with the gas firing, but don't you miss the smell of meths? Brings back happy 1960s Mamod memories for me.
From probably the smallest, dampest and most untidy workshop in Bradford, West Yorks, England, if not the world..
Offline klank
  • Sunny East Devon
« Reply #7 on: August 06, 2009, 07:51:19 PM »
Darren, CC, Andy - thankyou all, gentle men for the kind comments.
I am a bit thick here, but what U-tube video do you refer to Darren? I will certainly look it up.
Andy - yup, I rather got too much of the Meths smell when I "experimented" with a triple wick burner before being given my gas system. I did prove it could be an uncontrollable conflagration.
I could not find suitable wicking in our local ironmongers (yes it does use that name even today) so thought to try making "wicks" from porous Thermalite block slugs, set into brass holders, joined by a bottom pipe with a top cut slightly under each burner. I tried it out with a drip feed to the pipe and the smell became overpowering (holes in the pipe too big perhaps). I then noticed my right sleeve was getting very warm (an open meths flame is hard to see in bright light) - then it all got too exciting for words.
The porous plugs, holders, pipe etc. are now useful landfill.
I never had a Mamod in those days of long grey shorts and scabby knees - but I do remember the smell of a Mills engine running on Diesel fuel (getting off topic here) - showing our age - but happy days!
« Reply #8 on: August 06, 2009, 08:01:33 PM »
Just for those that have trouble obtaining suitable wicking material.
If you go into your local DIY outlet and see if they sell those garden spirit lamps that you stick in the ground, they look like a length of bamboo with a glass bottle on the top.
You should be able to buy the spare wicks for those items, and the ones we have here are made of fibre glass 'string'. I have used it for all sorts of meths burners, including my flame licker. It lasts forever, once the glass ends have melted and fused, it just doesn't seem to get any shorter.
Very nice build BTW Klank.
Offline Andy
« Reply #9 on: August 06, 2009, 08:07:03 PM »
I had a look for Tubal Cain videos on YouTube. There are quite a few but they seem to have nothing to do with the Tubal Cain that most of us will know (at least in the UK). This was Tom Walshaw, who died a good while ago.
The guy who has done the videos that I saw sounds like an American and appears to have assumed the name.
« Reply #10 on: August 06, 2009, 08:28:01 PM »
Ah, well that's be rooted out as a newby then, I didn't know he wasn't american.... :doh:
That sure does seem an odd way to go about things though, taking on someone elses pseudonym... :scratch:
« Reply #11 on: August 06, 2009, 08:55:27 PM »
Wow Peter... Very nice post. Anxious to see it run.
 :clap: :clap: :clap:
« Reply #12 on: August 07, 2009, 01:30:55 AM »
I looked up Tom Walshaw's pseudo, when I first started to read about him, well before internet days.
It is mentioned in a passage from Genesis in the Bible, and is a very apt name. I suggest you have a look yourself.
« Reply #13 on: August 07, 2009, 02:23:09 AM »
Peter,
Marvellous post. Very well described, & shown.....  :clap:
Looking forward seeing it run successfully.  :thumbup:
Offline klank
  • Sunny East Devon
« Reply #14 on: August 07, 2009, 08:24:27 AM »
Thanks David.
To avoid giving the wrong impression - I feel I ought to add to the first posting of this project that none of the ideas for it and those I am considering doing are mine.
A bit like "Japanese" auto engineering - I have taken some of the best ideas that suit my abilities from other disparate sources and cobbled them together.
The overall "display" ideas I gleaned from a couple of old articles in back issues of ME. The ideas for steam drying, feed water pre-heating, boiler/pipe fixtures and so on etc. from books.
There is a lot to be gained from reading not only TC's books (aimed at the beginner) but also three more :- Model Loco Boilers - Martin Evans; and the two by K N Harris - Model boilers and Boiler Making and Model Stationary and Marine Steam Engines.
All of these appear superficially a bit "dated" due to when they were first published (over 30 years ago?) but are really excellent and well worth tracking down. The authors treat you "old Skool" - i.e. that you are intelligent, can read and understand basic scientific principles and have some practical abilities.
In them I discovered a whole host of ideas, sketches and formulae covering virtually everything to do with model steam "stuff". I understand they are still available over here as re-prints- quite cheaply too - I got mine second hand off Amazon.
To add to Bogs worthy comments re - Tubal Cain - look up Genesis Ch. 4 v22 - "Son of Zillah, 'forged all kinds of tools out of Bronze and Iron'.
Some say, the Patron of Engineers!
(the name also crops up in the opening stanza of an old hit record of the '70's? - as a loco driver - "The Night They Drove Old Dixie Down")
« Last Edit: August 08, 2009, 07:10:25 AM by klank »
« Reply #15 on: August 07, 2009, 10:53:45 AM »
That is going to look splendid .. well done!  :clap:
« Reply #16 on: August 07, 2009, 12:54:04 PM »
All those years later......... He`d gone & changed his name to Virgil!   :lol: :lol:
Offline klank
  • Sunny East Devon
« Reply #17 on: August 10, 2009, 08:54:28 AM »
Back to the build.
I spent a long time shuffling the various items around the display board, once the boiler position was fixed.
Trying to think ahead, it is important that  1. everything that needs to be accessible can be reached as easily as possible without affecting anything else - i.e. cylinder drain cocks, pump handle, control valves and 2. The main steam pipe feed is kept as short as possible for thermal loss reasons.
With the layout shown, i think it gives the best compromise. The steam pipe, taken off the dome on the side closest to the chimney will be fitted with a right angle globe control valve, and the output then fed back into the boiler casing - possibly through one of the port-holes, and run through the internal space next to the boiler barrel thus keeping it nice and hot. If I can get it right, the pipe will emerge at the bottom of the cabinet, nearest to the engine cylinder, and enter the lubricator, and thus to the engine valve chest. Access to the drain of the lubricator may be difficult, but I am hoping to mount it on a small stanchion to raise it enough to get at the drain cock.
The cylinder drain cocks will be operated by a hand held "tool" - long thin brass rod with a forked end.
(Sorry about photo quality - not my strong point)
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild2005.jpgSmall "Mill Engine Plant" (Display)
I temporarily fitted the burner/lpg. tank and gauge glass furniture to the backhead (using a steel off cut rod in place of the glass) to check clearances and to see where the blow down pipe will go.
I decided to mount the feed water tank and pump on the other side of the board - I didn't want to have to brush my fingers against anything else (hot or not) when using the pump.
The pump and tank is an old Stuart-Turner item I think from the '50's?
The tank frame is simple brass angle, soft soldered and sprayed with car engine enamel.
I think I'll leave the pump in its original (sick) green enamel. Unfortunately, the unions on this are very large and crude, hence the size of my brass fittings. (The output one is yet to be finished).
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild2009.jpgSmall "Mill Engine Plant" (Display)
Next to the pump is a "trial" length of pipe and olive hidden by the screw fitting, bent using a simple pipe bender I built to a beginner's design by Stan Bray found in an old issue of ME. I used this first to bend the water tubes in the boiler build.
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild2003.jpgSmall "Mill Engine Plant" (Display)
I have "cut" a set of (aluminium) rollers to the various sizes of brass pipe to be employed. I made simple "form tools" from stainless steel rod which I happened to have of the same diameter as the pipe (I don't have any stocks of Silver steel at present!). Rather like making D bits, but with a radius ground on the tip to match the radius of each diameter of pipe.
A small "production run" of pipe olives was made.
To encourage any who read this and don't know how to do it - here goes.
This method was given to me by someone else and has also been referred to elsewhere on this site - its not original, but is really easy and works!
For the (water) pipe shown - which is a length of 3/16" (4.76mm) brake line tubing - I used 1/4" brass rod in the three jaw, end faced, centre drilled with my smallest bit, and deeply drilled to about 11/2" with a 3/16" bit in the tailstock drill chuck - keeping the speed fairly high. Swap the drill bit for a length of 1/8" steel rod and introduce it into the bore. I parted off the olives at about 3/16" lengths using a carbide tipped tool set at a suitable angle to the brass so as to give a nice cone at the "cut" and the olives pop off onto the steel rod quicker than shelling peas.
Change the stock dimensions to suit other diameters of piping.
In the past, I have silver soldered the olives onto the ends of the prepared/cleaned/fluxed pipe (after adding the screw fitting - yes?) using a little collar of fine Silver solder wire around the inboard joint. Heat the pipe gently but NOT the olive itself and as the heat is drawn up to the olive, all should melt/flow. With my luck, I often knock the joint in passing and dislodge the  solder wire - all very fiddly. I am now using Silver solder paste - comes in a small hypodermic syringe. The goo is pre-fluxed. Makes the process much quicker and easier.
Don't forget to "paint" a barrier ring around the copper tube behind the olive/joint with wax pencil or (I use) typo correction fluid from a pen. This stops the solder from spreading where you don't want it.
I will try and post a couple of pics of this process if it helps anyone? (Don't want to overload this thread with too many things which are possibly too basic for most.)
The water valve cock on the output of the tank looks a bit naff to say the least - but it is my very first effort - done from a recipe in a back issue of ME. There are many many recipes available from that source or published on the net.
I recently came across the Gauge O Guild handbook, published on the web which gives an excellent instruction on making Globe control valves and a globe form tool.
Clearly Globe Valves look better, and so I have had some fun trying to make one.
I had blagged a length of old car rear suspension leaf spring from a local garage - gauge plate!!!
I sliced out a length for the tool using my chop saw (Bosch 1mm thin ?carbon fibre? blade - cuts anything virtually).
This embryo tool bit then needs annealing. It was suggested to me by my Yorkshire Rabbi, that the best way of doing this was to hang it in the wife's oven during the cooking of the Sunday roast and let it cool down in the oven afterwards. Not a chance!! The other usual way is to put it in the embers of a fire and leave it to cool therein overnight. Nope - no fires in this house and no bonfires allowed by Local Authority.
In the end, I made a little cubical hearth with 6 of those heat resistant mineral fire bricks, put the tool blank in the bottom, left the lid off and nuked it with my Propane torch for a while - leaving it cherry red for a few minutes. Put the last brick on top and left the whole thing to cool.
Now I do not know if it worked properly, but after it had cooled, I drilled the blank fairly easily and cut it to length and file the ends to a sharp finisgh with no problems. Then harden and temper to straw in the usual way.
http://i336.photobucket.com/albums/n354/klank_photo/PlantBuild2025-1.jpgSmall "Mill Engine Plant" (Display)
And that is the result.
I tried it on a scrap length of brass bar, turning at about 1000 rpm, and it worked like a dream.
I haven't tried it on brass hex yet for the next valve, but will probably "knock the corners off it" first with a standard lathe tool before forming the globe proper.
Will post more later.
Offline Andy
« Reply #18 on: August 10, 2009, 11:13:08 AM »
That's looking really good. Are you going to have anything for the engine to drive?
I can confirm that your method of softening hardened steel worked for me too. Lacking a coal fire, I carved out a 'cave' in a soft firebrick (the white sort, cadged from the local crematorium) and did it exactly the same way to soften the frizzen of a flintlock musket that needed re-profiling.
« Last Edit: August 10, 2009, 11:24:40 AM by Andy »
Offline klank
  • Sunny East Devon
« Reply #19 on: August 10, 2009, 11:25:57 AM »
Thanks Andy.
Hmm - what to drive - I have to say I havn't really considered that. I am just hoping to get it all to run leak free first, but you do have a point there.
I cut grooves in the engine flywheel to make it look more prototypical, and add "texture" to an otherwise bland surface, so I suppose a sort of belt drive could be taken off here to a line shaft? But space is a bit limited - must think it over more - unless anyone has a "good idea"?
Offline DeereGuy
« Reply #20 on: August 17, 2009, 08:00:45 PM »
Peter after seeing the detail on you boat I can hardly wait to see the rest of this.  You always pay so much attention to detail when your building something.  Here you have building a total all in one spot stream system with it's own reservoir.  Good job and please continue on...
« Reply #21 on: August 18, 2009, 02:20:06 AM »
Coming along nicely Peter,  :thumbup: you'll have a cracking display when you've finished, well explained to.
Have fun
Offline klank
  • Sunny East Devon
« Reply #22 on: August 22, 2009, 12:07:15 PM »
Thank you all for the encouragement and kindness.
Not been able to do much these last weeks - got personal problems with me old Dad.
Anyway - done a bit over the last two days - working on a steam control valve and lubricator.
I appreciate this is not, by any means, big stuff, but making little fittings in brass I find very relaxing and satisfying - a change from having-at big lumps of steel in complicated ways.
My first plan was to make a separate steam control valve and displacement lubricator - the latter being adjustable, based on the type used in the Boarderer/Marcher marine engines. However, whilst idly flicking through the pages (yet again) of TC's book on model steam engines (Vol 1), I saw a photo of a combined steam control valve and lubricator - all in one. It is part of his design for "Hercules" - a steam powered crane. It is a nice, elegant looking, compact unit, doesn't seem difficult to make and of course is backed by TC's step by step instruction - useful for  those of us with minimal confidence/experience.
I decided to have a shot at this - materials were (just) available from my little stocks.
Here are the main component parts - I did not take pics. of the machining - its all very straightforward.
The valve spindle itself is stainless steel, all else is brass hex and a bit of brass bar.
http://i336.photobucket.com/albums/n354/klank_photo/Lubricator-ValveBuild005.jpgSmall "Mill Engine Plant" (Display)
The main body should be of brass square stock - but I don't have any, so used hex and turned off the corners a bit at each end to make it look less "linear".
The spindle, gland nut, threaded insert and inlet fitting (facing the camera at the left hand end) need no further word.
The outlet, at the bottom I modified from the design a little, to fit my engine - a simple brass round fitting, silver soldered and let into the body and a short length of copper pipe (with nipple and nut fitted first) soldered into the fitting.
The oiler itself is incredibly simple in operation - in fact it is hard to understand how it works at all!
According to TC, it is originally a design by a really old time engineer who went under the name of "LBSC" - a.k.a. Curly - who published a huge amount of model engineering material from the 1930's up to the 1960's (approx - not sure).
Going off topic - for those who don't know - LBSC stands for the (late) London, Brighton and South Coast Railway (absorbed into the Southern in 1924). He had a love of that grand old company and published plans for model engineers to build one of its locos in the 1930's. One of the first perhaps.
Back on topic :-
Anyway - TC said that this lubricator design has worked for him for over 25 years!
All it is is an oil reservoir, fitted with a close fitting screwed cap (no air hole in the top), and the waisted bottom drilled with a number 70 drill - a tiny pin hole - situate exactly opposite the steam outlet hole from the body. And thats it!
Its not an obvious displacemnt lubricator. The only way I can visualise it working is through the "venturi" effect (like a carburettor bleed hole) of the steam rushing past the hole and drawing a mist of oil out as it goes by.
There is no means of blocking the hole, and thus I don't know if the oil will ooze out when not in use.
I appreciate that steam oil is extremely thick and viscous (is it Rape-Oil?), so maybe it won't drip through such a tiny hole?
Drilling that hole gave cause for thought. It has to penetrate approx 5mm of brass. After much thought and seeking advice, speed of rotation seemed to be the crux of the matter. In the past I have had conspicuous failures and flops when trying to drill holes 1/16" or less and ended up with useless items with broken drill bits embedded in them.
I had made some time ago a small drill adaptor to fit my tailstock, lever operated (sliding chuck) with a good quality pin chuck on the end. Girding up my loins, I put my (only) number 70 drill in this lever/tailstock chuck adaptor with only 2 mm projecting, and cranked up the lathe to its max. - over 2000 rpm on mine (never done that before!) - this speed, noise and some vibration does concentrate the mind!
I just touched the end of the drill bit against the brass bar end (all carefully surface finished and just kissed with my smallest centre drill bit first) and a tiny sliver of brass curled off. Great - I carried on very slowly, wood-peckering the drill in and out/cleaning the swarf off with a little paintbrush and slowly extending the length until it broke through. Very satisfying.
http://i336.photobucket.com/albums/n354/klank_photo/Lubricator-ValveBuild004.jpgSmall "Mill Engine Plant" (Display)
http://i336.photobucket.com/albums/n354/klank_photo/Lubricator-ValveBuild003.jpgSmall "Mill Engine Plant" (Display)
I then silver-soldered everything together - using silver solder paste (as used by hobbyist jewellers). I found using this material in these operations to be a revelation. No bits of silver solder wire to get and keep into position, and no fluxing. Just make sure the joints are clean, and annoint them with the (brownish looking) goo. Add heat from the torch with my smallest nozzle, play the flame gently near the joints and wait for the silver colour to show and run into the joints - easy peasy.
No doubt I may find a dud joint when I steam it, but the silver collars around the joints look o.k.
And here it is mounted (temporarily) on the engine.
http://i336.photobucket.com/albums/n354/klank_photo/Lubricator-ValveBuild001.jpgSmall "Mill Engine Plant" (Display)
I deliberately made the valve spindle/handle "over long" to allow for my hamfisted fingers and to bring the control to an easy point to reach, because the steam inlet - pipe position fixes the whole affair a bit back from the edge of the display board.
I shall run the steam line from the dome off-take, via a globe valve and then back into the boiler cabinet for a turn, down by the hottest part, so as to act as a "steam dryer". In these circumstances, I fancy cylinder lubrication becomes more essential.
As I have said before - this is all "basic work" for experienced engineers, but I do hope it may help a few to have a go at "steaming" something.
My garage/workshop shall now be known as the "Dampf-Haus".
More to follow when I get time to myself.
« Last Edit: August 22, 2009, 12:17:49 PM by klank »
« Reply #23 on: August 23, 2009, 02:30:25 AM »
Lots of very good info/ experiences there Peter!  :thumbup:
I`m going to have a look for some of the jeweller`s silver solder......
Offline klank
  • Sunny East Devon
« Reply #24 on: August 23, 2009, 07:03:42 AM »
Hi David
I sourced my paste from CupAlloys :- http://www.cupalloys.co.uk/ (usual disclaimer).
I had checked around for the "best" value deal for silver solder paste, and found their prices very good - I bought a 10cc syringe of the stuff - delivery was very quick too, and the bloke at the end of the 'phone was extremely helpful - giving advice on soldering technique when using this stuff in model engineering applications.
