Author Topic: Making rectangular plate in to a round plate on the mill.  (Read 16100 times)
Offline DeereGuy
    • D1 Adapter Solutions
« on: August 20, 2009, 07:48:06 PM »
Well gang, I am finally getting around to posting a small project I did for Weston.  I won't tell you why he needed this.  That's his job when he gets ready. :)
Weston had handed me a piece of 1/4" plate rectangular in shape and ask me if I would make it round for him.  I, of course said, "you bet".  I thought about first trimming the corners off to make an octagon shape to start out, then take it over to the lathe.  Then I thought....hey I can use my face plate on the mill  :beer:  So that's what I did.  The rotary table was already zeroed from the last part I did so I was able to skip that step.  Starting out by clamping it first to the faceplate so I could drill two holes to put 2 bolts through
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/WestonByeRoundPlate/IMG00198-20090816-1253.jpgMaking rectangular plate in to a round plate on the mill.
then I set the edge of my end mill .02 outside of what I wanted for a final dimension I began to make my roughing cut.  I used carbide 3/4" fine toothed roughing mill and started to take a .250 deep cut.  I went as far as you see here and decided I needed to back it down to .100.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/WestonByeRoundPlate/IMG00200-20090816-1334.jpgMaking rectangular plate in to a round plate on the mill.
Here is a shot of the finished rough cut.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/WestonByeRoundPlate/IMG00201-20090816-1402.jpgMaking rectangular plate in to a round plate on the mill.
I placed in a regular ¾” end mill to make take it to the final dimension.  I don’t know about you guys but I have found that the side cut of a rough cut end mill is really rough…..hmmmm…..maybe that’s why they call it “rough cut” :beer:.
Here is how the part turned out.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/WestonByeRoundPlate/IMG00204-20090816-1515.jpgMaking rectangular plate in to a round plate on the mill.
Weston picked the part up from me this evening and will continue on later with the saga of this now round object.)…Stay tuned.
Re: Making rectangular plate in to a round plate on the mill.
« Reply #1 on: August 20, 2009, 08:09:12 PM »
Nice one Bob. This works great if you can put holes in the round part, but dosen't work good if you can't. Still it's a neat idea.
How the heck would you have held that part in the lathe anyway? With a faceplate? Same as on the mill? And then again it'll only work if you can put holes in the round part or do you have a secrete way of doing it?  :D
« Reply #2 on: August 20, 2009, 09:01:54 PM »
If you are very careful Bernd, you can friction turn large round parts without having any holes in them.
Very similar to how I turn flywheel blanks, but instead of putting a centre drilling in the part, you make up a block with a centre drilling instead, and use that between the rotating centre and the part to be turned.
« Reply #3 on: August 20, 2009, 09:45:19 PM »
In my limited experience I have already discovered that it is important when turning a disc from a plate that the outer piece being seperated from the disc is firmly attached to the face plate.  I have a nice steel pretzel to remind me of that lesson. :coffee:
Offline DeereGuy
« Reply #4 on: August 20, 2009, 10:02:00 PM »
Luckily in this case I could drill the holes.  If I couldn't have then I would have made my first attempt at doing it with two sided tape and a tiny center point to use the live center in the tail stock.  Also I would have trimmed most of it off with the band saw leaving very little to do on the lather.  The cut would have been light and I would have spent a whole lot more time doing it.  As it is I have about 20 minutes start to finish.  Oh..yea and very low rpm until I had it completly round..then maybe kick up the rpm some...
Offline websterz
« Reply #5 on: August 22, 2009, 06:08:39 PM »
What size is your rotab? It's a Grizz...I can tell that by looking. It looks just like mine. :D
 :med:
Offline DeereGuy
« Reply #6 on: August 22, 2009, 11:33:57 PM »
It's a 6 inch that I bought used about 5 years ago and I have no idea who the manufacturer is.
