Author Topic: Machine Vice  (Read 49451 times)
Offline PhiberOptix
  • Adapt Improvise and Overcome
Machine Vice
« on: September 09, 2009, 11:48:12 AM »
This is the stage I was at Last night, basic stuff just milled out a large portion and a quick lick with a fly cutter
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0500.jpgMachine Vice
todays efforts
milled a slot in the side and center drilled, pilot drilled, and 8mm drilled and couter sunk the holes
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0502.jpgMachine Vice
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0503.jpgMachine Vice
milled a slot thru the base
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0504.jpgMachine Vice
then 5mm slot for running guides for the back jaw
this is as far as i got
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0506.jpgMachine Vice
SKYPE - GrimsbyDragons
Offline Andy
Re: Machine Vice
« Reply #1 on: September 09, 2009, 12:02:16 PM »
Looking good there.  :headbang:
That's a bit of a chicken and egg situation I suppose - helps if you've got a machine vice in order to make a machine vice. :scratch:
From probably the smallest, dampest and most untidy workshop in Bradford, West Yorks, England, if not the world..
Re: Machine Vice
« Reply #2 on: September 09, 2009, 02:13:22 PM »
That is starting to look very nice. Very professional looking. Keep up the build log!
Re: Machine Vice
« Reply #3 on: September 09, 2009, 09:08:40 PM »
That's looking good, I'd be very interested to see the next stages... :thumbup:
Offline arnoldb
  • Windhoek, Namibia
Re: Machine Vice
« Reply #4 on: September 10, 2009, 02:13:24 AM »
Good going on that vice Andy  :clap:
 :beer:, Arnold
Re: Machine Vice
« Reply #5 on: September 10, 2009, 03:38:07 AM »
Nice 1! Looks like you have  :proj:
I had one of those sort of vices many moons ago when I had a little sherline milling machine. The vice was brilliant! The machine was really accurate to give it its due but a just for small things! Didn't have a quill feed either which limited it a bit!
Offline PhiberOptix
Re: Machine Vice
« Reply #6 on: September 10, 2009, 12:59:27 PM »
turning the chamfer on the mushroom ring now need to drill it and part it off
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0513.jpgMachine Vice
Fly cut finish on back of rear jaw ready for drilling for locking mechanism
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0514.jpgMachine Vice
vice and parts for locking mechanism so far
(needs a longer caphead the biggest i have it too short)
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0518.jpgMachine Vice
once I get a longer caphead tomorrow i can give the vice a final fly cut
also thinking of making some alternative jaws in brass and stainless to fix to the existing ones
« Last Edit: September 10, 2009, 01:02:57 PM by PhiberOptix »
Re: Machine Vice
« Reply #7 on: September 10, 2009, 03:05:55 PM »
Looks great, I found my vice very accurate and possible to get a high clamping force. good design as it's always pulling the jaw down as well.
Offline sorveltaja
Re: Machine Vice
« Reply #8 on: September 10, 2009, 03:46:59 PM »
Interesting project. Is that aluminum you are working on?
Offline PhiberOptix
Re: Machine Vice
« Reply #9 on: September 10, 2009, 04:12:26 PM »
Yes its Aluminium (Aircraft grade) It is to be used for Aluminum only until I make some Brass and Stainless Jaws for her
I may even have her anodised
regards
Re: Machine Vice
« Reply #10 on: September 10, 2009, 04:13:19 PM »
Just wondering, how are you going to clamp it down to the table?
Offline sorveltaja
Re: Machine Vice
« Reply #11 on: September 10, 2009, 04:43:04 PM »
Is there spesific english language term for that kind of machine vice? I'm willing to build one(two, maybe three) small(er) versions for special purposes.
Offline PhiberOptix
Re: Machine Vice
« Reply #12 on: September 10, 2009, 04:51:37 PM »
I'm not lol, its going sideways in the vice it was made in
but...
I guess you can put longer pins thu the side holes and clamp down on them
or mill clamping slots in the ends & sides
I have seen blocks with pegs in the side just for clamping these down
but mines going in another vice so you adapt/mod your to you needs
regards
Offline PhiberOptix
Re: Machine Vice
« Reply #13 on: September 10, 2009, 05:07:37 PM »
I have only ever know them as a machinist's vice I am unaware of any specific name
I'm sure it probably has one I just dont know it, maybe someone could enlighten us
Re: Machine Vice
« Reply #14 on: September 10, 2009, 06:07:12 PM »
First ones on here
http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices
I use a 1" one all the time for holding small stuff in my larger vices.
Re: Machine Vice
« Reply #15 on: September 10, 2009, 07:04:35 PM »
I've seen them called tool makers vices before, think they are all ground, high precision things though.
Offline DeereGuy
    • D1 Adapter Solutions
Re: Machine Vice
« Reply #16 on: September 10, 2009, 07:41:22 PM »
Andy, nice project you have started there.  I am been kicking around building one also probably this fall when things slow down a bit.  keep up posted with your build..:)
Offline PhiberOptix
Re: Machine Vice
« Reply #17 on: September 11, 2009, 11:33:50 AM »
The starts of a small vice been fly cut
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0524.jpgMachine Vice
sorry go carried away and forgot to take pics
All done except the polishing
BIg brother and the little one
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0526.jpgMachine Vice
Offline PhiberOptix
Re: Machine Vice
« Reply #18 on: September 12, 2009, 08:26:51 AM »
and after a quick polish the baby of the two vices vice looks like this
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0537.jpgMachine Vice
Re: Machine Vice
« Reply #19 on: September 12, 2009, 08:28:54 AM »
I do like your vices  :lol:
Esp the dinky one as I could do with one of those. I have some bars of cast steel I may have a go with......on top of all the other things I want to do of course....... :doh:
Offline sorveltaja
Re: Machine Vice
« Reply #20 on: September 12, 2009, 01:44:09 PM »
Is there some kind of T-piece, where tightening screw goes?
I have seen that kind of vices only on pictures.
Offline Gerhard Olivier
Re: Machine Vice
« Reply #21 on: September 12, 2009, 02:01:53 PM »
There is a plan on
http://www.projectsinmetal.com/free-metalworking-project-plans-toolmakers-screwless-vise-mill/
Hope this works / helps
Gerhard
« Last Edit: September 12, 2009, 02:03:31 PM by geroli »
Guernsey
Channel Islands
Offline PhiberOptix
Re: Machine Vice
« Reply #22 on: September 12, 2009, 02:37:16 PM »
yes there is a 'T' piece
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0538.jpgMachine Vice
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0540.jpgMachine Vice
http://i628.photobucket.com/albums/uu7/phiberoptix/000_0539.jpgMachine Vice
All I used was a slice of round stock drilled and taped to match the locking cap head
and an off center hole thu the side for the locking pin (in this case a 1mm wire)
also there is a slot milled in the underside of the jaw to locate the slice into
to stop it rotating whilst putting the pin thu
There are plans for this vice but i did not use any
Hope this helps
The same method was used in her bigger sister
Offline sorveltaja
Re: Machine Vice
« Reply #23 on: September 12, 2009, 03:18:48 PM »
Thanks for the replies! They helped me to understand the mechanism :beer:.
Offline arnoldb
  • Windhoek, Namibia
Re: Machine Vice
« Reply #24 on: September 12, 2009, 05:29:54 PM »
Good going Andy  :clap: :clap:
And to think you groaned about Tiny being small  :lol: - come to think of it, have you found a compressor yet ?
 :beer: Arnold
