Author Topic: Improving the ball cutter  (Read 16524 times)
Offline Gerhard Olivier
« on: September 19, 2009, 08:37:59 AM »
As I will need do make a couple of ball  + ball handles I decided to improve the ball cutter
http://i608.photobucket.com/albums/tt161/geroli/Madmodder/Mods002copy.jpgImproving the ball cutter
This is sold as a trailer bearing for about 2 quid with delivery -ebay
http://i608.photobucket.com/albums/tt161/geroli/DSC_0002-2.jpgImproving the ball cutter
SO i made a cut in the base to house the ring of the bearing leaving the center stub to be able to lock with m8 allen bolt later.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0003-2.jpgImproving the ball cutter
Note deeper section for the bearing cage to clear.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0004-2.jpgImproving the ball cutter
Making the base of ALi is stead of the mild steel plate this is so that the top-slide holder is the same as the ball holder and the same studs could be used simly swapping one for the other.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0005-3.jpgImproving the ball cutter
http://i608.photobucket.com/albums/tt161/geroli/DSC_0007-1.jpgImproving the ball cutter
http://i608.photobucket.com/albums/tt161/geroli/DSC_0008.jpgImproving the ball cutter
At the bottom of the base I put 1 angular contact bearing ( skateboard) to allow the bolt to run on bearing as well - in theory that would mean I can tighten it all up well and still have it rotate freely
http://i608.photobucket.com/albums/tt161/geroli/DSC_0009.jpgImproving the ball cutter
This shows the clearance so that all the presure is just between the two bearings.
http://i608.photobucket.com/albums/tt161/geroli/DSC_0010.jpgImproving the ball cutter
End result A ball cutter that looks very much the same but works a lot better.
http://i608.photobucket.com/albums/tt161/geroli/BallTurner.jpgImproving the ball cutter
Gerhard
Guernsey
Channel Islands
Offline Mustang
Re: Improving the ball cutter
« Reply #1 on: September 19, 2009, 09:24:36 AM »
Nice mod.
I'm going to have to make one of those if I can get it to the top of my Round-to-It list. :)
« Reply #2 on: September 19, 2009, 09:40:45 AM »
Nice mod.
Yep!  :clap:
Me too!  ::)
« Reply #3 on: September 19, 2009, 01:55:00 PM »
Nice mod.
Follow these 3 simple steps and you will have it finished in short order. :coffee:
Step 1.  Place item in question on bottom of Round-to-It list. When writing it on be sure to write it backwards and upside down (trust me on this). :med:
Step 2.  Turn Round-to-It list upside down. :scratch:
Step 3.  Get off your butt and start working on your Round-to-It list before your SHMBO comes along and add something above this which will effectively trump this. :poke:
There Andy, that wasn't so hard was it. Quicker than you thought. :ddb: :ddb:
« Reply #4 on: September 19, 2009, 02:30:41 PM »
Thanks chaps
This has made such a differance. It worked fine before but it took some power to rotate now it is just such a pleasure to work and it is easier to attach to the lathe as well.
Just cut a 40 x 20mm wheel with a 10mm radius as seen in cross section ( a round flat ball) and drilled 8 -- 5mm holes at 45 degrees apart and tapped them all M6 and broke the tap off deep in the last hole.       :(MAYBE I SHOULD HAVE MADE A TAPING WITH CARE GADGET INSTEAD :(
Gerhard
Guernsey
Channel Islands
Offline arnoldb
  • Windhoek, Namibia
« Reply #5 on: September 23, 2009, 04:22:01 PM »
Nice mode on the ball turner Gerard  :beer:
 :hammer: don't you just hate it when you don't have that tapping gadget yet  :scratch:
 :beer: Arnold
« Reply #6 on: September 23, 2009, 07:17:02 PM »
Nice work Gerhard :thumbup:, I feel I will soon be looking in my box of old tapered bearings!
« Reply #7 on: September 23, 2009, 11:21:50 PM »
Pretty smooth mod you got there!
 :mmr:
« Reply #8 on: September 24, 2009, 03:18:28 AM »
Thanks chaps im buzy designing one for my wood turning lathe.
It is a bit more difficult as there is no cross slide but it should be possible.  I want it to have a 6 inch max down to 1 inch min radius
The scrap bin has a lot of say in the design
Gerhard
Guernsey
Channel Islands
