Author Topic: Dog Rough Key Way Slotter  (Read 30099 times)
« on: September 25, 2009, 12:35:48 PM »
OK Chaps this is not going to be pretty so any one of a nervous nature look away.
When I did the key way slot in the pulley for my sub spindle I could tell I wasn't doing my machine any good I was putting a lot of load on, and as I've decided to remake the pulley, I'm not too happy with the fit, I realy need another way of cutting the Key Way. As I'm also suffering from project creep like Bernd, this is going to be a no frills job it'll look ugly but all I want, is for it to do the Job  :hammer:.
OK gather the material together and put a rough plan together
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2458.jpgDog Rough Key Way Slotter
Bits of garage door Thanks Ralph  :thumbup: (where is Ralph  :scratch:) and 20mm and 30 mm bar and a off cut from a shaper job some one was doing that I piced up at the scrappy.
First job drill some holes in the channel for M8 cap screws, this is going to be the base.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2461.jpgDog Rough Key Way Slotter
Those garage door bits make great clamps Ralph got any more  :D
Bolt the bit thats to be the ram guide to the base with M8 cap screws. sorry no pics of drilling the guide.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2463.jpgDog Rough Key Way Slotter
Drill and tap M8 a chunk of 30mm bar for the pivot.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2464.jpgDog Rough Key Way Slotter
The ram guide needs to drilled on centre: easyest way set it up square on the the saddle, bolt it up, and get it positioned and lock up the cross slide.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2465.jpgDog Rough Key Way Slotter
Centre drill it
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2466.jpgDog Rough Key Way Slotter
Then drill it with 8mm pilot then 13mm pilot and finish of with a 20mm drill
The channel  was springing back so rigged up a jack to stop it. I may add some corner bracing.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2467.jpgDog Rough Key Way Slotter
Putting the 20mm drill through. I stopped the lathe and removed the swarf using a pair of pliers, it was as sharp as a razor, handling swarf is the only job I wear gloves for.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2469.jpgDog Rough Key Way Slotter
Hole drilled.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2470.jpgDog Rough Key Way Slotter
Should get it finished tomorrow thats if the boss leaves me alone, herd her mumbling about going to the Traford Centre (Moll)  :(
Have fun
Re: Dog Rough Key Way Slotter
« Reply #1 on: September 25, 2009, 12:39:20 PM »
I cut a keyway on the lathe once and agree it does give one a feeling that they should be shot..... :lol:
Yes, where is Ralph, I was only thinking that yesterday..... :scratch:
Offline CrewCab
« Reply #2 on: September 25, 2009, 02:20:03 PM »
I'd been wondering but he popped up this morning on a thread .................. probably been on holiday .......... again  :coffee:
CC
Sorry Stew .............  :bang: .................. <edited to add> ............. I'm quite intrigued by this "quick and dirty" slotter  :thumbup:  ........... press on  :dremel:
« Last Edit: September 25, 2009, 02:22:17 PM by CrewCab »
« Reply #3 on: September 27, 2009, 11:15:04 AM »
Ok home run
Maching the ram to size between centres
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2472.jpgDog Rough Key Way Slotter
Putting an 8mm slot in the end of the ram.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2473.jpgDog Rough Key Way Slotter
This end was also tapped M8 and one arm open up with a M8 clearance drill to take the pivot pin.
The other end was drilled down the middle 10mm and a M5 cross hole tapped to grip the tool.
The back link:- again this was slotted 8mm and cross drilled and tapped M8 to take the pivot pin, a flat was put on the other end with another 8mm pivot pin hole. Made this bit complete then parted it off.
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2474.jpgDog Rough Key Way Slotter
Made a tool holderthis was just a length of bar with a 6mm cross hole, with a M5 clamp screwe down the middle.
This is the tool on the lathe.
 Forward
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2483.jpgDog Rough Key Way Slotter
Back
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2482.jpgDog Rough Key Way Slotter
You can see the swarf shaved off
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2481.jpgDog Rough Key Way Slotter
This is the result of the trial run on the scrap pully
http://i431.photobucket.com/albums/qq32/sbwhart/Key%20way%20slotter/100_2485.jpgDog Rough Key Way Slotter
OK its a bit wuf but it does the job.
Have fun
« Reply #4 on: September 27, 2009, 01:00:28 PM »
'nuff said, job done, and it's a gud 'un.
« Reply #5 on: September 27, 2009, 02:46:39 PM »
Looks good to me Stew, hold a key won't it...... :clap:
Offline Gerhard Olivier
« Reply #6 on: September 27, 2009, 05:34:46 PM »
Your just to clever
Finaly understand
Nice one
Gerhard
Guernsey
Channel Islands
Offline CrewCab
« Reply #7 on: September 28, 2009, 03:13:46 PM »
Nice one Stew  :thumbup:
CC
Offline chuck foster
« Reply #8 on: September 30, 2009, 09:21:13 PM »
it looks like a very handy tool to have  :thumbup: :thumbup:
you did a great photo/write up on the whole project  :ddb: :ddb:
chuck  :wave:
skype:  aermotor8
former hmem member
« Reply #9 on: October 01, 2009, 02:39:02 AM »
Thanks Chaps
It was a job I enjoyed doing, nice and quick with a good ending.
Have fun
Offline websterz
« Reply #10 on: October 09, 2009, 12:50:40 PM »
No-one else has mentioned it, but the wine cork in the tailstock spindle is brilliant! Beats the bit of rag I have keeping the chips out of mine.  :clap: :nrocks:
 :med:
« Reply #11 on: October 09, 2009, 03:04:09 PM »
The problem is I keep losing it and have to open another bottle.
:D :D :D :D :D :D
Thanks
Offline johnny123
« Reply #12 on: May 08, 2010, 10:13:16 PM »
hello
built a smaller version of this one and it has many uses i found out!
Offline cidrontmg
« Reply #13 on: May 09, 2010, 05:27:32 PM »
from sbwhart: "The problem is I keep losing it and have to open another bottle."
Hm. What might the problem be in that? Too tight corks?  :)
Olli
Penafiel
Portugal
« Reply #14 on: May 09, 2010, 05:53:54 PM »
 :lol:  I only just found this thread  :doh:
Yep those are good clamping bits Stew... I haven't gotten any for a while now though.
Good to see someone finally found a use for those big black arm brackets though.... I do have a couple of those around still!
And to those who thought I was AWOL.... I was just resting.... Oh, and spending time re-building the car  ::)
Very nice piece of kit BTW Stew  :clap:   :thumbup:
« Reply #15 on: May 10, 2010, 03:52:29 AM »
Me Too!   :bugeye:   ::)
Where have I been?  :scratch:
Should I worry?
Nice work, nicely shown Stew!  :thumbup:
