Author Topic: Making a 5MT Myford adapter  (Read 36680 times)
« on: October 15, 2009, 06:53:03 PM »
As you may well know, I use adaptable tooling, that can be swapped from machine to machine, still with the piece part mounted, so I can turn an item on the lathe, unscrew the chuck and screw it straight onto the RT for further work, and vice versa.
What I have noticed, especially on the lathe, if I take a largish cut, I sometimes get chatter marks.
I am going to try to reduce the chatter as much as possible.
This is what I am using at the moment, a chopped down 5MT to 2MT adapter, with a 2MT mounting Myford chuck nose. I want to make it a one piece job.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle01.jpgMaking a 5MT Myford adapter
When Stew and myself had a morning out to visit Bluechip Dave, we had to stop half way there for me to stretch my legs. It just so happened, right next to the rest stop was a scrap yard. So taking a leisurely stroll, we found ourselves inside and confronting a young man sorting out ferrous scrap. I had spied what looked like rams off hydraulic cylinders, so the young gent climbed in the skip and retrieved me a couple and I also picked up some nice thick pieces of plate. I asked him how much, and I got the lot for five squid.
Anyway, I decided to use part of the smallest and shortest piece of our find to make a one piece unit out of. This is 2" in diameter.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle02.jpgMaking a 5MT Myford adapter
A quick date with the power hacksaw chopped off a slightly overlength piece. I wasn't really worried about the overhang out of the chuck. The chuck held it really rigid, and I knew it wasn't going to flex much. It turned up fairly nicely.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle03.jpgMaking a 5MT Myford adapter
The end was faced and centred.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle04.jpgMaking a 5MT Myford adapter
Then it was drilled and tapped out to 12mm. This is for the drawbar I will be using.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle05.jpgMaking a 5MT Myford adapter
I will be using the topslide for turning the taper. But because I will need all 100mm (4") of the movement to cut the taper, I had to turn down the end bit.
That is the end of the turning at this time, I need to set the topslide angle to cut the taper. So this piece was removed from the chuck, and the original two piece part was mounted up with the threads inside the jaws.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle06.jpgMaking a 5MT Myford adapter
The first thing I did was getting it to run true. I have said before that I like these four jaw self centring because they always seem to run accurately, this one was no exeption, less than 0.02mm (0.001") runout. So as long I got it running true at different areas of the taper, I was happy.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle07.jpgMaking a 5MT Myford adapter
The DTI was run along the taper to set the angle up on the topslide, from near the chuck,
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle08.jpgMaking a 5MT Myford adapter
to the tailstock end. It took a little time, but I got it spot on and everything was locked up tight.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle09.jpgMaking a 5MT Myford adapter
The original lump of metal was remounted in the chuck and trued up with a DTI.
Feeding the topslide by hand, the basic taper was cut to size, but because of the hand feeding and the tough material, the finish was only so-so.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle10.jpgMaking a 5MT Myford adapter
To clean up the cut, I decided to use my toolpost grinder. Here, I am just dressing the wheel by feeding with the topslide to make sure it runs parallel with the taper.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle11.jpgMaking a 5MT Myford adapter
I put a cut on of 0.01MM (0.0005") and gradually hand fed along and back on the taper.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle12.jpgMaking a 5MT Myford adapter
It isn't as good as what I would normally do, but my hands were giving up with all the slow feeding, so I decided it was plenty good enough for the job it had to do. In fact the photo shows it worse than it really is.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle13.jpgMaking a 5MT Myford adapter
So after putting a thin layer of engineers blue on the inside of the mount, I located the taper and this is how it came out.
That will do me just fine.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle14.jpgMaking a 5MT Myford adapter
The next job is to modify the old drawbar, then with the taper locked in, I can start to shape the front end.
Re: Making a 5MT Myford adapter
« Reply #1 on: October 15, 2009, 07:44:33 PM »
You know John if you stare really hard at the unfinished end you can see the 1-1/8" x 12 thread hiding just under the surface.
John S.
« Reply #2 on: October 16, 2009, 01:50:00 AM »
Yes John, I have already seen it.
Now that I know that this machine can cut accurate imperial, I can see even deeper.
This is only the first part of the exercise, the next bit will fit onto this, an ER32 nose. Then I have the Myford nose fixture to make for the RT, so the ER32 will then fit both.
It was a real shame I couldn't give that surface another going over with the grinder, but as you well know, I have a duff right hand as well (I'm falling apart at the seams), and I was lucky to get one cut done. But everything from now on can be done under power, so that will cure any future problems.
« Reply #3 on: October 16, 2009, 03:28:30 AM »
Very nicely done/ started John.....  :clap:
Again!  :thumbup:
« Reply #4 on: October 16, 2009, 03:15:17 PM »
John, somewhere, maybe even on Madmodders(?), someone is using a battery drill to turn their compound screw etc.
« Reply #5 on: October 16, 2009, 04:12:29 PM »
That is already on the tuit list, but not this time.
I very rarely use the topslide like I did, only a few times a year, so it is very low on the priority list.
Many thanks for mentioning it anyway. It might spark off another topic.
« Reply #6 on: October 16, 2009, 05:17:40 PM »
As I mentioned last time, before I can start any work on the new adapter, I need to make up a drawbar for it, this will stop it falling out of the spindle as I am working at the nose end.
I had already done a little work before I took these photos, so this shows where I am up to.
I have already cut off the old smaller thread that was on the drawbar I had made for the old nose fitting.
At the right hand end, a new thread fitting has been made and this will be joined onto the bar when I get it to the right length.
In middle front is a bearing block to help prevent damage to my spindle and make things a lot easier to tighten and undo.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle15.jpgMaking a 5MT Myford adapter
Before going any further, I will explain about the bearing block.
When I made the drawbar originally, the turn knob sat directly on the end of the spindle, and was very tight to slacken off or tighten up because of the metal to metal friction.
This is an ali block that sits inside and on the end of the spindle,  and has a ball race stuck into a recess. So when the knob is tightened, it presses on the ball race instead of the spindle end.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle16.jpgMaking a 5MT Myford adapter
Because I need the tightening knob to act on only the centre of the ball race, a small flange was cut that was smaller than the outer race, but larger than the inner.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle17.jpgMaking a 5MT Myford adapter
Using my rotating tailstock chuck, I mounted up the drawbar so that I could give it a going over with emery cloth to make sure the surface was smooth enough to allow it to run thru the ballrace.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle18.jpgMaking a 5MT Myford adapter
So now the rod had to be made to the correct length for it to tighten up and do it's job.
The new screwed end was put into the tapered adapter, and that was then stuck up the spout and given a light tap with a lead hammer to get it into the right position.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle19.jpgMaking a 5MT Myford adapter
This shot shows how the bearing block works, it sits between the knob and spindle end.
The rod was pushed forwards until it hit the new threaded fitting.
The amount of gap between the knob and block is how deep the hole needs to be drilled in the screwed end fitting. This was just over 18mm (3/4"), so if I drill the fitting to 25mm (1") deep, that will give a nice tightening up allowance.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle20.jpgMaking a 5MT Myford adapter
That is what is being done here.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle21.jpgMaking a 5MT Myford adapter
The first thing I had to do was put the bearing block on the shaft, because it won't go on after it is all put together.
The now drilled screwed end was fitted onto the end of the bar and a cross hole was drilled, and a roll pin fitted to allow disassembly if needed.
It was tried out, and it worked just right.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle22.jpgMaking a 5MT Myford adapter
So now this bit is finished, the main part can now be done, so that will be in the next enthralling episode.
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #7 on: October 16, 2009, 05:24:31 PM »
Yup, it was me. I just chucked up a allen key ( with the little leg cut off ) in the cordless drill, then just ran it on a nice slow speed hand held to engage on the socket head cap screw holding the handle on the cross-slide ( or on the topslide ). Made quite a nice finish on my rubber lathe, so it should work even better on yours John  :thumbup:
Tim
« Reply #8 on: October 16, 2009, 05:56:13 PM »
Tim,
I don't think that would work for me when grinding, but it might be OK for turning.
I have to gauge the forwards movement of the toolpost grinder so that it is sparking out (finishing the grinding process) as it moves along the bar, so it is doing two jobs at the same time, continuously starting to grind and finishing the grind all in the width of the wheel.
So for 4", about 15mins, much slower than your drill could feed it. I need to make something that is geared down to give a V-E-R-Y slow speed.
Even the slowest feed speed I can get on the saddle of my lathe is still a little too fast for ideal grinding.
People don't seem to realise that grinding on this sort of scale is a very slow affair, and can't be rushed. Otherwise you can end up with surface finishes worse than when you started. DAMHIK.
When you see industrial grinding, they are using massive wheels compared to what we use, and flood coolant to keep the surface heat under control. That is how they can get things done much quicker. Even the wheels are automatically dressed as they progress.
We can only play at it, and do the best with what we have.
Offline spuddevans
    • My Photo website
« Reply #9 on: October 17, 2009, 04:10:47 AM »
Wow  :jaw: I did not know that you had to go that slow when grinding. That would be far slower than a drill could go. Maybe a little motor driving a worm gear reducion gearbox would be a future mod to make  :dremel:
Tim
« Reply #10 on: October 17, 2009, 07:48:08 AM »
Tim,
Now you can realise why my hand was starting to hurt.
Not only did I grind towards the head, I also came back again at the same speed, and still got a few sparks coming off even though the setting hadn't been touched.
Some people must be able to do it faster, but with the setup I have, I have found that is what gives me an acceptable to superb finish.
Something else to remember, this is sometimes the only way you can machine hardened or some very hard materials.
So what you do is make the part a tiny bit oversize, harden it, and then grind out the distortion caused by the heating process.
I just hope the lads who are making their own toolpost grinders realise that it isn't for doing quickie 'chop' jobs.
Offline spuddevans
    • My Photo website
« Reply #11 on: October 17, 2009, 12:35:45 PM »
No kidding !!
I dont know if they are, but I sure am taking note for when I make one. :thumbup:
Tim
« Reply #12 on: October 17, 2009, 12:51:12 PM »
Tim
Me too, when I tried grinding on the lathe with an air die grinder I know know I was trying to cut too deep too fast .... Thanks again John for the info .  :thumbup:
« Reply #13 on: October 17, 2009, 02:35:11 PM »
No kidding !!
I spent a good deal of time when I was an apprentice the tool room grinding. The practice was for the turners to leave +0.010" to 0.015" on the finished size as an alowance for the grinders to grind to size after the tool had been heat treated.
Tim
« Reply #14 on: October 17, 2009, 07:09:54 PM »
So now that the adapter is solidly fixed into the spindle nose, I can now concentrate on finishing off the nose end. Making it so that a Myford fitting can screw onto it.
The first job was to get the back face made that the chuck or fitting will run up to. This face needs to be very well finished, as it is this which straightens the chuck up to it's final running position.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle23.jpgMaking a 5MT Myford adapter
I measured three different backplate fittings and noses that I have in my possession, and they all came up with the same basic figure, 0.12mm (0.005") clearance for fitting on the spigot.
Whether that is intentional, I don't know, as it looks a little excessive to me, so I decided to go with 0.05mm (0.002") clearance instead.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle24.jpgMaking a 5MT Myford adapter
And that is what I turned the spigot to. A nice, smooth sliding fit.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle25.jpgMaking a 5MT Myford adapter
I went thru single point screwcutting only a few topics ago, so I have no need to repeat it all again, but I will just show the setup I have. Topslide set to 27.5 degs (half of thread profile angle) and everything exactly as before. This time I will be cutting 12TPI.
If you look at where the leadscrew is, you can see just how little movement I have towards the headstock. If the original leadscrew guard was on there, I wouldn't have been able to do this job.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle26.jpgMaking a 5MT Myford adapter
On the forwards planning to do this job, I had no experience of using this machine to cut imperial threads, so I had purchased a cheap die to bring the threads down to the correct size. But flush with the success I had with the first thread I cut, I decided to bite the bullet and not use the die, but the machine to cut the thread to finished size.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle27.jpgMaking a 5MT Myford adapter
I don't think I could have got a better fitting thread by using the die. It was spot on.
Confidence now super boosted. I have no further worries about single point cutting of imperial threads.
I now need to check out the metric side of things.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle28.jpgMaking a 5MT Myford adapter
I will eventually be making an ER32 collet fitting to go onto this stub nose. So I drilled down as far as I could with a 9/16" drill. This will allow me to hold something like a 150mm (6") length of rod in the collet chuck.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle29.jpgMaking a 5MT Myford adapter
The old and the new.
Raw material costs, less than a squid.
Amount learned about screwcutting on my machine, priceless.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Spindle30.jpgMaking a 5MT Myford adapter
So that is another tuit out of the way.
I might do another one, maybe two, before I start back on the Halo build.
