Author Topic: Keeping things well oiled.  (Read 9668 times)
« on: November 14, 2009, 06:25:32 PM »
As you may well know, I am a lubrication fanatic. I would prefer to spend 20 squid a year and have my machines dripping in lube, than pay for costly repairs to a non or under lubricated machine.
I noticed that Arc Euro were selling real cheap sight glass oilers, so I ordered a couple. I now know why they were cheap, but they should do the job.
There are two areas on my mill that require constant attention when running for any length of time, the first is the bottom bearing in the arbor support on my new bit of equipment.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers01.jpgKeeping things well oiled.
And the second is the quill and spindle lubricator.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers02.jpgKeeping things well oiled.
A length of hex bar was set up in the lathe, and the end was turned up to accept a 1/8" BSP thread, the same thread that is used on the fittings already there.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers03.jpgKeeping things well oiled.
And the thread cut onto it.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers04.jpgKeeping things well oiled.
The thread was screwed into location, and the length that is required obtained
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers05.jpgKeeping things well oiled.
The same was done for the other fitting.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers06.jpgKeeping things well oiled.
Once both bits were to the right length, they were drilled right thru with a 3mm drill.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers07.jpgKeeping things well oiled.
A larger diameter bar was drilled and tapped at each end to fit 1/8" BSP and both bits parted off.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers08.jpgKeeping things well oiled.
So these are the bits needed to make my right angled extensions.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers09.jpgKeeping things well oiled.
A flat was milled onto the side of the upright so that the hex bar sat nicely on it.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers10.jpgKeeping things well oiled.
The hex bar was screwed in tight, and the upper side marked up. The upright was tried for fit, and was spot on.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers11.jpgKeeping things well oiled.
Unlike this one, which has been made with the tapping in the casting well out of square.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers12.jpgKeeping things well oiled.
No need to worry, Mr Powerfile to the rescue.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers13.jpgKeeping things well oiled.
A few seconds, and this one looked OK as well.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers14.jpgKeeping things well oiled.
Now to get them stuck together.
A length of 0.5mm silver solder wire was wrapped around the bottom part of the hex and the joint well fluxed up.
Apply heat to the bit at the bottom (NOT TO THE SOLDER).
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers15.jpgKeeping things well oiled.
And both bits end up well fused together.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers16.jpgKeeping things well oiled.
Mount hex upright in the vice, then drill down until the hole reaches the hole in the upright.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers17.jpgKeeping things well oiled.
That'll do me.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers18.jpgKeeping things well oiled.
A bit of PTFE on the threaded joints and they are both fitted to the machine.
First the one at the top.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers19.jpgKeeping things well oiled.
Then the one at the bottom.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Oilers20.jpgKeeping things well oiled.
I tried them both out with oil, and adjusted them to give a steady drip feed.
One thing less to worry about.
Re: Keeping things well oiled.
« Reply #1 on: November 14, 2009, 06:41:33 PM »
Heads up for next time, buy the chrome ones not the brass ones, come from he same supplier in China but fr better quality.
John S.
Offline Powder Keg
  • Machinist Extraordinaire
« Reply #2 on: November 14, 2009, 06:53:45 PM »
Thanks for posting this John. I've often thought of doing the same to my mill. Great show!!!
Wes
Wesley P
« Reply #3 on: November 15, 2009, 04:04:09 AM »
Thanks for the tip John, will do, don't know when, because I have no more to do. But a good reminder to people who might be following on.
Wes,
I personally think something like this is well worth doing, it takes the guessing out of it.
I had been meaning to do it for a while, and it wasn't until I got the second machine part only recently, that spurred me into action.
It can be a matter of only a few seconds of running dry, and the machine can suffer drastic consequences.
Just remembering to turn them on and off is now a new problem. But I think being more visible is a good reminder.
Two strokes on the central lube and then flick on the oiler.
Offline Gerhard Olivier
« Reply #4 on: November 15, 2009, 04:42:46 AM »
That would be a vey good way to keep the old lathe solid bearings in good shape - thanks good idea
Gerhard
Guernsey
Channel Islands
