Author Topic: Mini Lathe Toolpost.  (Read 16898 times)
« on: December 20, 2009, 04:32:45 AM »
The toolpost on my mini lathe has always been located too high & wide for any sort of rigidity.  ::)
It`s ok for the little fiddly diddly brass parts I normally make, but is useless when faced with a piece of steel....  :scratch:
http://i110.photobucket.com/albums/n95/Dayjo/pc140003.jpgMini Lathe Toolpost.
Winding the compound back still has the tool outside the cross slide footprint.
http://i110.photobucket.com/albums/n95/Dayjo/pc140009.jpgMini Lathe Toolpost.
It then gets in the way of the tailstock nut.
http://i110.photobucket.com/albums/n95/Dayjo/pc140008.jpgMini Lathe Toolpost.
Very limited on diameter too.
http://i110.photobucket.com/albums/n95/Dayjo/pc190003.jpgMini Lathe Toolpost.
But, when it grabbed & bent my new parting tool.  :bang:
Something had to be done!  :scratch:
http://i110.photobucket.com/albums/n95/Dayjo/pc1900011.jpgMini Lathe Toolpost.
Remove compound & fit steel block, to give largest available footprint on crosslide.
http://i110.photobucket.com/albums/n95/Dayjo/pc190012.jpgMini Lathe Toolpost.
(Yes, it`s not quite square & in line..... This is a posed pic. )
http://i110.photobucket.com/albums/n95/Dayjo/pc190023.jpgMini Lathe Toolpost.
New (cheap) toolpost brings the tool into the crosslide envelope.
http://i110.photobucket.com/albums/n95/Dayjo/pc190017.jpgMini Lathe Toolpost.
And improves the capacity.
http://i110.photobucket.com/albums/n95/Dayjo/pc190020.jpgMini Lathe Toolpost.
Just need to chop away what`s in the way....... When the weather lets me get back out there.  ::)
http://i110.photobucket.com/albums/n95/Dayjo/pc190029.jpgMini Lathe Toolpost.
Lots of work/ tweaking to do. But I think this is the way to go.....  :thumbup:
« Last Edit: December 20, 2009, 04:36:51 AM by Stilldrillin »
Re: Mini Lathe Toolpost.
« Reply #1 on: December 20, 2009, 04:48:01 AM »
Looking good David
 :thumbup: :thumbup:
Its these tweeks that makes all the diference as I'm sure you know
Have fun
« Reply #2 on: December 20, 2009, 04:57:11 AM »
I use the same QC toolpost on my 9*20...Although I had to pack it up to get it on centre..
What a difference from the oem unit!  :thumbup:
I intend to make a new qctp when the weather permits..its a tad too cold atm(where's the 'brrrr' smiley?  :D )
« Reply #3 on: December 24, 2009, 04:39:46 AM »
I managed to have a few little workshop sessions......
Cut away beneath the toolholder to allow some clearance.
http://i110.photobucket.com/albums/n95/Dayjo/pc230022.jpgMini Lathe Toolpost.
Will round the corner sometime, if necessary.
http://i110.photobucket.com/albums/n95/Dayjo/pc230014.jpgMini Lathe Toolpost.
I have a 1" piece of unknown steel. The old set up screamed & rattled at a 10thou pass.
This cut sweetly at 20 thou!
At 40thou, (a handwheel turn), it cut nicely, but the motor began stalling.
http://i110.photobucket.com/albums/n95/Dayjo/pc230017.jpgMini Lathe Toolpost.
Even the normal, mundane jobs are now much sweeter.....  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/pc230020.jpgMini Lathe Toolpost.
Still got to tidy up........ Some 5/6" whit studding ordered for the lock screw.
All in all, a very worthwhile mod......  :D
