Author Topic: Hasbrouck V Twin Steam Engine  (Read 43203 times)
« on: May 31, 2010, 05:02:52 PM »
I have posted some pictures of this engine in my "casting brass" thread.
I thought it would be a good idea to do a build log of this engine.
I share my shop with a good friend , so any rough bits are his work  :D :D :D
This is the basic speck of the engine
Bore 1.875", Stroke 2.000"
Rated 2hp
400RPM 120 PSI
Stephensen Reverse
Double Acting V twin
The drawings are imperial desighned to be built without castings
http://i261.photobucket.com/albums/ii63/john970s0/P6010097.jpgHasbrouck V Twin Steam Engine
The base plate milled out of 10 mm plate (drawings use 1/4 but i had this to hand)
Using thicker plate caused some problems later.
http://i261.photobucket.com/albums/ii63/john970s0/P6010114.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/P6010101.jpgHasbrouck V Twin Steam Engine
Getting the base plate & back plate at 90 degrees proved difficult
I will find some of the early pictures & post them
Re: Hasbrouck V Twin Steam Engine
« Reply #1 on: May 31, 2010, 06:29:50 PM »
Hi John
Its about time you did a post on this engine  :D :D :D :D :D
I will tell Walter what you said  :lol: :lol: :lol:
Regards Rob
« Reply #2 on: June 01, 2010, 03:23:59 AM »
Build log? Thank you!  :clap:
Bring it on.....  :thumbup:
« Reply #3 on: June 01, 2010, 03:39:20 AM »
Build Log:-------------- yes please  :nrocks:
and
 :worthless:
Thanks
« Reply #4 on: June 01, 2010, 07:10:20 PM »
As this engine is about half way built the build log will be in fast speed  :D :D :D
http://i261.photobucket.com/albums/ii63/john970s0/eng8a.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/eng8b.jpgHasbrouck V Twin Steam Engine
This is how it should look
Cylinders were made from 2 large pices of steel (to do it again i would cast bronze)
http://i261.photobucket.com/albums/ii63/john970s0/014-3.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/002-2.jpgHasbrouck V Twin Steam Engine
Had the old bantam lathe working hard
http://i261.photobucket.com/albums/ii63/john970s0/009-1.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/004-1.jpgHasbrouck V Twin Steam Engine
Tomorrow it will be the steam ports
« Reply #5 on: June 02, 2010, 06:21:32 PM »
The valve ports were machined on my Axminster mill drill . This has been replaced by a Warco 626 mill
http://i261.photobucket.com/albums/ii63/john970s0/003-2.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/002-3.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/004-2.jpgHasbrouck V Twin Steam Engine
« Reply #6 on: June 04, 2010, 05:28:25 PM »
I found some more pictures of the con rods  these were turned from 1 inch key steel the big end journal being screwed and silver solderd
http://i261.photobucket.com/albums/ii63/john970s0/001-2.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/012-1.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/017-2.jpgHasbrouck V Twin Steam Engine
All the bearings are ball races as this is a working engine not a modell
http://i261.photobucket.com/albums/ii63/john970s0/019.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/016.jpgHasbrouck V Twin Steam Engine
I am trying to get a hard drive to work as most of the pictures are stored in there
Regards
« Reply #7 on: June 04, 2010, 08:40:13 PM »
Very nice John!
Looking forward to see this!
« Reply #8 on: June 05, 2010, 08:26:42 AM »
Hi John, appreciate your sharing pictures and some of the build log with us, particularly on a working engine, as those are all to seldom shown on such a forum, or should I say so seldom done at all, given the ease of just buying a small engine made somewhere else.  I am impressed with the numbers, 2 hp at 400 rpm, you are looking for a good bit of torque out of it, I hope it turns out without too many irritating bits and pieces.  I'm definitely looking forward to seeing it run, it looks like a good start. :thumbup: mad jack
« Reply #9 on: October 27, 2010, 05:19:15 PM »
After a bit of a traumatic family time i have eventually motovaited my self in to finishing this engine.
After meeting Rob Wilson i am converted to casting  :) :) :) :)
The drawings ask for the trunk guides to be fabricated from iron pipe , bronze castings will be better  :) :) :)
This is my first attempt at propper pattern making (i dont like wood)
http://i261.photobucket.com/albums/ii63/john970s0/PA250025.jpgHasbrouck V Twin Steam Engine
Some pices of MDF glued together
http://i261.photobucket.com/albums/ii63/john970s0/PA270027.jpgHasbrouck V Twin Steam Engine
All turned up and primed
Plenty of rubbing down later
http://i261.photobucket.com/albums/ii63/john970s0/PA270034.jpgHasbrouck V Twin Steam Engine
I must admit i am very pleased
http://i261.photobucket.com/albums/ii63/john970s0/PA270033.jpgHasbrouck V Twin Steam Engine
Now for the core box
http://i261.photobucket.com/albums/ii63/john970s0/PA270029.jpgHasbrouck V Twin Steam Engine
Same again MDF (magic wood) glued together boring the hole was interesting
http://i261.photobucket.com/albums/ii63/john970s0/PA270031.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/PA270032.jpgHasbrouck V Twin Steam EngineIt turned out better than expected
« Reply #10 on: October 27, 2010, 05:54:46 PM »
John.
Those pattern parts look almost as good as Rob's.  :thumbup: .....   But, he's had more practice than you!   :D
Blummin well done! :clap: :clap:
« Reply #11 on: October 27, 2010, 11:48:09 PM »
That is pretty neat. Have you ever cast before?
« Reply #12 on: October 28, 2010, 12:52:28 AM »
Nice bit of pattern making John
Keep them comming
« Reply #13 on: October 28, 2010, 01:28:31 PM »
Very nice John  :clap: :clap: :clap: :clap: :thumbup:
Offline Artie
« Reply #14 on: October 28, 2010, 03:27:03 PM »
Yep, Yep Yep...what they all said... Casting Porn!!!
 :headbang: :wave: :whip: :beer:
« Reply #15 on: October 29, 2010, 05:05:12 PM »
Made up the cores today
Wor lass was at graft (the wife was at work)
So i took the opertunity to cook them in the kitchen oven  :) :) :) :) :) :)
Used a mixture as recomended by the master him self (Rob Wilson) :bow: :bow: :bow: :bow:
http://i261.photobucket.com/albums/ii63/john970s0/PA290041.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/PA290042.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/PA290043.jpgHasbrouck V Twin Steam Engine
http://i261.photobucket.com/albums/ii63/john970s0/PA290046.jpgHasbrouck V Twin Steam Engine
Hopefully we will be casting tomorrow  :) :) :) :) :) :)
« Reply #16 on: November 04, 2010, 07:53:11 PM »
new video on you tube
thanks to Rob Wilson
Offline CallMeAl
« Reply #17 on: November 04, 2010, 10:34:19 PM »
Nicely done!  Looking forward to the rest of the project.
I skin cats my own way!
« Reply #18 on: November 05, 2010, 02:38:12 AM »
Great Video John, very interesting to see the casting proses, especially the one that went wrong it helped in the understanding of the technicalities of the proses
Thanks for showing, look forward to seeing more.
Offline Artie
« Reply #19 on: November 07, 2010, 07:18:44 PM »
Hi guys, you really are getting a great finish on the casting, brass isnt the easiest of stuff. Well done!  :beer:
« Reply #20 on: November 07, 2010, 07:32:28 PM »
Just caught the video. Very nice to see it done. That you and Rob in the video?
Offline johnbaz
    • My Flickr
« Reply #21 on: November 07, 2010, 07:32:54 PM »
Smashing vid- i've done casting like this at work but to do it in your own back yard is fantastic!!!!
Cheers, John :beer:
« Reply #22 on: November 08, 2010, 11:49:31 AM »
:doh:  yep that's me Eric
I was tying to keep out of shot  :lol: :lol: :lol: :lol: :lol:
« Reply #23 on: November 08, 2010, 12:21:39 PM »
Blummin well done you two!  :clap: :clap:
Well shown too. I could smell the bacon from here!  :thumbup:
« Reply #24 on: November 10, 2010, 09:31:21 AM »
Hello John, I can't say I've enjoyed a video more than the very professional looking operation you and Rob put on with this casting.  The finish on the good one was great, clean, and should do you well in your engine, and the one with the sand a bit moist was very instructive, particularly that you immediately noted problems and stopped before a mess was made.  It almost looks like it was done deliberately bad, just to make a good show on what to do when it goes wrong.  I hope to be doing some casting of the same sort in the not too distant future.  It really makes it all to have the whole of it, from the ramming up, ramming the sprues, carving the pouring funnels, all the way from beginning to finished casting, laying on the ground, looking ready for turning, and then turning.  Fine piece of work there, with the video, and well complimenting the work on the cores, boxes, and patterns.  Truly instructional :jaw: :bugeye: :bow: mad jack
« Last Edit: November 10, 2010, 09:38:51 AM by Rob.Wilson »
