Author Topic: basic dividing on a Chester Comet lathe  (Read 20299 times)
Offline wheeltapper
  • Spixworth Norfolk
« on: June 28, 2010, 02:46:06 PM »
I thought I'd show you how I do this.
this is my lathe, it's a Chester clone of the sieg c4.
CAUTION turn the power OFF before you start anything like this!!
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280004.jpgbasic dividing on a Chester Comet lathe
here is the inside of the drive housing
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280005.jpgbasic dividing on a Chester Comet lathe
to start off I made this fitting, it's a flat bar with a square piece with a cross hole and a clamp screw bolted on.
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280006.jpgbasic dividing on a Chester Comet lathe
remove the two bolts shown with allen keys
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280008.jpgbasic dividing on a Chester Comet lathe
and, using longer bolts, fix the fitting
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280009.jpgbasic dividing on a Chester Comet lathe
I then made an expanding sleeve to fit the lathe mandrel
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280007.jpgbasic dividing on a Chester Comet lathe
fit this in the mandrel
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280010.jpgbasic dividing on a Chester Comet lathe
and then fix a change wheel to the end and insert the detent pin so it engages with the teeth
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280011.jpgbasic dividing on a Chester Comet lathe
the expanding sleeve can also be used with a handle
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280012.jpgbasic dividing on a Chester Comet lathe
a close up of the drive pin on the handle
http://i293.photobucket.com/albums/mm72/wheeltapper_2008/P6280013.jpgbasic dividing on a Chester Comet lathe
very useful for screwcutting short threads, the lathes lowest speed is 100 rpm, a wee bit too fast for my liking.
and thats it, I hope I haven'd bored you too much :big:
cheers
the demonstrating side of Roy
Re: basic dividing on a Chester Comet lathe
« Reply #1 on: June 28, 2010, 04:36:51 PM »
Not boring at all Roy!   :thumbup:
Superbly made, and shown....  :clap: :clap:
« Reply #2 on: June 28, 2010, 05:33:31 PM »
Very tidy work Roy and I know it will be useful too! :clap:
