Author Topic: Cutoff Saw  (Read 16979 times)
Offline tinkerer
Cutoff Saw
« on: July 26, 2010, 10:59:48 AM »
Well, after a very long month that included an attack of angry yellow jackets and an hemerrhoid ectomy, that still is an issue, I am in the planning stages of my next mod. My neighbor is moving and had a yard sale and I bought this miter saw. My plan is to motorize it, if I can get some madmodder engineering assistance. In other words, I have no idea how to go about adapting everything. Any ideas will be appreciated.
  http://i993.photobucket.com/albums/af57/tinkerer_2009/saw.jpgCutoff Saw
Tink
Prov 13:19
Re: Cutoff Saw
« Reply #1 on: July 26, 2010, 01:27:17 PM »
tinkerer
Glad to see that you are back, hope everything is under control. :ddb: :ddb:
That is going to be quite a challenge to motorize that as I believe the motor and drive mechanism will have to be free to swivel with the saw as it swivels about its axis. This will be an interesting project, I'll be watching.  :D :D
Re: Cutoff Saw
« Reply #2 on: July 26, 2010, 08:10:20 PM »
I'd start out by looking at how a metal one is motorized.
Perhaps a search on the net or a trip to Harbor Freight or a browse  through the virtual catalogs of Enco, MSC and the like.
There have also been some writeups in the metal working magazines that showed how to build one from raw stock.
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
Re: Cutoff Saw
« Reply #3 on: July 26, 2010, 08:25:49 PM »
There are a few things in these links that may give you some ideas.  Some of the pictures tell a lot.
http://www.vintageprojects.com/machine-shop/power-hacksaw-plans.html
http://www.rustyiron.com/literature/Sawmaster_Power_Hacksaw.pdf
http://www.vintageprojects.com/machine-shop/power-hackSaw.pdf
There are others.  Do a google search.
Dean
Dean W.
Shop Projects:
Re: Cutoff Saw
« Reply #4 on: July 31, 2010, 07:59:13 AM »
Hi Tinkerer, I've got a home made power hack saw I inherited from someone who built it out of left over blocks and chunks of angle and plate and it works great, but it's a bit heavy and unwieldly compared to what you're getting into.  I've got a couple of gear motors that are right angle, and put out 60 rpm, which is about right, they came out of various office equipment, if you're anywhere close to North Carolina, I could send you one.  When I got the saw, it appeared to work fine, but took forever to cut.  It has a belt drive primary reduction, with a jack shaft, and then about a forty one chain drive secondary reduction, with a connecting rod attached to the secondary sproket, about six inches in diameter or so.
http://i894.photobucket.com/albums/ac150/madjackghengis/IMGP1161.jpgCutoff Saw
the connecting rod is set up for about a five inch stroke, and it cuts on the pull stroke
http://i894.photobucket.com/albums/ac150/madjackghengis/IMGP1162.jpgCutoff Saw
The man who made this had it running the wrong direction, so the angle of the con rod was tending to lift the blade during the cut stroke, and pull down during the return.  I ended up reversing the motor, and changing the bearing point on the saw end of the con rod, and now the angle of the rod lifts the blade slightly in the cut on the outward, non-cutting stroke, and pulls slightly down on the pull stroke that cuts, and it cuts pretty fast on steel my band saw ruins blades on.
    For that saw you got, you will probably have to build a sub-frame, to carry the motor assembly, which is why I suggested the right angle motor for size, and you'll have to calculate the angles of blade during the cutting action, so you can set up your  drive and pivot points to allow the natural motion of the arms to give you pressure in cutting, and relief in the return.  Those are the primary considerations, and you might consider putting the motor on the far end of the saw, so it cuts on the pull stroke, to ease the setting up of natural forces to do your cutting pressure and relief in the return.
    I could get along without mine, but it's saved maybe a couple hundred hours of hacksawing in its twelve or fifteen years in my custody.  It's likely to last another fifty years after I go, as it did after the previous owner.  He had it at least that long and used it all the time, even with the angles and stroke wrong, it still cut, just slower.  I just hope I make it to 91, which is how old he was when he finally passed on to that main machine shop in the heavens.  He was a good mechanic, and a wealthy man, when it came to good stories, good work, and good cheer, I remember him every time I see his old saw.  Here's to Joe Barbour and the many things he left behind as monuments of his work. :nrocks: mad jack
Offline crabsign69
Re: Cutoff Saw
« Reply #5 on: July 31, 2010, 11:07:58 AM »
here here  :beer:
Offline Dean W
Re: Cutoff Saw
« Reply #6 on: August 01, 2010, 01:51:29 AM »
... and a wealthy man, when it came to good stories, good work, and good cheer,
This is wealth, indeed!
Here's to Joe Barbour!   :beer:
And,  :thumbup: to you, Jack, for the pictures and more good ideas.
Dean
Dean W.
Shop Projects:
Offline jwsvandr
Re: Cutoff Saw
« Reply #7 on: August 01, 2010, 08:03:03 AM »
Just a thought - how about keeping your motor stationary and making the base turn. It is a light machine and if you arent cutting long pieces it might be easier
