Author Topic: Kennedy Power Hacksaw - newest addition to the workshop  (Read 59984 times)
« on: September 11, 2010, 07:21:19 PM »
When I first saw one of these running I really liked it. Being in a basement workshop, I`m limited with the size of the equipment I can have down there, especially floor standing. This is an ideal size, OK, limited certainly to the size I can cut but it`ll certainly give my arm a rest on the small stuff.  I get a lot of my stock from the scrappy so I have a lot of long bar, too big to easily get on the lathe so cutting with this saw should be quicker. I suppose we`ll see how much use it gets over the next few months but I think it`ll be a good addition to the shop.
It was pretty much ready to run, I just needed to make a new clamping block to hold the saw in place. The oil pot contains slide ways oil, I don`t know if that is too thick?
Anyone know much about these machines....I really need to get to grips with the setup although it is cutting pretty well as is:
Offline Trion
Re: Kennedy Power Hacksaw - newest addition to the workshop
« Reply #1 on: September 12, 2010, 02:29:22 AM »
Very nice, I'm jalous! :thumbup:
I neither know much about such saws, but was just wondering if there should be any lifting action of the blade on the non-cutting stroke?
« Reply #2 on: September 12, 2010, 03:55:25 AM »
That's a lovely little saw Chris - very busy looking too... the "Rapid"or I have access to is a much more leisurely cutter... And that cut-off mechanism is just brilliant - totally Heath Robinson, but in a good way.
Trion - I believe the reverse stroke is supposed to clean the chips out of the teeth & the cut, just like when you cut with a hand hacksaw.
« Reply #3 on: September 12, 2010, 04:33:47 PM »
Hi guys, has anyone seen one of these running in person - I have a comment on youtube saying that it looks to be running a bit quick. Anyone any thoughts? I have to admit, when I first booted it up, I did question the speed but then the Hover motor is original so I don`t know how it would be running too quick or quicker than intended.
« Reply #4 on: September 12, 2010, 06:30:26 PM »
Never seen one, Chris, but on the video it looks like it's doing 3 or 4 cuts a second, so maybe around 200 per minute. With a stroke of perhaps 6", that would be a "surface speed" of 100 fpm, which doesn't seem too much compared to a bandsaw. Of course, it will go faster in the middle of the stroke than at the ends, but I reckon it's still within reasonable bounds. The paint isn't burning off the blade, anyway.
Offline Cornish Jack
« Reply #5 on: September 13, 2010, 02:20:59 PM »
Have had one of these for about twenty years. Super bit of kit although a bit limited for size that it can handle. For some reason I can't see your pic/video so can't say if it appears to be fast - if it has the original motor and standard belt drive, it will be working at the correct speed - a compromise, of course. Have used mine for steel, ali, delrin and brass - all nicely done and VERY relaxing :thumbup: Enjoy :thumbup:
Offline gingerneer
« Reply #6 on: September 14, 2010, 05:09:07 AM »
Hi craynerd
I have one of these machines on long term loan from my mentor. Great bit of kit, his advice to the setting of the blades was that it did not matter which way around you put the teeth. I have tried this out and it cuts well with the teeth eather way around. Its drive from a reduction gear box, not sure if its worm drive or spur gears, but i would say it runs at half the speed yours does.
William
« Reply #7 on: September 14, 2010, 08:20:15 AM »
I actually had the pleasure of watching another one of these running last night, in person, and it was running at the same speed as mine does. Mine is cutting fine so I`ll just leave it as it is for now until anything becomes a problem.
I said there was a slide ways oil in the dash pot but any idea what oil should really be in there. Is this too thick and will cause the saw to drop too slow or would this be OK?
« Reply #8 on: September 20, 2010, 07:35:53 PM »
 :doh: :doh: :doh: :doh: :doh: :doh: :doh:
Spent a couple of hours on this during the last few hours. I`m convinced that the motor speed has slowed down a touch, but regardless of that, the saw is trying to fall too quick and is jamming and stopping the motor. I imagine the oil pot controls the speed it drops but there must be another mechanical element to adjusting the falling speed of the blade. It cuts lovely when you put your finger just on the end to take some of the downward force/weight!!
Anyone any thoughts.... I`m out of ideas short of changing the oil but I thought slideways oil was pretty thick!
Offline kwackers
« Reply #9 on: September 21, 2010, 04:37:23 AM »
I'd imagine the oil is just a damper, nothing to do with the speed of cut.
Usually there's a weight that can be slid back and forth to adjust the force on the blade.
« Reply #10 on: September 21, 2010, 04:39:52 AM »
Ahh, that sounds sensible. I`ll give it a try tonight!
« Reply #11 on: September 23, 2010, 12:10:56 PM »
That sounds a bit odd - never happened with mine in 20 years! :scratch: There is no weight adjustment on the saw arm - it just relies on the dashpot resistance to control the fall. The oil in mine was just from a can of diesel I had for the car and it has (so far) been just right. The piston in the dashpot makes quite disgusting squelching noises as it is raised and lowered - not a particularly technical way of describing it but that's what it is and it gives just the right amount of resistance. Thicker oil, maybe???
Offline rleete
« Reply #12 on: September 23, 2010, 12:48:37 PM »
With a bit of searching, you might find Bog's thread where he added a lump of iron or something to the end of his.
Offline kwackers
« Reply #13 on: September 23, 2010, 01:45:01 PM »
I can't see that the dashpot oil has anything to do with speed of cut. Consider how fast or slow you can raise the arm with a small amount of pressure, compare that to the differing speeds it will cut through metal.
At the rate the saw descends when cutting I can't imagine the dashpot would make any difference at all. I haven't seen one in the flesh though so might be talking the proverbial.
All of the power hacksaws I've seen (mine included) have an adjustable weight that can slide back and forth along the top of the saw arm, the further forward the more pressure it applies when cutting.
Having said that, craynerds problem seems to be one of cutting too fast. Adding weight is hardly likely to help that...
« Reply #14 on: September 23, 2010, 02:58:08 PM »
Hi, I sorted this out just as Kwackers suggested. I`m a bit confused Cornish Jack, if you unscrew the two bolts on the top of the saw you can move the saw and weight position.... this fixed my issue and I`ve just been again to a friend who has one this evening and it runs at the same speed to mine.
« Reply #15 on: September 25, 2010, 02:29:09 PM »
..."I`m a bit confused Cornish Jack" ... You and me, both, Chris. Just fought my way out to the shed through a Norfolk gale to check my saw. Yep, two bolts on the saw arm BUT NO ADJUSTMENT FOR ANYTHING!!. The bolts just hold the saw frame to the top guide runner and they're FIXED in position - no weight to change and no way of changing the saw frame position on the guide. Very puzzling but irrelevant if you've managed to sort your cutting rate.  :thumbup:
Offline pbernard
« Reply #16 on: October 06, 2010, 06:30:24 AM »
Hello all,
Just thought I might respond to Kennedy hacksaw posts as I used one 40 yeras ago at university (staff not student!!) and bought one from Ebay 12 months ago which to say the least was absolutely ***gered by mechanical abuse by trying to use it for too big a job(s)
Totally covered in crud of years, most of the levers and stops missing, and the vice adjustment knob - a welded on, cock-eyed socket spanner (for just a bit more torque!! by means of a socket handle).
Any way that said I am attempting to rebuild this into some sort of working machine - I only paid a fiver for it so I can afford to spend a bit on it.
The main reason I am posting is just to say that regarding the dashpot working etc it is just to slow down the fall of the cutting arm so that the blade does not jam in the work - I have always thought of the saw as a slow-close toilet seat with hacksaw attachment!!   OOOOH!
Cheers.
« Reply #17 on: October 06, 2010, 07:20:32 AM »
Yes, and the little leaver going into the dashpot allows you to control the speed as well as it looks to push on a little washer which either seals or opens the holes at the bottom of the "piston" to control the fall rate.
Offline pbernard
« Reply #18 on: October 06, 2010, 01:54:57 PM »
And guess what's also missing from mine!!  the little leaver going into the dashpot - just made a new washer as that was also  ***gered.
Paul.
« Reply #19 on: November 26, 2010, 11:24:46 AM »
Hi Chris,  I've got one similar, but made by someone who left it to me when he passed on.  It worked okay when I got it, mostly, but it wouldn't touch stainless, so with some fooling around, I found that changing the motor rotation and moving the link from the crank to the saw body, so the cut was on the pull stroke, and the crank was pushing the saw out as it rotated clockwise, gave a lifting effect, lightening the blade in the groove, and at the same time making for the crank to be pulling down on the cutting stroke, which made a significant difference in speed of cutting, and in blade longevity.  Mine is rather simple and has nothing but the weight of a half inch by two inch bar and no dashpot at all, but it is more effective than the band saw on hard to cut material, and does enough work I gave him a name, and think of him as a slow learning apprentice.  I suspect if you reverse the rotation, and have the cut on the pull stroke it will tend to lift the blade on the return stroke, lessening the wear and making the cutting stroke more effective.  They almost always cut straighter on a pull stroke than as a pusher, but there's a lot of issues in the angle and placement of the crank relative to the actual line of force of the cut which are determined by where shafts and such are located, and their position with respect to each other.  I wouldn't part with mine for the world, unless someone offered a really good deal.  mad jack
« Reply #20 on: November 26, 2010, 05:20:18 PM »
Madjack - thanks for the info regarding the cutting action. As I`ve said before, mine works a lot and I also wouldn`t get rid. I`ve only a very small basement workshop so one of the things I love with this is its small size! It is small enought to take only a small bench space yet can get a decent size under it...anything it can`t deal with I`ll have to use the old arm!
« Reply #21 on: February 02, 2011, 02:48:52 PM »
I went to pick up an item I won on eBay today and he had a complete working one of these sitting on his bench. I was tempted to make him an offer on it - then I remembered how frustrated I was with the first one I had :D
« Reply #22 on: February 02, 2011, 03:19:26 PM »
frustrated???  :jaw: this machine hasn`t let me down once and gets used loads, one of my best buys for sure!!
Offline jonny neate
« Reply #23 on: March 14, 2011, 04:31:04 PM »
Craynerd i have one of these machines but mines a Kennedy 90 yours is a 60. My 90 is about half as big again as yours and is quite lumpy.The 60,s do run a lot faster than the 90,s.
I love mine and would never part with it ,I think mine will cut about 3 1/2" thick by nearly 5" wide.
If your lucky enough to get a little used one the oil damper really works well but get an abused one and they can be a right pig.
                Jonny Neate
« Reply #24 on: March 15, 2011, 05:32:05 PM »
Cheers Jonny
I do keep threatening to remove the damper and take a look at it but then it seems to start working OK again so I leave it....!! Excellent machine and it has had plenty more use since my last posts on this thread!
