Author Topic: Snub Built A Ball Turner  (Read 27838 times)
Offline snub
  • Canada
« on: October 02, 2010, 10:45:14 PM »
My lathe is 5.5 inches fom center to the top of the cross slide so I needed a fairly tall 'stand'. I allready had this 4 jaw chuck that I use as a vice , so I decided to cheat and use this for the stand. Instead of machining a notch for the carbide tool bit, I decided to use the whole thing, bolting it to the bit holder.
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerconcavecut.jpgSnub Built A Ball Turner
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerconvexcut.jpgSnub Built A Ball Turner
The bearing is from a '57 Ford rear axle. I had a new one on the shelf, that's why I used it.
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerswivel2.jpgSnub Built A Ball Turner
The flat head machine screw passes through the rotating tool holder and threads into a cylinder with a shoulder on the bottom. When I get the tool holder to just the right snugness, I lock it in place with a set screw from the bottom.
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerswivel1.jpgSnub Built A Ball Turner
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerbase.jpgSnub Built A Ball Turner
  http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerbase2.jpgSnub Built A Ball Turner
I have to tell you, it works perfectly. No chatter and leaves an almost perfect finish.
Some of my balls. Aluminum, plastic and clear acrylic:
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturneraluminumball.jpgSnub Built A Ball Turner
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerpolypropolyneball.jpgSnub Built A Ball Turner
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/clearball.jpgSnub Built A Ball Turner
And a little 'freestyle', just to  see what I could make.
http://i53.photobucket.com/albums/g62/mithslew/Machine%20Shop/ballturnerornament.jpgSnub Built A Ball Turner
Offline Artie
Re: Snub Built A Ball Turner
« Reply #1 on: October 02, 2010, 11:18:10 PM »
Its amazing what modern medicine can do these days!   Seriously, great job, Im gonna find one of these under my bench one day pretty soon... well done mate.
Offline Powder Keg
  • Machinist Extraordinaire
« Reply #2 on: October 03, 2010, 10:23:14 AM »
Looks nice!!!
With all these ball turners showing up, Looks like I better post the one that I made? I can do 6" balls with minehttp://img.photobucket.com/albums/v652/Powderkeg3418/Smilies/headgear65-Copy.gifSnub Built A Ball Turner
Wesley P
Offline AndyB
« Reply #3 on: October 24, 2010, 01:05:20 PM »
Hi Snub,
Nice bit of work!
Am I correct in assuming that the toolholder end bears on the outer race while the bottom stub bears against the inner?
There are so many variations on a theme that I haven't completed one of these yet...another project plan waiting on the bench! :bang: Yours looks a cracker though! :clap:
Funnily enough, I got a couple of brand new bearings in a box of bits that are 40mm OD and I have some 40mm MS...
« Reply #4 on: October 27, 2010, 10:04:08 AM »
Nice work on that!
« Reply #5 on: October 27, 2010, 12:41:45 PM »
I like the thinking gone into that!  :clap:
