Author Topic: Graphite piston material  (Read 13933 times)
Offline Chuck in E. TN
  • USAF Retired
« on: January 08, 2011, 08:11:45 AM »
What are your sources of graphite rod for pistons? I’m building a ‘tin can stirling’ and have used a 1” steel tube for the cylinder. I need to find piston material that I can turn and lap to fit.
Chuck in E. TN
Chuck in E. TN
Re: Graphite piston material
« Reply #1 on: January 08, 2011, 10:22:00 AM »
Hi Chuck,
I asked the same before I started my tiny stirling build and somebody suggested this place:
http://www.nogginend.com/index_files/GraphiteRound.htm
I had some graphite donated by a very kind member, I have some left but it's not big enough to get an inch dia out of. I didn't get my stirling working but I'll try again 1 day. Will be trying the graphite on the two flame lickers I'm building now too.
  • USAF Retired
« Reply #2 on: January 08, 2011, 10:32:19 AM »
Wow, pricey. I imagine shipping will add quite a bit. I think I will experiment with casting a piston from epoxy.
Chuck in E. TN
Chuck in E. TN
Offline sorveltaja
« Reply #3 on: January 08, 2011, 05:10:22 PM »
Chuck, have you asked, if any EDM company has some leftover pieces?
Graphite is quite expensive, as I ordered two 20mm(0.787") bars long time ago. Despite that, it has unbeatable heat expansion factor, so it won't stuck on the cylinder, when heated(cylinder might expand more, than graphite piston, depending on cylinder material). Also it is totally self-lubricating material.
If you manage to get suitable size graphite rod, be sure to have a vacuum cleaner running, when machining it, to protect your lathe and other electrical devices, as graphite dust is indeed an electrically conductive material.
« Reply #4 on: January 09, 2011, 01:40:20 PM »
Ebay Chuck. That's where I got mine
Graphite rod on Ebay.
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #5 on: January 09, 2011, 06:54:19 PM »
Chuck, I get mine from Jerry Howell.  They're in the States, so shipping is not a problem.  Check the link.
http://www.model-engine-plans.com/partskits/miscsupplies/index.htm
Dean W.
Shop Projects:
Offline boatmadman
  • Located in Barrow in Furness, South Cumbria
« Reply #6 on: January 09, 2011, 11:13:48 PM »
If you know an industrial electrician, ask if they use carbon brushes on motors or generators. They get replaced regularly and there is always a nice bit left.
Ian
If it works, take it apart and find out why!
