Author Topic: Scott flame licker build  (Read 264452 times)
« on: January 16, 2011, 08:01:39 AM »
I am taking a bit of time out and building something that has been calling to me for a fair while now. This will run parallel to the Minimag build (when it turns up).
I gave up making things from castings a fair while ago, purely because the quality had got so bad (and still is amongst some of the well known suppliers).
In the middle of last year, I took a chance on a company I had never used before for castings, and bought two casting kits, this one and one for a full sized engine called the R & B, from Bruce engineering.
This one will be used to get me back into the swing of things, because no matter what people say, castings are not an easy way of making things, in fact, if you don't make them right, they can turn out to be an absolute eyesore, or it can cost lots of pennies buying new castings if you bugger up the initial ones. A lot of the second hand part built ones are sold by people who have become disillusioned when they thought they would be getting an easy build.
So now onto the way I get things done, others will have different methods, and as I don't like the way the instructions say how to build it, I will be doing it my way for some of the major parts.
So this is what comes in the kit. Everything you need to make the running engine, ball races, springs, even the fasteners, all except for the burner parts. That is because you have a choice of two methods, spirit and wick or butane/propane mix from a refillable gas tank. I will be going down the gas route, purely because in my steam days, I used to make refillable gas tanks, and I have a fully tested one waiting in the wings.
The quality of the castings, IMHO, are very reasonable, no surface blow holes or sags, intimating that something is amiss inside, and one thing I like the most, they haven't been over fettled by some gorilla using an angle grinder. I can take metal off easily enough, but putting it back on is a PITA.
The plans and instructions are well detailed, and I am sure if you follow them, you would end up with a working engine, which when finished, will be about 10" long by something like 6" wide, so not a small engine at all.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT01.jpgScott flame licker build
When I first bought the castings I had done a little bit of the cleaning up on the flywheel, just a couple of the segments. Now I have new files to fit the die filer, why waste energy.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT02.jpgScott flame licker build
In about ten minutes, I had the whole lot rough fettled, and not one single aching muscle or sore finger, it did a great job. This part will now be put away, and when the time comes to start turning and boring, a smaller and finer file will be fitted and it will be brought down to finished proportions.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT03.jpgScott flame licker build
This is the first piece that will get my major attention, the base casting. BTW, this engine is an Imperial build with BA fasteners, and because that are what are supplied, I will be using them.
So away with the metric measuring instruments, and in with the Imperial. Also, because the base is over 6" long, I will be using an 8" dial vernier rather than the 6" digivern.
The first thing that I did was to roughly check things for square and straightness, they were OK, then check for thicknesses and flatness.
By the time I had given it a good going over, I decided that the four top faces of the base bolt hole bosses were going to be my first datum points.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT04.jpgScott flame licker build
This is the first part that will need cleaning up, the bottom of the base. Once that is done, everything else should fall into place.
I don't like holding directly on the castings because of all the release tapers on them, so the first bit to be made will be a jig plate for it to be bolted to. That will allow me to mount and swing it about to known datums, and so everything will end up nice and square and straight.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT05.jpgScott flame licker build
So get your spurs and chaps on, and enjoy the ride.
Re: Scott flame licker build
« Reply #1 on: January 16, 2011, 08:56:13 AM »
Hi Bogs, glad you chose to move on with this one, it looks to be interesting, and I'm looking forward to the part with the burners, as I want to be using gas instead of spirits myself.  I very much like bronze for large parts like flywheels and such, so this should be a fine looking engine. :thumbup: mad jack
« Reply #2 on: January 16, 2011, 10:14:47 AM »
Hi Bogs, I will be follow this with a great intresst.
 :nrocks:
« Reply #3 on: January 16, 2011, 12:30:02 PM »
All saddled up John!  :thumbup:
Head 'em up. Move 'em out......   :D
« Reply #4 on: January 16, 2011, 04:28:12 PM »
If anyone is interested in a little more detail, here is a set of build articles that came from the public domain. I downloaded them and turned it into a PDF to keep it all together.
File name: Scott vacuum engine.pdf File size: 4.52 MB
As you will see. it is not a very difficult an engine to build, all it needs is to keep tolerances under control, as with all flame lickers, and a few specialist bits, like honing the bore and making a gas tank (if you go with gas). The gas tank isn't shown in these articles, but the details are shown fully on the plans, or you can buy a commercial one, plus the feed tube and jet.
« Reply #5 on: January 17, 2011, 01:20:35 PM »
Looking forward to this build John!
« Reply #6 on: January 17, 2011, 01:33:14 PM »
John I'll definitely be watching. As you know I love flame lickers, but I will be picking up bits and pieces for when I eventually make an engine from castings, maybe even a Bruce engineering one.
« Reply #7 on: January 17, 2011, 06:43:13 PM »
Well a bit more done today, and you will all be saying in the beginning, 'what is that daft old bugger up to now'.
So I may as well explain things a little. Being from an engineering background, you always try to look ahead a little. Well with this post I am certainly doing that. A couple of hours spent making a few fixtures can save many hours over the build of maybe not an engine this small, but anything a bit larger and more complicated, and you will have trouble progressing very far at all without them, so I am taking the opportunity to save myself a little time, and keep things more accurate than I could ever have hoped for if I was just holding the castings in the vice.
First off, I grabbed a bit of my favourite stuff, 12mm thick ali jig plate. Then I machined it square on all sides, and it ended up about 3/4" over the size of the main base casting.
The parallel sticking up the side (there is another one in the opposite direction on the other side) is to help keep things from flopping about and vibrating while being machined, because it is sticking up so far above the vice jaws.
Almost any material can be used for the holding plate, as long as it is sturdy and accurate enough to do the job.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT06.jpgScott flame licker build
A cutout was put into one side, you will see why a little later.
You will also notice the odd hole here and there. When this stuff comes out of a factory as scrap, it has invariably already been used as a jig plate, you just gotta take what you can get.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT07.jpgScott flame licker build
So this is the basic holding plate made, all nice and square and flat.
I suppose you can guess what fits into the cutaway now.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT08.jpgScott flame licker build
So the next job is to find out where to drill the holes in the plate, and this is one of the very few times I will hold a basic casting as large as this in a vice. All because the are usually no straight sides on the casting, so making holding in a vice very unstable. I could have clamped it down to the bed, but that would have meant me removing either my vice or RT, and because I am only doing very light machining on it, I take the chance.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT09.jpgScott flame licker build
I have already decided that the top faces of these bolt hole bosses are going to be my first start datum points, so what I am doing, by eye, is finding the centre of each of the four bosses and spotting it with a ball nosed cutter.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT10.jpgScott flame licker build
This shot shows just how 'bent' the casting is, look at what should be a straight face on the side left hand top edge, and the same on the right hand bottom edge. Now you can see why castings can't be treated like normal bits of metal. They can be bent like a bananas at times, and what you should be trying to do, is not to take all the bends out, but get them looking a little more presentable.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT11.jpgScott flame licker build
So now having the four 'holes' spotted, I can measure up and come to a 'mean' position for the holes. By drilling smaller holes in the holding plate, than the larger ones in the base, it will give a bit of 'fiddle factor later on.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT12.jpgScott flame licker build
The small holes were precision drilled in the plate, and the larger hold down bolt holes were drilled by eye. On the underside of the casting, where it won't be seen, I put recesses for the screws that will be used to hold it down for initial machining.
Also I made four 1" long upstands that were threaded all the way thru. The upstands were first screwed to the holding plate.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT13.jpgScott flame licker build
The plate, tapped down onto parallels, had the four upstands all skimmed on the top faces to ensure they were all the same length
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT14.jpgScott flame licker build
The cast base was then screwed downwards onto the four upstands, the screws went into the recesses while the sticky up bit of the casting went thru the cutout in the holding plate.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT15.jpgScott flame licker build
The whole lot was now gently tapped down onto parallels and everything given a final tighten up.
Then the gnasher came along and took off the hard skin, and the highs and hollows on the base. It took a cut of 0.020" to clean it all up
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT16.jpgScott flame licker build
The fine sweeper then came on the scene, and with a 0.003" cut, took out all the rough machining marks and left behind a nice smooth, perfectly level surface.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT17.jpgScott flame licker build
I now have a main datum base I can actually work with.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT18.jpgScott flame licker build
Everything was cleaned down, the casting taken off and the upstands removed. The casting was then bolted, using all the same drilled holes, onto the holding plate.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT19.jpgScott flame licker build
Once it is mounted back onto the mill, by using a DTI, I can swipe down all the edges and standing up parts, and by gently tapping, I can get the casting into it's optimum position to have any machining done on it.
This will ensure, by using the holding plate as a reference, I will be able to locate all holes and ensure that they are all drilled in the right places and all parallel to each other. Almost an impossible job if you were trying to hold the raw castings by themselves.
This plate will also be reused for the other parts that need machining, so it will not be wasted.
I now hope this goes some way to explaining what the daft old bugger is up to.
« Last Edit: January 17, 2011, 07:00:57 PM by bogstandard »
« Reply #8 on: January 17, 2011, 09:45:05 PM »
Hi John, I just wanted to say, it looks like you're off to a good start.  Im looking forward to seeing how this is going to look as it comes together.  I've got a casting, a frame for a horizontal steam engine, which has been sitting around for some time for the lack of a good way to hold it to get all the various surfaces machined properly aligned with each other.  I think I will emulate you with that piece of tooling plate, and solve a problem I've left for a better day for a few years.  Thanks for that idea.  I'll be following this one closely. mad jack
Offline Gerhard Olivier
« Reply #9 on: January 18, 2011, 03:23:10 AM »
Nice start John
Cant wait for more
Gerhard
Guernsey
Channel Islands
« Reply #10 on: January 18, 2011, 03:58:12 AM »
thanks for that. I would never have thought this through logically as you have  :smart:  but it all makes sense now. I'm glad I've held off trying any casting yet as I would certainly have cocked them up.
I've tried in the past many years ago and never really got anywhere but back then I didn't even really have a feel for limits and fits, let alone geometrical tolerances which is what we are talking about here.
I think by the end of your build I might have picked up some of the knowledge required to have a go at a simple kit of castings but just going to enjoy your article for now.
« Reply #11 on: January 18, 2011, 04:44:38 AM »
Most times, small casting kits just come with the instructions to file a flat surface somewhere on the casting and work from that. To me that is not acceptable, and why such a lot of beginners fall foul when doing their first casting builds. Usually ending up by throwing it under the bench when everything goes pear shaped.
Unfortunately, castings are all sorts of shapes, purely because the patterns have to release from the mould, and a flat face just won't cut it, so they have shallow tapers everywhere, nothing that you can get a true measurement off.
By me choosing this one major face to get perfect, now very easily, I can, if needed, get a few more faces square to it. Whereas before, I would be stabbing in the dark just where to drill holes and whether they are going to be parallel to each other.
As I said at the start, this build is a sort of prep for when I get onto the real deal, getting me used to working with castings again, because no matter what, if you do go in blind, you will almost certainly end up with some sort of error or bodge on the finished item.
I will say one thing though, working from drawings using bar stock materials is infinitely easier than using castings. It just isn't for everyone.
« Reply #12 on: January 18, 2011, 05:58:54 AM »
I can see now that with that careful prep work and making the fixtures it will be a lot easier and you will realise the joy of using the casting. All the basic structure is there requiring a lot less tedious machining hacking metal away. You just need to machine the features in the correct positions, not saying it's going to be easy, but surely less tedious.
« Reply #13 on: January 18, 2011, 09:53:39 AM »
That was a bit of brilliant work. It's encouraging me to work on that bronze bottle engine again. I should have tought of doing the same since at work they did the same thing with the large machine castings. They were set up in fixtures to get datum surfaces.
One question, maybe more. I noticed you didn't clean off the four bosses were the screws went through. Did you feel confident enough that they were level enough to just bolt down with out warping the whole base plate?
« Reply #14 on: January 18, 2011, 11:53:00 AM »
Hi John, while most of my experience in life has been with bar stock, flat stock and making parts for broken machinery and engines, once one has had the pleasure of building out of good quality castings, and come out with a high quality piece of gear, whether an engine or a tool, that does exactly what it's supposed to do, and has the advantages of the casting at the same time, it becomes an agrevation when one has to machine away parts of bar stock which wouldn't exist if it were a casting, and they become the preferred way, if they are well cast with good metal and done by those who really understand patterns, and all the intracacies of taking a drawing and making it into a pattern, casting it, and providing what the machinist needs to work straight forward and not have to make allowances for problems.  I just downloaded the pdf file for this engine, and I think you're going to start a run on the casting kits for this engine, with this build.  I think it is going to be a work of art and truly beautiful when it is running.  The castings look very impressive and well formed, and the design looks very much like something that will attract all sorts of attention, particularly with the big bronze flywheel. :nrocks: mad jack
« Reply #15 on: January 18, 2011, 12:07:29 PM »
Bernd,
I had already measured up the bosses beforehand as best I could, that was the reason for choosing them. Before mounting up, I tried them on the upstands without any screws, and as there was no rocking at all, I left them as they were.
If I had tried to level them with a file beforehand, I could have been playing about for hours trying to get them into a no rock situation.
I took it as a 'leave well enough alone' situation.
As it turned out, when measured from the new datum base to the top of the bosses, they were all within 0.002", so to me, to get a casting that close at this stage of machining is doing rather well. The more small datums that are cut, those measurements will get even closer.
Jack,
I agree with you about production castings, but here in the UK, the quality is so bad with model engine castings, they are almost not worth bothering with, just shapeless lumps of metal full of dross and blow holes and costing an absolute fortune.
That was the reason I took a chance on the two sets I bought, because they looked a definite improvement on what has been available the last time I was making from castings.
« Reply #16 on: January 18, 2011, 05:30:32 PM »
Now is the time to start to get the datums on the main bedplate sorted.
You will remember from last time, the bedplate was screwed down to the jig plate, but not yet squared up.
Mounted into the vice, as usual, bedded down onto a couple of parallels and the DTI was then brought into play.
I went all over the castings, looking for areas that matched for squareness, and by taking a few mean figures, I gently persuaded the plate to go into a position where, when machined, datum faces would be produced that would make sure that all the holes will be in the correct position.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT20.jpgScott flame licker build
The front and two side faces were cleaned up, the rear one can be done anytime as that will not be used in any marking up.
Some people will say I am removing too much of the casting features. All I can say is that I prefer to have an engine that is square, accurately made and not having to bodge things to get it running. If needed, the rough finish can be put back on once everything has been machined.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT21.jpgScott flame licker build
With the three sides cleaned up and totally square to everything else, it is time to get some measuring done.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT22.jpgScott flame licker build
The plate was blued up, and by using the two central upstands as datums, I found the centre point between them, and because I had the sides square, by using engineers squares, I could then mark up the centre line and an area of the plate to be machined to become the main vertical datum.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT23.jpgScott flame licker build
You can see here on my sketch and workings out the datum to be produced, and the exact positions vertically to the critical hole positions required.
Now the bedplate can be held accurately, it will be an easy job to get these holes drilled.
Don't worry about the vertical measurements being shown going to the wrong positions, they are in fact the hole centre heights from the datum face.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT24.jpgScott flame licker build
Back onto the mill again, and getting to grips with making the main datum face for the whole engine. What is required is to clean the surface off to remove all hi/lo spots. I found that taking a cut of 0.005" was enough to achieve the goal.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT25.jpgScott flame licker build
Once that flat area was completed, I jumped over to the cast in recess, and because it was full of lumps and bumps, I cleaned the whole lot up to make it look more presentable.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT26.jpgScott flame licker build
This is the finished result, all ready to have the bearing holes drilled and bored in the three uprights.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT27.jpgScott flame licker build
Now we are getting somewhere.
BTW, I was due to be building a magneto in parallel with this engine, and the pre production kit turned up today. But because I also have another little job to do as well, that build will now be delayed until at least next week.
There are only so many hours in the week that I can work.
« Reply #17 on: January 18, 2011, 07:15:19 PM »
Bernd,
I had kind of figured that, but was just curious. I know you won't skip an improtant think like that. Talk about luck being on your side.
I'm following this very closely since I'm getting that urge to work on that bottle engine again, but will wait till your done here with this build as I'm re-learning a few things I had forgotten from work.
Keep up the great work.
I'll be quiet now.
« Reply #18 on: January 18, 2011, 09:29:34 PM »
Hi Bogs, I got a look at the plans of that engine and it looks like she ought to be a good runner, with very good control over speed and power with gas.  In looking at the flywheel of that engine, and that of mine, I think I've got to shed a lot of weight, mine's only a 3/4 inch bore.  Is the base plate gun metal as the spec sheet says?  I can't tell from the pictures on my computer.  It looks like things are going into place nicely, the jig plate idea worked well, and the casting straight.  I like castings because they work, save metal, and look good when they're done.  In my opinion, they are there for my convenience and savings of metal, machining is for purpose, and straight fitting parts, correct clearances, and reasonable fitment of parts need no excusing, I just hate when things are done to no specific purpose, and no excusing improves the look or finish then.  That casting was rather well done for the hopper area to clean up completely with only five thousandths cut.  It's good to watch it progress steadily. :beer: cheers, jack
« Reply #19 on: January 19, 2011, 02:27:16 AM »
Bernd,
Maybe it was a bit of luck with those bosses, and the ease at which I managed to get the baseplate level on the bottom, but it is like everything when working with castings, you have to get that initial datum, once that is done, everything else becomes a lot easier.
Some people can just grab hold of a casting and find the datums straight away, unfortunately, I can't do that, so I have to work out everything the hard way. Even though it looks difficult, it isn't really, it is just a matter of sitting down and looking at it logically, the answer is usually staring you in the face.
I don't want to put beginners to casting machining off by what I am doing. It all looks very complicated, but during a conversation with a friend on Skype, I mentioned that even though I have posted a lot already about it, there is only about two hours actual work that has been done. So in fact, it isn't too complicated at all. The act of writing and posting about it makes it look more complicated than it really is.
Jack,
This engine, as far as I know from the plans was dated 1994. It initially called for a gunmetal base, but due to time and of course costs, it now comes with a cast iron base. The water hopper though is still a very heavy gunmetal casting. It's such a shame really, because I have it in my head that I am going to paint it, not polish it, after the initial runs are carried out. I will have to see whether the burner will take the paint off before making my final decision on that.
I wouldn't worry too much about your flywheel being overweight. These engines need as much help as they can get, and having too light a flywheel could stop it running.
Also having looked at the plans on this engine in detail, if you didn't want all the curvy bits to the water hopper (but you could put them on if you wanted to), it could very easily be made from ali and cast iron bar stock, with the uprights being bolted onto a baseplate from underneath. After all, this engine only has three castings, baseplate, water hopper and flywheel, everything else is made up from barstock and commercially available bits.
« Reply #20 on: January 19, 2011, 06:30:08 AM »
Off to a flying start John, am watching with interest. Castings seem good quality so far.
Offline shoey51
« Reply #21 on: January 19, 2011, 02:57:36 PM »
I too am watching this John. I learn so much from these threads :thumbup:
Offline spuddevans
  • Portadown, Northern Ireland
    • My Photo website
« Reply #22 on: January 19, 2011, 04:22:47 PM »
I too am enjoying your work. I also really like using the ali plate as a machining base/reference aid, sometimes just figuring out how to hold the object to the mill can be a trial, but this idea is one I will file away.
Tim
« Reply #23 on: January 19, 2011, 06:08:13 PM »
Many thanks gents.
HS93 talked me out of going into the shop this morning, so this is just an easy evenings work.
My DRO had remembered where the centre line was from yesterday, so it was just a matter of getting a zero datum from the end face.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT28.jpgScott flame licker build
Once that was done, it was an easy matter of spotting and drilling the three required holes. Horizontal work on the base is now done, except for drilling the oil cup holes, which can be done at any time, using the datums I have already created, even after it is taken off the holding plate.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT29.jpgScott flame licker build
Now this is where the plate comes into it's own. Swung to a vertical position, and clamped against the vice fixed jaw with a 3,2,1 block. This is plenty rigid enough for the jobs I am now about to do.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT30.jpgScott flame licker build
By having the 3,2,1 block hanging over a little, I can easily find the Y axis setting for the flat face I machined up last time.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT31.jpgScott flame licker build
And the machined end of the casting gave me the X axis position.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT32.jpgScott flame licker build
The X & Y were set to zero
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT33.jpgScott flame licker build
And the figures that I had worked out were fed into the table, the table locks were then tightened up.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT34.jpgScott flame licker build
This put my quill spot on over the position that is shown on the plans. A hole was spotted and drilled.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT35.jpgScott flame licker build
A long series centre drill was then used to spot thru onto the second part of the casting.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT36.jpgScott flame licker build
The hole was then drilled using a long series drill.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT37.jpgScott flame licker build
Both holes in line. I don't have a machine reamer that will reach both holes, so this will be done with a hand reamer later.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT38.jpgScott flame licker build
I now moved to the second set of coordinates I had, then spotted and step drilled up to 12mm diameter.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT39.jpgScott flame licker build
The boring bar then came into action, and the hole was opened out to 13mm, the size of bearing supplied for the flywheel shaft support.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT40.jpgScott flame licker build
A nice slip fit for the bearing. Eventually, a pair of them will be Loctited into this hole.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT41.jpgScott flame licker build
So that is the baseplate basically finished, except for a little fine fettling and tapping one of the holes that I drilled earlier, and of course the three oil cup holes. I have already hand reamed the two cross holes.
http://i202.photobucket.com/albums/aa102/bogstandard_photos/From%20June2010/SCOTT42.jpgScott flame licker build
I hope you can now see why I used the jig plate. Fairly easily, not only did I get the surfaces, top and bottom, level and parallel to each other, but also all the holes in the correct relationship and again parallel to not only each other, but to the base datums as well. So it was definitely worth doing on this build.
So the next step of the journey is to get that big lump of gunmetal into shape. I think this is one of those stages where I will have to hold the rough casting in the vice to get my first flat face, the bottom. Then take it from there.
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #24 on: January 19, 2011, 08:25:27 PM »
Very informative thread John, as usual.
I'm coming to this one a few days after it started.  The work with the die filer makes me wish for one even more.  ; )
Your explanation of the jig plate use should come in handy for a lot of fellows here.  I especially liked the part about
putting the casting up on studs when you were getting started.  That's one for my notebook, thanks.
Nice that you are getting some shop time!  Glad for that.
Dean W.
Shop Projects:
