Author Topic: My Chester Conquest Mill.....  (Read 30678 times)
« on: April 08, 2011, 01:16:21 PM »
A while back, I asked for forum guidance regarding a new mill.... http://madmodder.net/index.php?topic=4312.0
Well, It's finally. "finished"!   :D
Looking back..... It was a straightforward stripdown/ rebuild. Slightly more so, than any Chinese new machine.
New R8 spindle. Wonky locating peg. Pulled, re inserted, pressed back into place in me vice.......
http://i110.photobucket.com/albums/n95/Dayjo/P2160004.jpgMy Chester Conquest Mill.....
The planned taper roller bearings are wider than the originals.
So, I turned the lower seat area as close as I sensibly could to the locating peg......
http://i110.photobucket.com/albums/n95/Dayjo/P2220002.jpgMy Chester Conquest Mill.....
The machine arrived. Took off the head, stripped completely....
http://i110.photobucket.com/albums/n95/Dayjo/P2280004-2.jpgMy Chester Conquest Mill.....
The spindle was oversize. The bearings would not have fitted without a lot of brute force. So, I had to ease the diameters with fine emery, until there was only interference in the bearing seat area.
Made plastic plugs for the now unused holes......
http://i110.photobucket.com/albums/n95/Dayjo/P3140004-1.jpgMy Chester Conquest Mill.....
Top bearing and polished spindle........
http://i110.photobucket.com/albums/n95/Dayjo/P3140008.jpgMy Chester Conquest Mill.....
The pulleys lined up perfectly, thanks to the lower bearing seat.
Look! No gears! The pulley was a little loose, running slightly eccentric on the spindle.......
http://i110.photobucket.com/albums/n95/Dayjo/P3140007.jpgMy Chester Conquest Mill.....
Two years on from my last Conquest, they're still using the quirky stickers.......
http://i110.photobucket.com/albums/n95/Dayjo/P3140011.jpgMy Chester Conquest Mill.....
Head back on. Time to fit/ lube the X and Y slideways.
Hmmm...... The leadscrew's a little short.......
http://i110.photobucket.com/albums/n95/Dayjo/P3280002.jpgMy Chester Conquest Mill.....
Quick phonecall to Chester. "Oh? Now, that's a new one!"
Mk II screw arrived, next day.......
http://i110.photobucket.com/albums/n95/Dayjo/P3310007-1.jpgMy Chester Conquest Mill.....
I really, don't like the Z axis fine feed knob.......
Bored out an old Warco lathe handwheel, to match a small spigot on the knob......
http://i110.photobucket.com/albums/n95/Dayjo/P3290008.jpgMy Chester Conquest Mill.....
A few spots of sleeve retainer......
http://i110.photobucket.com/albums/n95/Dayjo/P3290010.jpgMy Chester Conquest Mill.....
Looks ok, I think. Works well too.......
http://i110.photobucket.com/albums/n95/Dayjo/P3310014.jpgMy Chester Conquest Mill.....
Now, it's time to do all the little tweaks which improve the handling/ working/ adjustment etc.
Filed a drill point on all the gib screws. Straightened and polished the gibs. Swapped the silly handwheel locknuts for stiffnuts.
I really dislike the wobbly handwheel handles..... So, I drill a piece of 10mm brass 8mm through. Then taper file the o/d to match the handle's taper bore.....
http://i110.photobucket.com/albums/n95/Dayjo/P3310009.jpgMy Chester Conquest Mill.....
"Screw" it on. Part off.... Grease and assemble......
http://i110.photobucket.com/albums/n95/Dayjo/P3310012.jpgMy Chester Conquest Mill.....
Last job was to fit the rubber bellows. Found they were both tight as a drumskin at full traverse.
Another phonecall produced a rear (largest) bellows, only. So, I fitted that one at the front.
The new rear one came from Arc Euro.
Job done, apart from final tramming.......
http://i110.photobucket.com/albums/n95/Dayjo/P4080015.jpgMy Chester Conquest Mill.....
I'm a bit pleased with that......  :thumbup:
Offline jim
Re: My Chester Conquest Mill.....
« Reply #1 on: April 08, 2011, 01:20:48 PM »
worth the work :thumbup:
« Reply #2 on: April 08, 2011, 01:22:52 PM »
Looking good Dave, soon be back in the chip business.
:thumbup:
« Reply #3 on: April 08, 2011, 01:25:02 PM »
Looking great David  :clap: :clap: :clap: :clap:
Now will you be getting back on with those hot air engines  :poke: :poke: :lol: :)
« Reply #4 on: April 08, 2011, 02:19:53 PM »
Nice one Dave. :thumbup:
After all that, I hope it gives you many years of trouble free and enjoyable machining.
Offline Trion
« Reply #5 on: April 08, 2011, 04:49:35 PM »
Nicely done and well shown! Now lets see the mill in use! :)
Offline SPiN Racing
« Reply #6 on: April 08, 2011, 11:09:31 PM »
Beautifully done!
SPiN Racing
« Reply #7 on: April 09, 2011, 03:52:06 AM »
Thanks for your kind comments Chaps!  :thumbup:
Available time is still a problem. I think chipping production will be a little slow for some time, yet.  ::)
Hot air engines, Rob? Another orphan arrived, last week.......  :palm:
« Reply #8 on: April 09, 2011, 03:55:54 AM »
:lol: :lol: :lol: :lol: now why dose that not surprise me, David   :lol: :lol:
What have you taken in now ?   :proj:
« Reply #9 on: April 09, 2011, 08:19:30 AM »
Yer 'tiz Rob!  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/P4090018.jpgMy Chester Conquest Mill.....
http://i110.photobucket.com/albums/n95/Dayjo/P4090017.jpgMy Chester Conquest Mill.....
Said, never to have run.  ::)
Swapped for a twin cylinder, Mamod SE3 steam engine, which I recycled some 18 months ago......  :D
« Reply #10 on: April 10, 2011, 04:56:20 AM »
Hi David
very interesting engine you have there  :clap: :clap: :clap: looks well made too  :dremel:  any idea why it never ran ?   :scratch:
i am sure you will be able to work your magic on it  :med:
« Reply #11 on: April 10, 2011, 05:42:39 AM »
Hi David
Probably because it's so ugly - it repels rotation.   :lol:
John S.
« Reply #12 on: April 10, 2011, 03:57:29 PM »
Hi David
John S.
That's a bit cutting to delicate constitutions, John!  :wack:
Don't you know, beauty is in the eye of the beholder? Only......  ::)
Anyroad, I'm not too pretty meself...... We'll get along ok!  :thumbup:
« Reply #13 on: April 10, 2011, 04:18:03 PM »
I think it's quite nice ...  :thumbup:
But then, I do have an eye for the finer things in life ...  ::) :beer:
Is it brass or maybe anodised aluminium ( or hallooooominum  )
I'm sure you will get it chirping Dave ...
Dave BC
« Reply #14 on: April 13, 2011, 02:13:43 AM »
Hi Dave.
Thanks for that! (A bit of deja vu, here)!  ::)
Brass, aluminium, stainless steel......  :thumbup:
Working on the Huxtable base at the mo. This one's waiting, in the cupboard with the other orphans......  :coffee:
