Author Topic: Mini Lathe, Saddle Retaining Strips......  (Read 21758 times)
« on: December 05, 2011, 04:11:22 PM »
Just a quick 'un. Though it took me a long time.......  :palm:
I didn't like the look of the contraptions which held my 7 x 12 saddle in place.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010801.jpgMini Lathe, Saddle Retaining Strips......
Also, I didn't like the horror stories of loose and broken strips.  :Doh:
I spotted a suggestion of an easy way of sorting the problem, and bought a  length of 6mm m/s.  :thumbup:
Never did have any trouble! So, it all got forgotten, until I spotted the strip in my store pile.  :scratch:
Now, I know...... "If it's not broke, don't fix it". But, 6 years had passed.........  :bugeye:
I measured the stand off between each strip, and casting. 20thou, front. 5thou rear, and machined the same size steps in the new strips.....
http://i110.photobucket.com/albums/n95/Dayjo/P1010803.jpgMini Lathe, Saddle Retaining Strips......
The screws, spaced exactly/ accurately 40mm apart, were replaced with 6mm studding, loctited in place.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010806.jpgMini Lathe, Saddle Retaining Strips......
The strips, held with nyloc nuts can now be adjusted easier.......
http://i110.photobucket.com/albums/n95/Dayjo/P1010822.jpgMini Lathe, Saddle Retaining Strips......
And give a better bearing area than the originals.
It was blummin cold, out in the workshop. So, I did a quick bit of parting off...... It cheerfully handled an old 1/2" caphead screw!  :D
Offline PeterE
  • Gothenburg
Re: Mini Lathe, Saddle Retaining Strips......
« Reply #1 on: December 05, 2011, 05:04:48 PM »
Ahhh, thanks a bunch for that idea  :headbang: something like that will be one of the mods when I lift the saddle of the bed.
See that you have oilways as well. Are they original or mods???
BR
/Peter
« Reply #2 on: December 05, 2011, 05:49:15 PM »
Yer welcome Peter!  :thumbup:
Don't remember who's idea it was, originally. But it was easy to remember and eventually put into use.  :smart:
The oilway is original, and very necessary to get the slide oil inside where it is needed.
« Reply #3 on: December 05, 2011, 06:53:10 PM »
....Don't remember who's idea it was, originally. But it was easy to remember and eventually put into use....
David, it probably came from Jose Meneses in Portugal, here: http://www.toolsandmods.com/saddle.html
I only mention it because he's in the photography business, and his pics are great. Not casting aspersions on your photos, which are better than my efforts with the camera.
« Reply #4 on: December 06, 2011, 02:31:16 AM »
Thanks for the link Andy!  :thumbup:
I read everything I could, in the early days of ownership. So, that probably was where it lodged in my head. to surface years later!  :scratch:
Lots of very spectacular/ accurate work there!   :bugeye:
Much too much faffing around for me..... Prefer to use my very limited time for production purposes, whenever possible.  :D
Offline winklmj
« Reply #5 on: December 06, 2011, 01:00:24 PM »
Just this past week I converted my 3yr old 7x14 over to new brass plates and shimmed them instead of using the studs-n-nuts. It took a bit of measuring with feeler gauges and a some more trial-and-error to get the right thickness for the shims (front and back were different).
But it was worth it--if I remove a single .0001 shim it will bind up the carriage. Shimmed properly--it slides the complete length of the bed with little effort and is rock solid. I had to sand off a little overspray from the underside of the ways and stone down the serial-number on the end of the bed so I could slide the carriage completely off.
If I remember I will post up pics and show how the old cast-iron gibs only touched on one edge.
New plates and shims highly recommended!
Mike
