Author Topic: ER 23 Fixture  (Read 8353 times)
ER 23 Fixture
« on: February 19, 2012, 05:13:19 PM »
Been going to make this for ages
Simply a block with a er32 collet holder on the end
Good for machining flats squares or cross drilling round stock
Rob Wilson gave me a piece of hot rolled square bar .This was hacked in to shape with a fly cutter
Then to the lathe  :dremel: :dremel: :dremel:
It took a while to get it all squared up and running true , this is the back end so was good practice for the nose end
20 mill drill half way through
Bored out until a reasonable finish was ac hived
One thing about getting metal from Rob is that it is shinny on the inside :) :) :)
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
Re: ER 23 Fixture
« Reply #1 on: February 20, 2012, 02:35:00 AM »
Nice start John  :thumbup:
I've got that on my tuit list as well, together with a hex version too - maybe this century if I can get that Kimble engine finished...
 :beer:, Arnold
Re: ER 23 Fixture
« Reply #2 on: February 20, 2012, 06:50:02 AM »
hi off to a good start
Re: ER 23 Fixture
« Reply #3 on: February 20, 2012, 06:12:25 PM »
Had a bit play with the fixed steady (i must clean it up and paint it)
Bore the taper tomorrow night then some threads
Re: ER 23 Fixture
« Reply #4 on: February 21, 2012, 05:13:06 PM »
Spent some time boring the taper
Got it reasonable in the end
Re: ER 23 Fixture
« Reply #5 on: February 22, 2012, 04:50:23 PM »
Threads cut 40 mm / 1.5
Pleased with them
Re: ER 23 Fixture
« Reply #6 on: February 22, 2012, 04:55:48 PM »
Nice clean thread  John
 :thumbup: :thumbup: :thumbup:
Good practice for cutting an M2
 :lol:
Re: ER 23 Fixture
« Reply #7 on: February 23, 2012, 03:28:47 AM »
Some nice work there John!  :clap: :clap:
That will come in very handy......  :thumbup:
Re: ER 23 Fixture
« Reply #8 on: February 23, 2012, 04:17:27 AM »
That's a nice fixture, John. I could use one of those myself.
Just one point: it looks from the first pic in your last post as though the collet is sitting a bit far back, so that if you tried to clamp it down on the minimum size of stock it will hold, the internal ring in the closing nut might foul the end of the threaded section before the collet gets a grip. An metric ER collet with a clamping range of 1mm needs to have about 4mm of the shallow taper projecting when placed in its chuck (or, in your case, fixture) without being compressed. Easy to fix, of course, by trimming back the front of the fixture.
  • Country: za
Re: ER 23 Fixture
« Reply #9 on: March 03, 2012, 05:45:14 PM »
I must have missed this on the first time round. :Doh:
Nicely done and shown :thumbup: :clap:
Useful piece of kit :thumbup:
Re: ER 23 Fixture
« Reply #10 on: March 03, 2012, 06:13:28 PM »
Thanks Dave
The collet holder was within .005 (not bad for me) :) :) :)
Rob wilson kindly squared it up on his surface grinder :bow: :bow: :bow:
It is now within a thou all 4 ways
I made a new chuck key for my 4 jaw chuck (i think it is possibly the most accurite chuck key in the world  :drool: :drool: :drool: :drool:
Now i need a surface grinder :lol: :lol: :lol: :lol:
A hexy one will be next
