Author Topic: Slicer software  (Read 21401 times)
Slicer software
« on: July 11, 2012, 01:09:39 PM »
So as not to hi-jack the reprap thread i have started a new one.
First of all read this post.
http://www.homemodelenginemachinist.com/index.php?topic=18727.0
Forget all the naysayers what I'm interested in is doing the same but in say 3mm slices and getting a DXF of each slice.
Tried to contact Matt but no reply.
Also had a look at slic8r program but can't see how to get a DXF as opposed to a reprap G -Code.
Any clues guys ?
John S.
Re: Slicer software
« Reply #1 on: July 11, 2012, 01:23:02 PM »
Any clues guys ?
John S.
NOPE :)
Interesting thread John ,  i can see the  potential .
Offline Country Bubba
  • LaGrange, GA USA
Re: Slicer software
« Reply #2 on: July 11, 2012, 01:35:47 PM »
As a thought to your query, there is a guy on cnczone that has a program gcode2dxf (or something like that) that will take a gcode and produce a dxf file from it.
Ah, here is his site:
http://codemangler.com/?page_id=7
Just a thought
Art
Country Bubba
Re: Slicer software
« Reply #3 on: July 11, 2012, 02:00:49 PM »
I think JS is after a program that takes a 3D solid file and slices it and is able to save the slices as a DXF file so he can use the DXF file in what ever  CAM program to create a G code file
is a close  :palm:
Offline Chazz
Re: Slicer software
« Reply #4 on: July 11, 2012, 02:30:38 PM »
Check out "Autodesk 123D Make" might be along the lines your are looking?
HTH
Chazz
Re: Slicer software
« Reply #5 on: July 11, 2012, 02:51:12 PM »
I had seen something along that lines. In fact, I saved the document somewhere that talks about it. Will look when I get home.
Re: Slicer software
« Reply #6 on: July 11, 2012, 03:15:05 PM »
Any clues guys ?
John S.
Possibly not quite what you want but have a look at 123D MAKE from Autodesk. (Free I think): http://www.123dapp.com/make
At the moment it only exports files in PDF or EPS format. There are free PDF to DXF converters about.
There is a plugin for Sketchup which generates slices for laser cutting but I can't see (without installing Sketchup and the plug in) what format it exports the slices in.
Cheers.
[Apologies to Chazz - I just noticed that you'd also suggested 123D MAKE]
Re: Slicer software
« Reply #7 on: July 11, 2012, 07:35:40 PM »
Yeah... What I thought was a document talking about software that does this... isn't. It is a document that talks about doing this manually!
Sorry.
Offline woodguy
Re: Slicer software
« Reply #8 on: July 12, 2012, 06:55:45 PM »
The Meshlab page here: http://meshlab.sourceforge.net/  says:
"Slicing tool. A new tool that allows to export planar sections of a mesh in SVG format "
Inkscape will read SVG and write dxf
I haven't tried any of this.
Offline wongster
Re: Slicer software
« Reply #9 on: August 06, 2012, 09:48:11 AM »
I've seen it done using bobcadcam. I'll try to find the video. Did the same to extract profile for lathe work. Basically a plane (or several planes) is drawn cutting into the solid model. The intersection is then taken, leaving behind the slices required.
Add: This is the video:
3G was acting up. Couldn't play the video to confirm earlier.  I can't recall if BobCad can export to DXF. Will check when I get home.
Regards,
Wong
edit: embeded link ds
« Last Edit: August 06, 2012, 01:07:33 PM by dsquire »
