Author Topic: Chester Mini Mill.  (Read 47190 times)
Chester Mini Mill.
« on: February 26, 2009, 12:39:50 PM »
About a month or so ago, I decided to sort out the exhaust system of my 3 cylinder Mamod steam engine.
My idea was to run all 3 of the 1/8" pipes separately into a spigoted chimney base, with the condensate draining out the other side via a pipe into a trough.
A bit like this.......
http://i110.photobucket.com/albums/n95/Dayjo/p2250006.jpgChester Mini Mill.
The problem was how to drill the holes tidily, with my lightweight Chinese bench drill....... :scratch:
I was offered a much heavier, English bench drill...... “You could do a bit of milling with that!”.  :thumbup:
So..... I asked you lot about cross vices.........  :wave:
During the drilling demo, some of the smoke leaked out of the motor!  :bugeye:
And we all know how hard it is to get it back inside again......  :scratch:
Smoke, plus your disapproval of cross vices seemed to be some kind of omen.........  :poke:
A Mini Mill arrived a few days later!   :clap:
This is what was in the box.
Everything as promised, but a 100mm vice instead of 80mm...... No complaints!  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/p2200018.jpgChester Mini Mill.
My son helped me lift it onto the 18” wide bench, still bolted to the packing crate base. .......
I didn`t wish to drill permanent mounting holes in my bench, but I don`t mind woodscrew holes.
So, I thinned down the heads of some 10mm x 50mm builder`s bolts & assembled to 2 thicknesses of 12mm ply glued & screwed together.
http://i110.photobucket.com/albums/n95/Dayjo/p2220001.jpgChester Mini Mill.
With a woodscrew at each corner this should be ok!  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/p2220003-1.jpgChester Mini Mill.
We`re a bit short of light, up this end........  ::)
http://i110.photobucket.com/albums/n95/Dayjo/p2240003.jpgChester Mini Mill.
Bought an extra 4` striplight......... That`s better!  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/p2240007.jpgChester Mini Mill.
Then the new collets arrived....
Well, I`ve now spent over £500...........  ::)
And I still haven`t any holes in my chimney base!
http://i110.photobucket.com/albums/n95/Dayjo/p2250003.jpgChester Mini Mill.
One day...... Soon, I hope.....
Re: Chester Mini Mill.
« Reply #1 on: February 26, 2009, 01:20:50 PM »
Rather expensive David, at nearly 170 squid a hole.
But think on the positive side.
A normal charge for hole drilling at an engineering shop is 2 squid per hole (setup charges extra).
So once you have drilled 250 holes, you will start to be in profit. :lol:
« Reply #2 on: February 26, 2009, 01:29:41 PM »
And you will have assets to dispose of at a later date....should you ever wish/need to.. :thumbup:
Well that's how I put it to the boss  :lol:
« Reply #3 on: February 27, 2009, 08:14:35 AM »
250 holes? That is a long time off.....
Does that include all the cutters, index head, T nuts, studding, DTI, wobbler, etc. etc I will need for the future?  ::)
Going toolbox opening this afternoon.
They`re still as I left em, on retirement day. Wonder what I might find in there.....  :thumbup:
Darren,
Funny you should say that.......
Yesterday was a watershed in the Drillin household......
After 40 or so years, at last I didn`t need to be evasive!  :D
"What do you need all this machinery for?"
"So that, now we`re fully settled into retirement, I can continue making things, as I have done since being a schoolboy"
"Also, in our present excellent circumstances, why shouldnt we buy whatever we want, when we want it?"
I held my breath.
But, there was no tut, no sigh, no comment.....
Only..... "Ah, yes". "Shall I put the kettle on?"
Yesterday was a good day........  :thumbup:
« Reply #4 on: February 27, 2009, 08:49:03 AM »
New sofa, carpet, bedding, curtains, cooker, heck the whole kitchen inc the flooring it is then...... :clap:
"WE" can be a very expensive word  :lol:
« Reply #5 on: February 27, 2009, 12:02:40 PM »
No problem.......
We can afford it!  :thumbup:
Found a few usefull artifacts this afternoon......  :clap:
http://i110.photobucket.com/albums/n95/Dayjo/p2270004.jpgChester Mini Mill.
Almost brand new finger clock.
Magnetic base.
Wobbler.
10 or so assorted cutters.
6 off 10mm "oversize" (compared to supplied) T nuts.
That will do nicely.....  :thumbup:
« Last Edit: February 27, 2009, 12:26:14 PM by Stilldrillin »
Offline malcolmt
« Reply #6 on: February 27, 2009, 06:53:26 PM »
David
Nice Find
Where did you Find Them
Malc
« Reply #7 on: February 28, 2009, 01:51:27 AM »
Nice find David
Those DTI are a real good addition to any ones tool box got a 1000 and 1 uses,
you'r realy cooking on gas now  :ddb:
Have fun
« Reply #8 on: February 28, 2009, 02:31:04 AM »
Malc
Malc,
It`s just amazing what follows you home, during a whole engineering career.  ::)
I`m sure several little surprises are still waiting to be discovered in long forgotten corners & boxes.  :clap:
The T nuts were a complete, happy surprise!  :thumbup:
I only recall using 5/8 Whit, or in later years 20 & 24mm.......
Stew,
Thanks mate....... I am having great fun!  :thumbup:
« Last Edit: February 28, 2009, 03:27:28 AM by Stilldrillin »
« Reply #9 on: March 01, 2009, 04:10:18 AM »
Finally got the machine stripped.
Red gloop everywhere, outside...... Dry, no lube anywhere inside......  ::)
http://i110.photobucket.com/albums/n95/Dayjo/p2270006.jpgChester Mini Mill.
http://i110.photobucket.com/albums/n95/Dayjo/p2280003.jpgChester Mini Mill.
http://i110.photobucket.com/albums/n95/Dayjo/p2280004-1.jpgChester Mini Mill.
http://i110.photobucket.com/albums/n95/Dayjo/p2280009.jpgChester Mini Mill.
http://i110.photobucket.com/albums/n95/Dayjo/p2280007.jpgChester Mini Mill.
Now starting to rebuild, with better fitting & adjustment......  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/p22800015.jpgChester Mini Mill.
All going well, so far....
« Reply #10 on: March 03, 2009, 04:06:28 AM »
A few more more pics.......
Both X & Y axese adjusting strips had grooves caused by the edge of the dovetail not being deburred properly...... Soon filed away.
Also spun the adjusting screws in the lathe to file to a "drill point " angle for better location in the dimples.
http://i110.photobucket.com/albums/n95/Dayjo/p3020003.jpgChester Mini Mill.
Silky smooth slide.....
http://i110.photobucket.com/albums/n95/Dayjo/p3020007.jpgChester Mini Mill.
All oiled & greased, leadscrew nuts positioned, baggy handwheel handles bushed etc. ::)
Ready for tramming.......  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/p3020008.jpgChester Mini Mill.
« Reply #11 on: March 03, 2009, 04:11:59 AM »
Lovely looking bit of kit,
I see you're putting that DTI to use already.  :thumbup:
You'll soon be cutting metal don't forget we'd like to see what your up to
« Reply #12 on: March 03, 2009, 04:44:00 AM »
David,
An hour or two spent setting the machine up correctly before you start using it, will be repaid with many years of satisfactory use.
These machines are invariable faily well made nowadays, but slung together by untrained erks, and can be made very accurate by doing just what you are getting up to.
It is when using the machine straight out of the box that problems are encountered. And of course the suppliers get slagged off for selling unstable garbage, when it is usually the buyers fault for not fine tuning it.
Well done.
« Reply #13 on: March 03, 2009, 10:11:24 AM »
David,
Very nice looking machine. Looks very simular to my Grizzly mini mill.
Question? From the pics I see that it uses inches on the scale so I'm assuming that the dials are graduated in thousands of an inch?
Now if this is the same as my mill I'm wondering if the lead screws on the machine are 16TPI or 20TPI. Here's the reason I ask. Go to my website and check out my page on the Mini-Mill. You'll see what I'm talking about.
Regards,
« Reply #14 on: March 03, 2009, 01:03:15 PM »
Thanks for your positive comments Fellas.....
Finished setting up today!!   :headbang:
Bernd,
Thanks for your link, I haven`t seen that one before. Will give it closer inspection!
My screws are 16tpi. With the drive slot....... And it`s a heck of a long way from one end to the other!
Don`t really fancy a finer pitch, just yet......  ::)
The Y axis was out by .008" high to the front.
http://i110.photobucket.com/albums/n95/Dayjo/p3020012.jpgChester Mini Mill.
I slipped a 1/4" wide strip of drinks can alloy, under the front of the column & re tightened the capheads.
This gave me one an a half thou...... Don`t remember which way...... That`ll do, for now!  :thumbup:
Got the X axis to .001" over it`s full table length, via the column nut.  :D
Time for a bit of bling (my version)......
That gear lever`s blummin `orrible!  :scratch:
http://i110.photobucket.com/albums/n95/Dayjo/p3030002.jpgChester Mini Mill.
Short throw, GT version!  :thumbup:
http://i110.photobucket.com/albums/n95/Dayjo/p3030003.jpgChester Mini Mill.
Hmmm....... Hadn`t spotted the remaining red grease!  :doh:
It all feels silky smooth & ready to go......  :thumbup:
Gonna make some chippings tomorrow....... Re machine those T nuts, probably!  :clap:
« Last Edit: March 04, 2009, 02:26:04 AM by Stilldrillin »
« Reply #15 on: March 05, 2009, 11:54:47 AM »
Final pic.
This afternoon.......
http://i110.photobucket.com/albums/n95/Dayjo/p3050014.jpgChester Mini Mill.
After 3yrs in retirement, "Mick the Miller" is back in business!  :clap:
Stillmillin    :thumbup:
« Reply #16 on: March 05, 2009, 12:02:32 PM »
Good to see it all up and running. I just hope that isn't your table you're milling thru.
« Reply #17 on: March 05, 2009, 12:31:51 PM »
Doesn`t everyone mill directly on the table?  :scratch:  ::)
Actually, I was plunging 1mm or so of material from the inner end of the vice clamp slots, centred over the 12mm wide T slot.
Tale of woe to be posted imminently........  :bang:
Offline SPiN Racing
« Reply #18 on: March 07, 2009, 07:55:15 AM »
AWESOME CONGRATS!!!
SPiN Racing
Offline shoey51
« Reply #19 on: March 17, 2009, 03:46:28 PM »
 :bugeye: wow David so this ins where you have been hiding.
great thread mate and a great bit of kit would love one of those as well.
still learning to use the lathe here myself and I think im progressing fairly well myself :).
say hi to SWMBO mate from Jilly and me
cheers Graham
« Reply #20 on: March 18, 2009, 03:21:31 AM »
cheers Graham
Mornin` Graham!
Welcome to the forum mate. Lovely to see you`ve joined us.  :clap:
Christine says hello, she`s just behind me at the mo`.  :wave:
Have a good look around, this is the perfect forum for the likes of us, and the natives are very friendly (mostly)....  :thumbup:
Looking forward to seeing how your loco build is going.
Enjoy!
« Reply #21 on: March 18, 2009, 04:07:20 AM »
cheers Graham
Mornin` Graham!
Enjoy!
Hi Graham  (Bit of a hi jack sorry David)  But my ears pricked up with the word loco:-  so lets see some photos then as
 :worthless:
Bit of a loco buff myselfe, on my first build, only slightly deiverted with the elbow engine  :proj:
« Reply #22 on: March 18, 2009, 04:20:51 AM »
[/quote]
[/quote]
Don't be embarrassed about it Stew.............. :ddb: :ddb: :ddb:
Offline shoey51
« Reply #23 on: March 18, 2009, 05:21:40 AM »
thats all coming together really well mate jilly is reading this with me.
had a bit of a problem with my lathe there was two striped lockdown bolt thingys  and I picked them up this arvo
now to put the cross slide back together
thanks for shareing this forum with me Ill have to spend hours catching up
cheers Graham
Offline shoey51
« Reply #24 on: March 30, 2009, 10:54:48 PM »
Hi David I have been looking at a mill at my local hoby supply
http://i153.photobucket.com/albums/s208/Graham-Jilly/MVS0940.jpgChester Mini Mill.
Looks verry similar to yours
just wondering how happy you are with it
cheers Graham
