Author Topic: My little Demon so far.  (Read 59958 times)
Offline Doc
    • My Youtube Channel
Re: My little Demon so far.
« Reply #125 on: December 31, 2016, 06:34:20 PM »
 I was going to anneal and then fill with sand but I king of like the filling it with lead I may give that a go. I have lots of tractor lead wheel weights. If this doesn't work  will up the radius to maybe .5 or .625. I just wanted to try and see if I could go down to a .375. The freeze thing as slow as I am it would all be melted by the time I got started bending it. :lol:
George
Offline ieezitin
« Reply #126 on: December 31, 2016, 07:23:30 PM »
Doc..
Experiment for sure ...... I vote for fine sand.. interested on your findings.. happy new year brother.
Anthony.
« Reply #127 on: December 31, 2016, 08:16:45 PM »
Doc,just do a google search for sand bending tube or pipe. There are several very informative videos on youtube.
The technique involves keeping the heat mostly on the outer side of the curve being formed.
OZ
Link to one vid here,there is loads more through google search.
And another:
« Reply #128 on: January 01, 2017, 03:37:14 AM »
Cerobend is the stuff to use. Melts in hot water
« Reply #129 on: January 01, 2017, 04:39:57 PM »
Offline ieezitin
« Reply #130 on: January 02, 2017, 11:13:23 AM »
Just did the research on this stuff it looks Pukka..
If anyone uses this product in the future please make a post of it Hopefully Doc gives it a whirl
Anthony.
« Reply #131 on: January 02, 2017, 11:53:36 AM »
I've been using it for decades  :bugeye:
Not only for bending pipes without them crushing, but also for fixturing awkwardly shaped bits for machining - just set them in a simple mould box, pour it in, then grip in a vice and machine the part. Melt out in hot water when done - save for reuse :thumbup:
« Reply #132 on: January 02, 2017, 05:12:27 PM »
I bought this to give some to my grandaughter for jewelry making to hold stones for drilling.
Offline ieezitin
« Reply #133 on: January 02, 2017, 06:20:26 PM »
Andrew..
Blinding idea for holding work for machining smashing... im going to give that a try thank you very much..
Anthony.
Offline Doc
« Reply #134 on: January 02, 2017, 09:08:20 PM »
Thanks for the info guys. You need to be careful some of that stuff has cadmium and that stuff isn't to good for you. We use to use some stuff at work like that to hold complex parts for machining. I may order some medical grade stuff (no cadmium) it could come in real handy.
Thanks!
George
Offline Doc
« Reply #135 on: January 03, 2017, 06:29:52 PM »
Didn't get any shop time last few days we ended up with another 10 inches of snow. So I have been busy moving snow again. I did grab the camera last night while moving snow.
George
Offline Doc
« Reply #136 on: January 07, 2017, 09:51:19 AM »
  Ok I did get the tanks at the right height and fuel line attached. I do need to come up with some small hose clamps of some sort. I added a short video the sound is terrible I used the new camera with  the sport case on it so now I know not to put the case on it again.  Anyway I'm going to work on the pipes and a temp coolant tank  to take the place of radiator. Shouldn't be long now I do have some mis things to wrap up but hoping to be able to give it a try next week end. Depending on how the bending and pipe thing goes
PS I did get the new batch of liquid rubber haven't had a chance to give it a try yet. I sure hope the stuff setts up this time.
George
Offline Doc
« Reply #137 on: January 07, 2017, 06:59:30 PM »
Bending tubes for exhaust and trying to get them the same length and angle.
George
Offline ieezitin
« Reply #138 on: January 08, 2017, 08:26:01 AM »
Good deal Doc... your bender could do with a handle that's a tad longer..   :palm:
Anthony.
Offline Doc
« Reply #139 on: January 08, 2017, 09:03:38 AM »
Anthony.
Haha yes it could but I'm done with it for now.
George
Offline Doc
« Reply #140 on: January 08, 2017, 09:24:30 AM »
  Ok have exhaust pipes done for now so on to the plug wires again. I think the first thing I will do is make some wire organizers. The silver soldering went pretty good for the most part. I did solder one with the video camera running. I may end up painting the set that will go onto the engine that I have put paint on.
  I also got the new set of liquid rubber stuff that the first batch didn't work (wouldn't set up beyond black goo) I hope this stuff will work. It is suppose to get to the hardness of tie rubber (according to their advertisement) I'll probably try the stuff out this week. I'm hoping the cold temp isn't what caused the first batch to not work because when they delivered it, again it was well below 0 degrees f.
George
Offline Doc
« Reply #141 on: January 08, 2017, 04:33:02 PM »
Still messing with the exhaust tubing.
George
Offline Doc
« Reply #142 on: January 09, 2017, 09:39:09 PM »
Ok update on wire organizers and  also tried out the 2nd batch of liquid rubber.
George
« Reply #143 on: January 09, 2017, 11:20:32 PM »
Nice work George.   :thumbup:
I have been wanting to order the plans for the Little Demon for awhile now. I went so far as to get a set of gaskets off Steve when he was selling them. I just need to order the plans and have the time to build it. I keep postponing... But reading your build is starting to inspire me to order the plans.
Keep up the good work!
Offline Doc
« Reply #144 on: January 10, 2017, 01:13:01 PM »
Thank Eric !
I purchased the plans when Steve first offered them. I do design work and drafting so I know how much work goes into this kind of thing and I couldn't believe the sweet deal he offered so I jumped on it. It has been a fun build but I've been kind of slow at getting things done but I am getting close.
George
Offline Doc
« Reply #145 on: January 10, 2017, 08:24:11 PM »
Here is a pic of the first boot I'm uploading the video of me removing the cores and taking it out of the mold. I had trouble getting the cores out the next one I put a little more Vaseline on the cores this time. The rubber did set up pretty nice this time.
George
Offline Doc
« Reply #146 on: January 11, 2017, 08:29:22 AM »
e is the vid of the taking the first boot out of mold and removing cores.
George
« Reply #147 on: January 11, 2017, 05:50:07 PM »
Nice work on the boots who did you get the kit off of. Are they as hard as tyre rubber like they said?
If you decide to scrap that one or have some scrap about it would be interestimg to see what happens when in contact with oil / gas.
Offline Doc
« Reply #148 on: January 11, 2017, 07:31:23 PM »
 First out of the mold it's not as hard as a tire but after setting another day I'd say it's close. I got it off ebay I'm happy with the hardness and the stuff has some tinsel strength. The first one getting the cores out I had to use a pliers and I twisted the crap out of the stuff and only suffered a small little tear.
   I fixed the little tear when I mixed and did another boot I dabbed a little on an now you can't find the tear.
 I redid the mold to add a little collar around where the plug goes into the boot once I get it the way I want I'll create a mold to do 4 at a time.
George
Offline Doc
« Reply #149 on: January 12, 2017, 04:48:42 PM »
plug boots update
George
