Author Topic: Coke Forge Build  (Read 104948 times)
Re: Coke Forge Build
« Reply #50 on: February 19, 2015, 12:37:47 PM »
Rob's work is so amazing   :bugeye:   :bugeye:   :bugeye: that I have to take a courage pill before I dare post my simple stuff!   :doh:   :doh:   :doh:
    • www. sredmond.com
« Reply #51 on: February 19, 2015, 01:02:08 PM »
I second that, Pete.... :bow: :bow: :bow: :bow:
www.sredmond.com
« Reply #52 on: February 21, 2015, 03:20:01 AM »
Thanks Joe , Pete and Steve  :beer: :wave:
I need a valve to control the air flow , so I decided to make a butterfly valve  :dremel:
The valve body so far. Machined from a bit mystery steel .
Setting the flat in the correct orientation with the PCD of the slots .
Body done  :dremel:
And a couple of BRASS bushes (not to be confused with Bronzes as that's quite different   :palm: )   for the spindle were machined up and pressed into the body .
I Nickel  plated the valve body to give it some corrosion resistances  :zap:
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #53 on: February 21, 2015, 02:09:28 PM »
Hmpf, i have Aciera as well.. why doesnt my bits look like that. ;D
« Reply #54 on: February 21, 2015, 03:31:20 PM »
 :) I am sure it works the same Neo  :poke: :lol:
Decided to do something different today , so I etched up some name plates to go on the forge and blower , smaller two  are to go on some tooling I have made .
Undecided on weather or not to add a colour infill  :scratch:
Offline NeoTech
« Reply #55 on: February 21, 2015, 03:39:34 PM »
Etched... how.. when does these etching, plating and all around goodie things come in a project log - more like tutorial ??  :drool:
Online awemawson
« Reply #56 on: February 21, 2015, 04:01:13 PM »
Very nice Rob, even by your normally excellent standard - you must tell more  :bow:
    • www. sredmond.com
« Reply #57 on: February 21, 2015, 04:23:22 PM »
Rob, your'e really blurring the line for us between praise and expletives!
www.sredmond.com
« Reply #58 on: February 21, 2015, 04:55:59 PM »
I'm running out of things to say. I think a nice bright background colour would be nice. Pick a colour and make it you.   :D
« Reply #59 on: February 21, 2015, 04:59:57 PM »
 Hi Rob , came out really nice, you might as well try one with the inlay , British racing Green maybe ?? or deep racing red if its going on grey machine ?
  Cheers Mick
« Reply #60 on: February 21, 2015, 05:08:54 PM »
Cheers Lads  :beer:
When I get things sorted I will do a how to , its just photo etching not at all hard to do  :dremel:
I will pick up some spray paint tomorrow , I only have Black on the shelf , must remember some wet n dry as well  .
Thanks Rob
« Reply #61 on: February 22, 2015, 05:00:57 PM »
well dune rob
« Reply #62 on: February 22, 2015, 11:07:22 PM »
I like the etchings. Fantastic stuff... another thing I need to learn to do!
« Reply #63 on: February 23, 2015, 02:47:39 PM »
Cheers Bob and Eric  :beer:
Decided to try a Blue infill  :)
Still room for improvement ,a few things I need to work on ,like were I cut through the plating  :Doh:  , but for now it will do to slap on  the forge  :thumbup:
Offline CrazyModder
  • Country: de
« Reply #64 on: February 23, 2015, 02:58:00 PM »
So, which etching method do you use? Is it basically like making PCB boards (shine light through some positive printout, develop with NaOH, then etch with FeCl3 or something like that)?
« Reply #65 on: February 23, 2015, 03:01:01 PM »
Very nice mate
It would look great in dark green
    • www. sredmond.com
« Reply #66 on: February 23, 2015, 03:01:17 PM »
That should dress up the forge right smart, Rob!  :thumbup:
www.sredmond.com
« Reply #67 on: February 23, 2015, 03:07:18 PM »
Yer , basically the same process as making a PCB board .
Cheers John ,,,,,not green  :palm:
Aye its all aboot the BLING Steve  ,,,,it  wont make the forge work any better  :lol: :lol:
Think I will have ago at some Aluminium plate and Anodize them to see what they look like ,,,,,,,,,,,, may look cooooool  :med:
Offline S. Heslop
« Reply #68 on: February 23, 2015, 03:33:30 PM »
That's real swish looking. I'll have to have a try at making some plates myself some time. Is it just steel?
« Reply #69 on: February 23, 2015, 03:47:43 PM »
I used Brass Simon , Steel should work OK , I will be giving Ally and Steel ago .
« Reply #70 on: February 23, 2015, 04:13:46 PM »
Could brick acid be used for etching as that is easily available and pretty cheap ?
Offline kayzed1
« Reply #71 on: February 23, 2015, 04:58:20 PM »
Very Very nice Rob, but i bet you have bought a new even better camera :lol: cos your stuff looks more betterfull ( is that a word ? ) than ever. :thumbup:
Lyn still trying ...
    • www. sredmond.com
« Reply #72 on: February 23, 2015, 05:09:36 PM »
It it's the same as muriatic acid (dilute hydrochloric) here I generally use that for cleaning scale and zinc off of steel, but it seems to leave the steel intact. Maybe because it's diluted, or I didn't notice -- even after a couple of mistaken overnight cleanings in it.
It also seems to work well to clean scale off of brazing and copper based parts that I've tried. But again, i didn't notice it eating away the base metal.
It will really tear into zinc, though!
www.sredmond.com
« Reply #73 on: February 23, 2015, 05:13:51 PM »
Hi Joules , I used Ferric Chloride (the same gear used to etch PCBs ) , if you have Brick cleaner (usually Hydrochloric acid) to hand then give it ago , it may work .
Cheers Lyn    :beer:  ,,,,,,,,,,,,, and no same camera ,just better at Photoshop  :)
    • www. sredmond.com
« Reply #74 on: February 23, 2015, 05:15:06 PM »
I forgot -- I have done electrochemical etching of steel  -- to make reed valves for pulsejet engines. Maybe that's a possibility. But i think there'd be some undercutting of the letters if you went anywhere near as deep as Rob has.....
www.sredmond.com
