Author Topic: But I can't brush my Teeth !!!!  (Read 27180 times)
Online awemawson
« on: March 12, 2017, 02:22:50 PM »
Sunday - a day of rest - but SOMETHING woke me up - ok no point in lying in bed, get up and do things! First action, brush my teeth. Oi who stole the water  :bang:
OK there was water but at a very low pressure. I glanced out of the bedroom window to see a 'gusher' in the front garden - probably about 6" out of the ground and LOTS of flow  :bugeye:
Quick Google got me Southern Water's emergency number, and when I called them they said they'd had several low pressure reports and were searching for the leak - 'I think I know were it is' I said !
This was just after 7 am - team turned up about 9 am but before arrival they'd shut valves to stem the flow - in the mean time I took a little video and a few pictures:
« Last Edit: March 12, 2017, 03:06:33 PM by awemawson »
Online awemawson
Re: But I can't brush my Teeth !!!!
« Reply #1 on: March 12, 2017, 02:29:56 PM »
They brought a 1 ton digger with them and started digging up my front lawn - very soggy - lots of mess  :scratch:
Eventually they got down to what was shown on the plans as a 150 mm ductile iron water main, but in practice turned out to be a 150 mm asbestos water main  :bugeye:
Oops - need another team - not allowed to cut asbestos pipes. OK another couple of fellows suitably trained turn up, and they decide to cut a 4 metre section out and replace flange to flange. More digging, big lorry arrives with 6 metre length of (this time actually ductile cast iron) pipe flanges etc
Careful measure up and out with the petrol cutter to slice off the extra
Online awemawson
« Reply #2 on: March 12, 2017, 02:32:43 PM »
Now while this is happening we have no water for the livestock so I pressed them for a bowser to be delivered, which eventually turns up
« Last Edit: March 21, 2017, 04:31:41 PM by awemawson »
Online awemawson
« Reply #3 on: March 12, 2017, 02:33:37 PM »
Cut length of bally heavy pipe now man ported across the soggy lawn and put in place.
The crack in the original pipe is substantial as you can see in one of the pictures
Online awemawson
« Reply #4 on: March 12, 2017, 02:41:12 PM »
So, leak fixed time to turn on the water  :thumbup:
Ah - ever heard of water hammer  :scratch: :scratch: :scratch: :scratch:
Big hammer effect as large volume of water flows into big pipe - BURSTING THE PIPE about 30 foot further along our hedge.
As I type, there is another even bigger hole being dug and about 10 metres of my front laurel hedge have been felled to insert yet anther new bit. They had to borrow my JCB 803 for this hole as theirs wasn't big enough !
They intend to fit a fire hydrant in our front garden on this section, and have it open when the pipe is re-filled to stop the water hammer, but it's now 18:40 - still no water, and I'm having supper - more pictures later !
« Last Edit: March 12, 2017, 03:09:05 PM by awemawson »
« Reply #5 on: March 12, 2017, 02:48:06 PM »
Now - that calls for something that rhymes with clacking bell!
Online awemawson
« Reply #6 on: March 12, 2017, 03:24:38 PM »
So supper finished but they're still at it - gave them a can of beer each as a consolation prize -  here's a few more pictures:
I'm glad that I installed good lights on the JCB803
In the last picture the hydrant is just visible in the bottom left corner
Offline John Swift
« Reply #7 on: March 12, 2017, 03:33:16 PM »
they have only done half the job
for what they charge for the water they should of replaced all of the old 6" asbestos pipe
(unless they plan to come back several times over the next few years )
Online awemawson
« Reply #8 on: March 12, 2017, 03:41:23 PM »
I agree John, it's daft - but this is a 'repair' by the emergency team and not a 're-lay' by the project team. I'll certainly tread carefully on that bit of lawn in the future  :clap:
Offline Spurry
  • Norfolk, UK
« Reply #9 on: March 12, 2017, 03:46:19 PM »
Is that the village supply pipe? We have to make do with a puny 1" plastic supply pipe.
« Reply #10 on: March 12, 2017, 03:54:53 PM »
Hi Andrew!
Chris tells me that there hasn't heard about your leak yet! Are you South East or Southern?
All the best! Matthew
Online awemawson
« Reply #11 on: March 12, 2017, 03:56:21 PM »
That 150 mm does us, two house further up the road (A21), then a small industrial estate and about 50 houses on the way into Battle down Marley Lane.
The Water Board have put up a public Bowser in the Lay-Bay across the road but we have our own  :ddb:
Online awemawson
« Reply #12 on: March 12, 2017, 03:56:52 PM »
Hi Andrew!
South East Matthew
« Reply #13 on: March 12, 2017, 04:19:54 PM »
Always an adventure at your place!
Seems you take it all in stride and with a good sense of humour (at least that's how you tell the story later anyway).
Online awemawson
« Reply #14 on: March 12, 2017, 04:46:10 PM »
Well Sparky there's no point in ranting and raving and getting under the skin of the poor chaps fixing the problem, they're doing their best.
Anyway - 20:30 Sunday Evening, and I've been able to wash my Wellies off under the outside tap - yes WE HAVE WATER  :clap: :clap: :clap:
The front garden now looks like The Somme with slit trenches, piles of earth, cut down hedging, but at least given time it's all repairable. The restitution team are apparently going to turn up on Monday or Tuesday, fill in the trenches, level the piles of earth, and re-turf the lawn.
I'll take some pictures when the sun returns
Offline howsitwork?
« Reply #15 on: March 12, 2017, 06:07:51 PM »
Andrew
surely there's a re-enactment team somewhere down your way???  :ddb: :ddb: :ddb:
Sealed Knot specialize in civil war , not sure who covers 1914- 18 period but at least give 'em a chance!!
Glad to hear you're flush again, I assume your charging piece rates for the use of the JCB?  :headbang:
Hope the re turning etc goes well.
Ian
« Reply #16 on: March 12, 2017, 07:52:10 PM »
Blimey I was going to come and visit you today. Sounds like you had enough on your plate without me making a nuisance too :D
Online awemawson
« Reply #17 on: March 13, 2017, 03:40:45 AM »
Be glad to see you Pete, no issue with plate overload  :thumbup:
Online awemawson
« Reply #18 on: March 13, 2017, 07:16:21 AM »
 :update:
So this morning I woke up to quite a different view from the bedroom windows :
Online awemawson
« Reply #19 on: March 13, 2017, 07:19:02 AM »
And it didn't get a lot better from ground level  :scratch:
Online awemawson
« Reply #20 on: March 13, 2017, 07:20:22 AM »
Still, look on the bright side - we now have our own private fire hydrant  :lol:
Offline Spurry
  • Norfolk, UK
« Reply #21 on: March 13, 2017, 07:31:02 AM »
Corr, that's a bonus Andrew. A water supply with no meter.  :D
Online awemawson
« Reply #22 on: March 13, 2017, 07:40:55 AM »
..... that DID briefly cross my mind Pete .......  :ddb: :ddb: :ddb:
Offline DaveS
« Reply #23 on: March 13, 2017, 10:21:26 AM »
Andrew,
Sorry to hear of your  major inconvinience (bit of an understatement) hopefully they don't cause too much agro over the landscapeing. I assume the water didn't flow west as there have been reports of an approaching Tsunami in my area.
That was some gusher and at least their response was quick and the new pipework is a very good match to your Plasma machine.
Online awemawson
« Reply #24 on: March 13, 2017, 11:02:23 AM »
" and the new pipework is a very good match to your Plasma machine"
 :lol: :lol: :lol: :lol:
