Author Topic: Little Blazer X4  (Read 3973 times)
Offline Doc
    • My Youtube Channel
Little Blazer X4
« on: January 07, 2018, 09:29:36 PM »
I'm building 4 Little Blazer engines I plan on maybe selling a couple to try and raise some money for our local humane society.
Anyway here is a vid f what I have so far.
« Last Edit: February 08, 2018, 07:49:50 PM by Doc »
Re: Little Blazer X4
« Reply #1 on: January 08, 2018, 10:56:23 AM »
Raising money for the local humane shelter... That my friend is a good cause. Will watch the video in a little bit.
Offline Doc
« Reply #2 on: January 13, 2018, 08:21:41 AM »
Been a bit since I've been in the shop. Hope to get some done this weekend.
« Last Edit: February 08, 2018, 07:49:26 PM by Doc »
Offline Doc
« Reply #3 on: January 13, 2018, 11:29:07 AM »
The plan for the crank and cam disk.
« Last Edit: February 08, 2018, 07:48:58 PM by Doc »
Offline Doc
« Reply #4 on: January 15, 2018, 09:40:54 AM »
Ok next made prep-parts and cut them on NC machine.
« Last Edit: February 08, 2018, 07:48:30 PM by Doc »
Offline Doc
« Reply #5 on: January 20, 2018, 07:37:49 AM »
Work on the fly wheels roughed out on nc then trued up on the lathe.
« Last Edit: February 08, 2018, 07:48:00 PM by Doc »
  • Country: ie
« Reply #6 on: January 21, 2018, 05:45:17 PM »
Excellent videos Doc, much appreciated.
I am currently converting to CNC so I  naturally have a few questions and observations:
1. What CAD/CAM system/setup are you using?
2. Is that a CNC'd Bridgeport?
3. The last operation to machine the flywheel OD scared the S*1T out of me. The part could easily have rotated as you milled off the corners a full 1/4" by 0.25
    You could have stuck two sheets of emery paper back to back which would have improve the friction immensely. Also the extra few tho' would have allowed you to mill clear of the part and not into your table.
Will, Malahide, Co. Dublin.ie
Offline Doc
« Reply #7 on: January 21, 2018, 09:03:49 PM »
I was beginning to wonder if anyone was interested in the Little Blazer build but I'll keep chugging along.
   I will sell one for sure for the local human society maybe also a Little Thumper engine also.
My machine is pretty much a Bridgeport it is a CNC Master Supra mill from CNC masters.
Thanks for the comment! And yes some times I scare myself but if she would have moved it would have just spun on the pin but it's surprising how much a small clamp wit a #10 screw will hold.
« Reply #8 on: January 22, 2018, 12:12:36 AM »
I'm watching so far so good!
« Reply #9 on: January 22, 2018, 06:25:10 AM »
Hi Doc,
I'm watching!
Offline kayzed1
« Reply #10 on: January 22, 2018, 03:16:11 PM »
I'm watching also Doc...keep up the good work.
Lyn.
Offline Doc
« Reply #11 on: January 24, 2018, 11:17:55 AM »
Thanks guys for the comments lets me know someone is interested or watching out there.
Finishing up pistons and turning up and making wrist pins or posts.
« Last Edit: February 08, 2018, 07:47:18 PM by Doc »
Offline Doc
« Reply #12 on: January 28, 2018, 09:58:48 AM »
Connecting rods done.
Getting close valve rod fork, bushings and burner left to do.
« Last Edit: February 08, 2018, 07:46:31 PM by Doc »
Offline Doc
« Reply #13 on: February 04, 2018, 10:34:08 AM »
Cam roller fork.
« Last Edit: February 08, 2018, 07:45:55 PM by Doc »
Offline Doc
« Reply #14 on: February 06, 2018, 12:34:11 AM »
« Last Edit: February 08, 2018, 07:45:06 PM by Doc »
« Reply #15 on: February 06, 2018, 04:55:45 AM »
Hi Doc
                 They are coming along just fine. Like the videos.
Offline Doc
« Reply #16 on: February 07, 2018, 05:11:10 PM »
Thanks David I appreciate the comment!
« Last Edit: February 08, 2018, 07:44:21 PM by Doc »
Offline Doc
« Reply #17 on: February 08, 2018, 05:38:31 PM »
« Last Edit: February 08, 2018, 07:43:28 PM by Doc »
Offline Doc
« Reply #18 on: February 08, 2018, 07:55:24 PM »
Piston to cylinder fit on Little Blazer engines.
Offline Doc
« Reply #19 on: February 10, 2018, 10:45:01 PM »
Offline Doc
« Reply #20 on: February 11, 2018, 08:50:24 PM »
Well all 4 have had their first run need to makes base for each yet but as far as the motors I'll call the motor build done.
Offline Doc
« Reply #21 on: February 16, 2018, 09:53:53 PM »
Started cleaning them up and a little paint and will do a final assembly
« Reply #22 on: February 17, 2018, 02:53:42 AM »
  Hi Doc
                          The little burners turned out well, like the tip of coiling the solder will use that on future projects. The engine runs very nicely.
                                                    Well Done
        Ceers David
Offline Doc
« Reply #23 on: February 17, 2018, 08:51:47 AM »
Thanks David
  I'm in the process of cleaning and final assembly I'll try and get some pictures f them done and maybe a short video when I get them completely done.
Offline kayzed1
« Reply #24 on: February 17, 2018, 11:01:06 AM »
Yet another great thread Doc, thank you for putting it all up.
Ow! how i wish i could do stuff like this. One day.
Lyn. :clap:
