Author Topic: DDCSV Control Language  (Read 888 times)
  • Country: ie
« on: February 13, 2018, 10:14:52 AM »
AS you have seen from previous posts I have been trying to understand the control language that enhances G-Code.
I wrote a simple routine:
(Safe Block)
G17 G21 G90 G54 G40 G49 G80
(Read the current tool mechanical coordinate position i.e MACH workspace)
(#20 is X, #21 is Y, #22 is Z)
#20=#864
#21=#865
#22=#866
(I want things nice and slow)
F50.0
IF #22 LT 20 GOTO 1; If Z < 20
   G01 Y#21 - 10; Z is > 20 so Move Y minus 10
   GOTO 2
N1 G01 X#20 + 10; Z is < 20 so Move X plus 10
N2 M30
and it actually works!!
Next is to try to get subroutine calls working
BTW: I read on another forum that if you select a file on the memory stick and press start (i.e. the file is not loaded yet) you get the tool path window showing a simulation of the code!
Onwards and upwards
  • Country: ie
Re: DDCSV Control Language
« Reply #1 on: February 14, 2018, 07:44:05 AM »
How about loops:
(Safe Block)
G00 X0.0 Y0.0 Z0.0
#11 = 3
F 50.0; Nice and slow
(Test Loop processing)
N5 WHILE #11 > 0 DO 13
   G01 X10.0
   G01 X0.0
   G04 P5000; 5 second delay
    #11 = #11-1;  The number of cycles decreases
END 13
M30
The above works a treat! :bugeye:
  • Country: ie
« Reply #2 on: February 15, 2018, 07:51:27 AM »
And now here is a subroutine:
(Safe Block)
(Investigate Subroutines)
(set initial X, Y  and Z)
G01 X0.0 Y0.0 Z0.0 F100
#1 = 3.888
G01 Z2.0
G01 X FIX[#1]; Round Down
G01 Y FUP[#1]; Round Up
G04 P5000; Little delay
(Note the above has nothing to do with testing the subroutine mechanism!!)
M98 P456 L3; Call subroutine 3 times
M30; End main Program
(Declare the Sub)
O456
G91
G01 X2.0 F50
G90
G04 P3000; Little delay
M99; End of Sub
Hope this helps
Will
Offline Cosimo.83
  • Country: it
« Reply #3 on: February 15, 2018, 01:03:32 PM »
Bravo..... Fantastico..... Hai provato a fare un probe e vedere se dentro al programma ti parte la sonda per ricercare lo zero pezzo e poi riparte? Tipo la torcia del plasma.... Grazie
  • Country: ie
« Reply #4 on: February 16, 2018, 05:27:20 AM »
