Author Topic: Stirling Engine  (Read 4225 times)
Offline Doc
    • My Youtube Channel
Stirling Engine
« on: February 23, 2018, 10:02:51 PM »
 I started modeling and putting together a Stirling engine design back a long time ago. I used it as training for learning CAD when I became a CAD tooling design engineer. I thought well maybe some day I would build it. Well today is the day I start. It has been a long time in the works. I put a few finishing touches on the model and will start it soon.
Re: Stirling Engine
« Reply #1 on: February 24, 2018, 04:03:58 AM »
Hi Doc,
Looking forward to seeing this build. It's something I've always wanted to make.
Cheers.
Offline Doc
Re: Stirling Engine
« Reply #2 on: February 24, 2018, 09:36:17 AM »
Got a small start. Cut material and turned up a spud on each end these will be used for aligning the hot cap with it left them oversized until the inside dia is bored. I will locate on the inside bore to turn the fins and at that time I'll finish the end alignment spuds.
PS also the length was cut to finish and I'll post a video here after I get a little further along.
Re: Stirling Engine
« Reply #3 on: February 24, 2018, 02:09:44 PM »
I'm watching George.
Hoping to learn something new.....  :thumbup:
Offline Doc
Re: Stirling Engine
« Reply #4 on: February 24, 2018, 02:41:52 PM »
  The bore finished and mounting hole done (the spuds on the ends will be finished to a finish dia later)
Next step is to cut cooling fins.
A video is uploading and I will post later.
Here is a pic for now.
Re: Stirling Engine
« Reply #5 on: February 24, 2018, 04:00:07 PM »
I'm watching too.
Offline Doc
Re: Stirling Engine
« Reply #6 on: February 24, 2018, 07:19:38 PM »
The start of build.
Offline Doc
Re: Stirling Engine
« Reply #7 on: February 24, 2018, 08:24:41 PM »
Cooling fins done.
Here is a pic video is uploading should be posted tomorrow sometime.
Offline Doc
Re: Stirling Engine
« Reply #8 on: February 26, 2018, 05:41:19 PM »
Took awhile my internet provider had issues.
Offline Doc
Re: Stirling Engine
« Reply #9 on: February 27, 2018, 05:12:10 PM »
Ok got started on the hot cap started by drilling the ID out. She was a little tough but didn't go to bad.
Offline Doc
Re: Stirling Engine
« Reply #10 on: February 28, 2018, 05:21:02 PM »
Got it bored out to size and bottom flattened out. Flattening the bottom was a real pain but I got it without wrecking anything.
Next I will finish up the od and flang.
Offline Doc
Re: Stirling Engine
« Reply #11 on: March 01, 2018, 05:47:51 PM »
Ok finished up the hot cap for now unless II decide to change it and add material to the end of it.
And here is a video of finishing it and no laughing at the struggle I had with it. :lol:
Re: Stirling Engine
« Reply #12 on: March 02, 2018, 12:08:58 AM »
Well that was humourous! Scribing or scoring the shaft is a good idea I'll have to remember that! It's coming along nice though.
Re: Stirling Engine
« Reply #13 on: March 02, 2018, 05:19:34 AM »
Hi Doc,
Air pressure's a bitch, ain't it?  :lol:
To avoid this next time.... centre drill a small hole deep into your mandrel (somewhat deeper than the part, ideally); then cross-drill into it. Your part will then push on/pull off much more easily...
The only thing that might happen, is it might not hold on the mandrel quite so well when you're turning it, as it won't have air pressure to help it hold on.
Or: Zhengzhou, China. An even longer way from anywhere...
Skype: adev73
Offline Doc
Re: Stirling Engine
« Reply #14 on: March 02, 2018, 04:42:57 PM »
Ok got a start on the displacer I chose to bore the ID first.
Re: Stirling Engine
« Reply #15 on: March 02, 2018, 07:47:17 PM »
Hi Doc,
After some thought I'd probably score a channel down the side leaving some untouched at the end to retain vacum until you want to release it by raising it to the channel.
Offline Doc
Re: Stirling Engine
« Reply #16 on: March 02, 2018, 08:55:44 PM »
 Yes it would have been a good idea.
     I wasn't thinking about a vacuum problem I was only thinking of it scoring and not being able to get it off ( as that actually happened to me ) so adding pressure lube only made things worse. I've done smaller hot cap the same way but the size was a lot smaller for my stirling fans and it wasn't an issue. Leason learned hope I can remember it  :thumbup:
Offline Doc
Re: Stirling Engine
« Reply #17 on: March 02, 2018, 11:17:57 PM »
Ok finished the displacer tube by turning the OD and ended up about .03 wall thickness.
Re: Stirling Engine
« Reply #18 on: March 03, 2018, 05:23:36 AM »
Looking good Doc! :thumbup:
Offline Doc
Re: Stirling Engine
« Reply #19 on: March 03, 2018, 08:31:53 AM »
Thanks Phil !
Ok have the displacer ends turned up.
Offline Doc
Re: Stirling Engine
« Reply #20 on: March 04, 2018, 01:29:09 PM »
Played with my first engine built and tried to get it running.
Offline Doc
Re: Stirling Engine
« Reply #21 on: March 09, 2018, 06:52:17 PM »
Awww darn made a boo boo so I need to do a little repair. Machining the main mount plate.
Offline Doc
Re: Stirling Engine
« Reply #22 on: March 10, 2018, 02:57:25 PM »
Well I fixed the dumb a** boo boo I made and dam near made another.
Ever have one f those days you should just not go out to the shop?   :palm:
Offline Doc
Re: Stirling Engine
« Reply #23 on: March 10, 2018, 10:04:27 PM »
Power cylinder done.
Offline Doc
Re: Stirling Engine
« Reply #24 on: March 11, 2018, 05:25:33 PM »
Ok I started a short little update uploading to youtube and then took my pal for a walk. We walked about 1.5 miles it was cool but not to bad. Just got back and here is the piston update.
