Author Topic: Mill/drill stand for Warco Major mill  (Read 33329 times)
Online philf
Re: Mill/drill stand for Warco Major mill
« Reply #25 on: August 05, 2018, 04:29:55 PM »
......I was ready to replace the awful single phase vibrator that mascarades as a motor with a proper 3ph one ......
Bill,
We had a mill/drill at work and "single phase vibrator" sums up the motor nicely. It was well enough balanced in that when you let it run down from full speed to stop with no power there was no vibration. As soon as you applied power it was terrible, the belt guards rattled violently, and it was almost impossible to get a good finish! Swapping the motor out for a "decent" 3 phase motor with a VFD would be the first job I'd do on a mill/drill. Even a 1 ph motor from a good maker would be a huge improvement.
« Reply #26 on: August 05, 2018, 05:12:19 PM »
The drill mill will do fine work ,  plenty of guys here do wonderful work on them
Now we agree.
Sorry about the bad motors mentioned, mine is fine, but it's an older Enco, and US electrical specs so again specifics, are important.
« Reply #27 on: August 06, 2018, 03:56:48 AM »
Single phase induction motor is bit like single cylinder four stroke I.C. you need an massive flywheel...problem is that this type of mill has splines between belt sheaves and spindle, you really need a 3p motor or secondary flywheel (or good fit with the spline).
RE: accuracy, rigidy, mass, stiffness and all that.....production environment is a completely different ball game. For hobbyist it pretty much tells what is the "absolute maximum rating" of the machine.
I know a person that "tested" the some machines with normal structural steels and end mills. His idea was to use same make end mill with recommended feeds/speeds and programs (on CNC) to produce commercial parts with commercial tolerances. Smallest machine (and the only manual machine) was Bridgeport. On this application bridgeport strugled on 12 mm or bigger endmill.  Can't remember how the real CNC:s were, but their productivity and and abbility to keep tolerances were magnitude better.
For most hobbyist the bridgeport (layout/size/weight/expence) is the goal or dream and we use way bigger than 12 mm endmills on them! It is just completely different ball game.
Yesterday I chucked 52 mm OD 2 mm wall pipe on milling vise and used 8 mm carbide endmill to notch it. I was using it probably 600 rpm (highest speed on my current mill) and feeds/speeds were fraction on nominal values. But I needed that radius and this was not production environment.
Anyway, I am bying cheap mill/drill that I'm paying way too much for what it is, but at this moment and on my situation it still looks like my best chance of getting something done... there are better and smaller (10x price), there are better and cheaper (5x weight/size, used), but this capacity/size/availability/price is just a compromize I had to make or I would not fit into my garage or would not move swarf.
Anyway, hope it get's shipped today and I get my hands on it and learn on next few something new....hopefully it is good enought and I don't need call it partial loss.
Offline WeldingRod
« Reply #28 on: August 06, 2018, 02:45:39 PM »
Another couple of stand thoughts: get it high enough, and make it so you can roll out the cabinet!
I jacked my Rockwell up about 6" to address my 6'4" height.  Its cabinet is useless, though.  I found some ikea drawer modules, about 4' tall as 12" so square with a whole bunch of shallow drawers.  I one on each side of the column.  Super handy! I wish they still made them!!
My Hardinge is jacked up about the same amount.
« Reply #29 on: August 14, 2018, 01:22:05 PM »
I thought they had lost the shipment, because last update on tracking info was 7.8 and contacted Warco Yesterday. Afetrnoon I got a call from Finnish depot that I can have it tomorow morning. Took surpricingly long time for them to process it. Hope I'll like it.
« Reply #30 on: September 09, 2018, 07:34:59 AM »
Last night I cut some C-channel (80x45 mm and 65x40 mm). Four 740 mm pieces for legs (because that is the maximum size that fits into my flower pot that is filled with vinegar to remove rust and slag). And four 500/600 pieces for table apron and stretchers.
Flower pots are perfect size, almost 750 mm internal lengt, but still about 10 liter volume. Drawbacks are missing lid (opening means streching new clingafilm) and material should be thicker all over.
Not cruicial on this one, but sometimes it would be really nice how to weld together pipe/plate/channel to to produce strogest joint. I know some priciples, but there is more. Wonder if there is a siple guide to layman?
« Reply #31 on: September 15, 2018, 05:29:06 PM »
Draw bar.
First I was thinkking if differential screw. It needs certain ration and at the taper end is tandard, that leaves tail end to play with. Hole trough the spindle is pretty good for M16x2 thread and was easy to tap. Therefore I made alternative design.
Drilled 8,5 mm hole trough  M16 20 mm long screw.
M8 thread at tail end of draw bar and long nut to fit.
Greased the rotaing parts and used bearing retainer glue to glue M8 long nut into draw bar. Left it upright for glue to harden and prevent it running to wrong places.
« Reply #32 on: October 14, 2018, 02:45:27 AM »
I have been bussy lately, but put hour now and then to this.
Decided to  make it minimum size (base size for the drill mill and a little extra to put the mount holes iddle of the C_channels results in outer size of base is 400x600 mm. Height 750 mm.
Welding and paintin was easy. Came out pretty heavy.
Used best part of the day putting the lifting eye on the roof joist. Build it from two 2x4" upright atop of roof joists. Spend some time questimating would that bee good enough. It was. Used M16 8.8 all thread and lifting eye, big washer upper end trough hole on one 2x4" laying flat.
I bought cheap chanin block and I am not sure if the markings are right on the box. Promise is for one metric ton, but maybe for them metric and imperial ton is the same. It was a little sticky with 1/3 of metric ton.
Got it lifted, put in the tray and proceeded to shim (my day off).
« Reply #33 on: October 14, 2018, 05:54:13 AM »
uhuh
Shimming it straight was not easy (nor completely over) :Doh:
I think that not only the floor is skewed but the welded fame has a set and something flexes on 0,1 mm /m scale when bolts are tightened.
The big idea was to nip the frame reasonably straight and true on mill base (it is ribbed cast iron frame with some rigidy) and then shim it level and relaxed on the floor. That did not give consistent results.
Plan "B" now it is reasonably level, but not completely straight. I bolted it down, let it settle and if it has big issues I shim again the base. If it stays on level, I will shim the mill straight betwen mill plinth and table frame.
Next time I'll design adjustment on the floor pads.
After I bolted the frame on the ground i cut the bilical cord - took away the hoisting equipment. Now it has to stand on it's own.
« Reply #34 on: October 14, 2018, 07:36:16 PM »
Looks good but I’d be worried a little the machine base is bigger than the stand and once the table is moved to the end of travel supporting any weight the leverage just might tip it! I see it’s bolted down I’m just saying!
« Reply #35 on: October 15, 2018, 03:05:39 AM »
Pretty convinced that M10 achor bolts will keep it tied properly on floor.
I was first considering buidling a frame over a toolbox. I could not find a tool cart of proper size (I actually bought one). But with wheels and/or table support frame it would have brought the many mill controls too high and I would have left behind it 100% empty space - they are not that deep and this mill is about one metre deep. The tool cart will be repurposed to it's original function as a tool cart to store some measurement tools and such
Then I checked smallet tool chests and boxes and I felt that I would be designing in a unnecessary complication with a very little gain. All resulted in wasted space and reduced flexibility. Therefore I decided to build funcional frame and later fit in few selves or drawers and maybe mount something on the frame.
This is build way too thick materials (6-8 mm wall thickness) but that is what I had in hand. And It won't break. I was considering a 3 mm sheet metal shell and putting three drawers in. Would have looked more professional, but harder to build anything in after mounting the milling machine.
« Reply #36 on: October 15, 2018, 02:23:35 PM »
Good to see it on the stand, Pekka! :beer:
« Reply #37 on: November 11, 2018, 11:53:55 AM »
Next thing next:
CENTERING! :lol:
Two basic ways to mount centring indicator
A) Stub that mounts into chuck: Dowside = you need to take off the drill or tool and replace it with indicator.
Coaxial is nicer, but takes more daylight.
B) Threepoint moount that mounts to spindle ot chuck.
Might be nicer to centre multiple holes and use one centre drill.
« Reply #38 on: November 21, 2018, 04:42:21 PM »
Next thing next:
CENTERING! :lol:
B) Three-point mount that mounts to spindle ot chuck.
Got today ne about 11£ job.
Glad I bought it. It is sort of 3D model for what I need.
Construction is pretty sloppy and it has pretty inconsistent adjustment. It has a lot of nylon washers and some aluminium spacers, but adjustment tries to open/close thumb nuts and that affects adjustment "feel" also the arms are pretty thin and every part flexes.
The three point fixture mounts nice on spindle nose (but has no space to turn there) and mounts pretty nice to drill chuck.
Some pictures...
« Reply #39 on: December 20, 2018, 05:45:18 AM »
Mill has been used to make some light work. Now my carbide mills and drills gets exercise at top speed (all that mill has, my 1,5 metric ton mill has 700 rpm max spindle speed....).
However, it started ocassionally really rough - banging and shuddering. As if the centrifugal switch went to very rapid ON/OFF switching during the start. Seemed to happen mostly on two highest speed (that I used anyways 80% of time).
Sent message to Warco and it was answered pretty fast. However they were not interested to assist me to troubleshoot it (maybe understandably - there are all sorts of people). Suggestion to take it to motor shops does to fly with me.
I opened the motor junction box and Z-circuit wires were all loose - that goes long way explaing the rough start (this is the start capacitor - centrifugal switch circuit), two other screws were not tighten either. Two other connections and ground wire connections were loose on the control box (the one with all push-buttons). After tightening them up it hasn’t been acting up anymore.
Next challenge is to find correct belts to it. The original V-belts are pretty lumpy and are wearing rapidly.
There are two belts, luckily they have markings that make some sense. They are A-profile belts and first number is ID-length, next is nominal length - in this case datum length.
Longer belt, markings on the belt: A-1000Li 1033Ld
Measured Li 998 mm, La 1058 mm.
Shorter belt, markings on the belt: A-838Li 871Ld
Measured Li 837 mm, La 897 mm
I would like to replace them with AX or XPA cogged belts. Looks like they are not made exactly to same dimensions, considering XPA 882 and XPA 1030 Optibelt Super X-Power belts.
let's see,
« Reply #40 on: December 20, 2018, 03:47:26 PM »
There's a lot to be said about replacing the solid belts with linked belt like this:https://www.durabelt.com/linkedvbeltinfo.php
The linked belts are better damped so vibrate less than a normal V belt . Notched (timing) belts can be noisy .
« Reply #41 on: December 20, 2018, 04:04:08 PM »
This is cogged V-belt
I agree timing belts can whine at high speed.
« Reply #42 on: December 21, 2018, 03:22:49 PM »
Got the belts and changed them, sounds whole lot better and smoother.
Got those: XPA 882 and XPA 1030 Optibelt Super X-Power belts, they are not exactly the same nominal size, althogether nominally about 8 mm longer. They are easier to change speeds than original. Have to see if I need to change one shorter when they start to wear.
So far looks good.
