Author Topic: New 3D printer  (Read 26778 times)
New 3D printer
« on: November 25, 2020, 09:01:14 AM »
I think I have done all to my Ender 3 that I can do without replacing frame pieces to extend it.
I have actually decided to build a second printer...
Found this CoreXY printer that has a decent design and good following.
BLV MGN Cube
Will be powered by a Duet 3 and Rasperry Pi.
I have the a 320mm bed to go in it, but I have the files to do an even larger bed (400mm). The frame/rails I am using will allow for a Z of 595 mm.
Doing the triple Z thing to allow for 3 point bed leveling.
Got most of the parts in. Will be starting the build in the next month or so.
« Last Edit: December 01, 2020, 09:11:56 AM by Brass_Machine »
Offline MetalMagus
Re: New 3D printer
« Reply #1 on: December 01, 2020, 07:07:10 AM »
Hi Eric,
Take a look at the Hevort 3D printers on Thingiverse, GitHub and Facebook.
https://www.thingiverse.com/thing:3532039
Regards
Sean
Re: New 3D printer
« Reply #2 on: December 01, 2020, 09:14:58 AM »
Hi Sean,
Thanks for the link!
Someone has taken the HeVort bed mounts and have adapted them to BLV Cube. May end up doing some hybrid monstrosity of printer...
Have you built a HeVort?
Offline MetalMagus
Re: New 3D printer
« Reply #3 on: December 02, 2020, 06:59:04 AM »
I've started printing some of the parts. But, that's as far as I have got. Life and other projects keep getting in the way. But I follow the FB group and will get back around to it soon.
Sean
