Author Topic: Cannon ball mold  (Read 9313 times)
Offline Powder Keg
  • Machinist Extraordinaire
Cannon ball mold
« on: May 10, 2008, 11:37:25 PM »
Here is a mold for balls that fit in soda can mortars. I made this on my old lathe.
Later, Wes
Wesley P
Re: Cannon ball mold
« Reply #1 on: May 11, 2008, 11:26:54 AM »
So do you crush the cans in them like a compactor? or are they melted down and cast in the mold?
Offline J. Tranter
« Reply #2 on: May 11, 2008, 10:09:43 PM »
How did you do the spheres?
Offline Alphawolf45
« Reply #3 on: August 13, 2008, 01:02:44 PM »
I made mold the same size as that, I  used my cnc mill..I wrote the program by hand , lonnnng program so I didnt get the steps extremely close together. There are visible concentric rings that show up in the cast lead balls..Aint as purty as mold you made right there.
...Ever have friends over drinking beer, shooting cannon  and accidently hit the neighbors house with one of them lead balls?  ::) ;D
I am not actually retired ,I merely find myself disabled by an intolerance for productive activity.
Offline PTsideshow
« Reply #4 on: August 13, 2008, 04:20:59 PM »
I believe the soda can mortars refer to the the size of the opening and what it shots as opposed to lobbing lead shot spheres as the seem to be discussing here. At least the ones I have seen the idea was the bore was the size to hold a soda can. The other sized one is for tennis balls.
The idea behind soda cans and tennis balls was you,could remove the missile from the mortar or cannon if it should miss fire and not launch. As removing a hunk of lead the size of a tennis ball approximately,safely or with out danger to remover could be problematic. If it did go off, you might have no need for a fancy suit or a open fancy lined resting box. :o ;)
As for hitting the neighbors house, with a hunk of lead that size can you say. In trouble with the authorities up to and past your epaulets. ::)
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline Alphawolf45
« Reply #5 on: August 13, 2008, 05:31:26 PM »
  Black powder is lot of fun.I built a few mortars.
