Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
The Craftmans Shop
Model Engineering
Looking for V2 Magnum plans by Steven Pierce
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Looking for V2 Magnum plans by Steven Pierce (Read 11734 times)
V 45
Jr. Member
on:
June 03, 2012, 08:03:27 AM »
I found this engine while doing some surfing..actually found an email but came back undeliverable. I would like to try and make this...Steven Pierce's 60° V-twin motorcycle engine. This engine is run on CO2. The scale is about 1/16 and it is made from brass and aluminum. It has a 1/4" bore and 1/4" stroke and is called the "Maxum Magnum."
http://www.floridaame.org/GalleryPages/g1Non0134.htm
Thanx again... V45
Logged
V 45
Jr. Member
Re: Looking for V2 Magnum plans by Steven Pierce
Reply #1 on:
June 15, 2012, 08:13:11 PM »
After looking around somemore ... it was brought to my attention that it's based offf this engine build by David Kerzel.
http://www.john-tom.com/MyPlans/SteamPlans3/DavidKerzelCO2/TwinKerzelCo2.pdf
But I still don't see how he mounted the top of the engine in the Magnum version? Any suggestions ?
Thanx again...V 45
Logged
Brass_Machine
Administrator
Hero Member
Country:
Reply #2 on:
June 15, 2012, 10:10:30 PM »
Are you talking about the "valve covers"?
It might be possible the are screw on. I just saw a radial build (gas) where the designer did that.
HMEM Link
Hope that helps?
I have DL'd the Dave Kerzel plans awhile ago and it is on the list!
Logged
V 45
Jr. Member
Reply #3 on:
June 18, 2012, 10:06:54 AM »
Hi Eric,
Yesthanx...I was referring to the rocker boxes/ valve covers. How would you thread that small internal...I'm a new to this just since Jan 12 !!
Thanx again... V 45
Logged
Brass_Machine
Administrator
Hero Member
Country:
Reply #4 on:
June 18, 2012, 10:45:22 AM »
I would use a tap. start with a tapered then go to a bottoming tap.
Logged
Print
Pages: [
1
Go Up
« previous
next »
The Craftmans Shop
Model Engineering
